amateur
Posts posted by amateur
  1. And it flies. Definitely the most difficult one so far....
    Especially the steel thread on wich it is mounted proved a problem: I used slow setting two-component epoxy. Not a good idea: the stuff hardens way too slow (I even think I got the mixture of the two components not correct: the stuff remains elastic, and therefore, it was difficult to fix the thread to the internal stucture. I hope it holds....
    But so far: the second wing and the head mounted, it is a 'realflying bird' in my cupboard. I like this one, as we have those finches flying around in our garden in autumn.
    That made two steamloco's and a bird. Now back to ships, I guess.
    Jan
  2. Sorry, that I didn't make my remark far earlier, I suspected it before, but I thought that it was the pic....:(
    When you are goung to rip the planking off between frames 5-10, is there any way to ensure that although offf-center, the stern will be vertical? In the last pics it looks as if the last two frames are tilted to the left, resulting in an asymmetry, but also a 'non vertical' stern.
    An off-center stern is a pity, but from a distance not very visible, a non-vertical stern does attract attention (in  a non-wanted way).
    Jan
  3. Was she painted an evenly blue, or did she had some camouflage patten on top of that blue coat?
    [edit: forget my question: the answer is in your first post :) ]
    On my screen the blue really pops out: is that because of a badly calibrated screen, or was this navy blue that kind of bright blue?
    Jan
  4. It has been a while that I posted ship-related stuff here, but I have been busy all along. I did two very nice (and also very easy german locomotives), and I started a bird.
    This time a lifesize flying one: a goldfinch. No buildlog, butjust a couple of pics to show progress. Pretty well self-explaining.
    IMG_0152.jpg.f45533932aca5162d575688e3a3d4313.jpg IMG_0733.jpg.f4100239670663c203fb3a0c42275ef7.jpg
    IMG_0735.jpg.1deabc58108c18952909968f84a5bb29.jpg IMG_0736.jpg.468d79b2ef882878815219b4b521c0cb.jpg
    These birds by Johan Scherft are easy to build, and their appearance is quite lifelike.
    This one is a bit more work than the others I did so far, as it has spreaded wings (with a coupe of individual feathers per wing). I had some trouble to get the body nicely closed, so I hope the head will fit. If not, the whole things flies into the dustbin, I will make a new print and start from square one :)
    Jan
  5. Actually, you could argue that the dark version is too dark, and the unpainted too light.
    in both contemporeneous models, there is almost no contrast between the painted friese and the shingled roof: there is a colour difference,but not too much difference in heaviness of the colour. You could try a colour that matches the original model slightly more: a bluish grey slate, in stead of the rather stark black.
    And, although I will never try a modl like this myself, it is a joy to see how it should be done. I'm a daily visiting, non-posting admirer :)
    Jan
  6. I think the answers of the first two questions are hidden in the mists of history.....
    The answer to the third question is (as far as I know) yes. Some small inland craft are still build kind of shell first:
    Although it is hardly a shell: those are mainly working boats, build on a heavy floor, and with sides made out of one or two heavy oak boards. The frames are put in after the sides are in place.
    check this one: https://www.dezeilpunter.nl/de-bouw-van-een-punter (don't forget the video that is embedded)
    It looks like shell first is just the upskaled version of this building technique. (but I don't know whether or not there is any evidence for that....)
    Jan
  7. Don't overdo it: rule number 1 was to keep your machine as clean as possible. There willbe some buildup of grease, but on theotherhand, that is in spots that are easily accesible, so the driver wa/able to remove the build-up. The constant maintenace results in a rather evenly shine of the wheelfronts and driving shafts. the sand is not in contac with the machine: it is deposited on the rails, so no sand on the machine.
    Finally: trains get an amount of dust, but are not in contac with real dirt. So it shows up as a dusty film, mianly on the upper parts.
    you have to check the position of the fill-caps for the water and coal: those do show up quite clearly. Check out some of the railroad-building sites: subtle weathering is in my view far more effective than the 'shouting out' version.
    Jan
