Everything posted by amateur
Today I started the rings on the lids. Fiddly stuff (too fiddly for my fingers and my tools: carpet monster took abot half of them ) and fitted on my test-port lid. Outer diameter of the ring ist about 2 mm. Actually, these are adapted 3mm rings that I found a long time ago on a webshop long gone. Jan
- 139 replies
- corel
- prins willem
yes, you forgot something: XI: a nice gift-paper to wrap it all up (ad VII: certainly no stay-sails, and no preventer stays. Don't forget the shrouds and the all-important ratlines) Jan
When you receive the kit, can you give us some of the history? Fentens advertises it as a Polish machine, named Bulgar, sometimes it is referred to as a German machine, but the pics in the internet suggest that it is a Bulgarian one (build in Poland, nicknamed 'Mother Bear') (registration number 46.03) (btw nice pattern for the rivetting :)) Jan
Hi Piet, I considered that, but there is nithong behind the ports, apart from that ugly U-shaped piece of black painted wood, and in some cases: just plywood of the bulkheads. Nothing of interest, so not drawing attention to it by showing an open port. Jan
- 139 replies
- corel
- prins willem
Just coincidence and lazyness. the local shop sells 400grams card (way to thick), 150 grams with a very visible structure in it, and 120 grams in packages of 250 sheets (way to much) So I took a sheet of white, cut two strips, ran a black marker along it. Took me less time than going to big city nearby Jan
- 139 replies
- corel
- prins willem
- 139 replies
- corel
- prins willem
Oops..... Good luck you were on it in time. take care! Jan
- 332 replies
- fluit
- abel tasman
I guess there where wire-diagonals with the original, but yes, these frames did not give any protection to the pilots at all. Jan
I have been struggling with blackened paper all morning. came up with this so far.... six lousy strips. Perhaps my tolerances should be slightly higher, to get some speed Jan
- 139 replies
- corel
- prins willem
I asked on an other forum (a very interesting German one), what they thought of open vs closed. The odds were very much in facvour of 'closed'. Therefore (also given my own hesitations, and the clear preference of the admiral), I decided for closed. That made it more important to have the lids at a snug fit. So I wnet over them again this morning. Starboard done: I fitted all lids using Tamyia tape to their gunport, to prevent mix-up. Next comes the hinges. GIven the size of the hinges on contemporay models, I decided that the Corel provided ones are not a serious option: too wide, too thick, and most of all: horrible bolts. Hope you agree with me So today will be: cutting small strips, painting them black, and adding them to tine squares of wood. I guess the carpetmonster will be lurking
- 139 replies
- corel
- prins willem
you could use 'De Roode Stier' but also 'De Roode Os' (Os translates as Oxen, but you already guessed that) or 'De Roode Bul' (yup, you guessed it) Actually, there was a VOC-ship named 'Zwarte Bul' , and one named 'Os' (I also found a Cow in the listing). Couldn't find any references to 'Stier'. That makes 'Roode Bul' the most adequate. Jan
Your main concern to get it more Dutch willbe the side-galleries. These should be pleasing to the eye, go with the flow of the wales, and show curves, instead of this boxy revell thing..... Jan
But the detailed vdv is not the wapen van edam, but a larger ship (zeven provincien?) Actually, Edam has a black bull, not a red one Jan
I wrote 'closed gunports are not an option', but the admiral was of a different opinion. her arguments: -no sails, minimal riggi g, ship is clearly in harbour. Why would you run out all your guns? - you left off all the smaller guns on the upper decks, why would you include the guns in the main deck? - If it isdifficult to attach the lids neatly, why show them open? After thinking it over, Itend to choose the admirals side: also the original model in the Rijks does show her with ports closed. decisions, decisions........ Jan
- 139 replies
- corel
- prins willem
I made some sawdust today. I fitted gunportlids on one side of the ship (two sides to go ). Next the second layer on the inside will be done, two rings (inside and out, and some paper hinges. I made a mistake some years ago, by following Kettings: he shows none-square gunports, implying that it is a bit difficult to get the gunports nicely fitted to the hull, without pointing in all directions.. (but leaving them all closed is not an option) so far for today. Jan
- 139 replies
- corel
- prins willem
I already knew that subs are not very spacy things, but the way you modl yours does show the living space very convincingly. Jan
Absolutely unbelievable..... The canopies look convincing, even in the macro-pics. Jan
- 345 replies
- graf zeppelin
- trumpeter
