![](https://modelshipworld.com/uploads/monthly_2017_06/594c220154a6f_JuliaDelacruz.jpg.7fb548c654153ae17c8e0d7243b347df.jpg)
russ
Members-
Everything posted by russ
I have never heard of a rammer's line. The line that was seized to the ring bolts on the bulwarks and then around the end of the gun barrel and back to the bulwarks on the other side of the gun was called the breeching rope, or just breeching. It would limit the gun's recoil. Russ
- 601 replies
- constitution
- revell
Do you mean the breeching that goes around the end of the gun? Russ
- 601 replies
- constitution
- revell
Robbyn: Check out Chuck's build log and look at his photos of that area. That might give you some guidance. http://modelshipworld.com/index.php?/topic/629-18th-century-english-longboat-by-chuck-c1760/ Your planking is looking very good. Nice work. Russ
- 234 replies
- 18th century longboat
- model shipways
Rusty: They look very good. My only advice here is to make sure they are set perpendicular to the baseline when you finally install them. Right now, they look like they are leaning outboard a bit. Russ
- 332 replies
- Triton
- cross-section
Kevin: The sides overlap the stern so that the end grain of the stern is covered by the side planks. Is that what you are needing to know? Russ
- 23 replies
- model shipways
- Willie L Bennett
The cap squares look pretty good. You can always glue them on if you are worried about them coming off. Russ
- 601 replies
- constitution
- revell
That looks pretty good. Those pieces out of which you made the eyebolts are backing plates for the lower ends of the chainplates where they attach to the hull. Another small detail to consider adding is the capsquare on each side of the carriage. These are the metal plates that hold the trunnion in place. You can use strips of masking tape painted black, or maybe even black pinstriping tape. Russ
- 601 replies
- constitution
- revell
Your gundeck looks good. I cannot see the seams in the photos and they are usually quite prominent. I think you did just fine. Russ
- 601 replies
- constitution
- revell
Len: You are doing really beautiful work. Thanks for sharing this build. Russ
- 122 replies
- bellerophon
- victory models
Mario: Very nice work. I like the window frames. Very elegant touch. Russ
- 78 replies
- victorian steam launch
- constructo
Cannon Breeching
russ replied to RiverRat's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
The best information I have is for British guns for the early 19th century. The Naval Pocket Gunner of 1814 says the breechings for 24s were 6 1/2", for 18s 5 1/2", and 9s were 4 1/2". This is circumference. Russ -
The ratlines look very neatly done. Nice work. Russ
- 95 replies
- bluenose
- model shipways
Paddy: On drawing treenails, I always hold the plate in my hand and draw with the other hand. I use a hobby knife to split my bamboo, but I do not worry much about if it is perfectly square in section. I usually draw about a 6-7 inch length at a time. Always go through each hole more times than you think you should. On the last several pulls through a given hole, there should be very little resistance. I angle the dowel through the hole on the last several passes to try and take off a little more before moving on to the next hole. That makes drawing through the next hole a bit easier. Russ
Adam: This model has a nice looking hull form. I think it will make a fine display once it is completed. Those bow "fillers" are really just there to give a landing for the bow planks. If I were doing this, I would fit some extra balsa or basswood fillers in between the first few bulkheads and the last few bulkheads. This will make planking a little easier because the lower planks ends will have some place to land in between the bulkheads. Have fun with it. Russ
