Everything posted by amateur
Now Hear This! Torpedo boat V108 model now available!
amateur replied to ccoyle's topic in Card and Paper Models
Great. Would definitely like to give this a go. Still trying to find a type of paper that is good enough to do these kind of models, but also acceptable to my printer..... Jan -
PRINS WILLEM by juzek
amateur replied to juzek's topic in - Build logs for subjects built 1501 - 1750
The carvings are nice, but why did you choose not to model rge knights head on the main knight? Those carved heads were quite typical for the ships in this period. Jan -
Great! New updates coming! (although I have to admit: cheating on your side takes a while to accept on our side....) Jan
- 1,207 replies
- sloop
- kingfisher
I thought something completely different: these ships must have been quite daunting for new crewmembers: how much drills did you need to find your way in this maze of turrets, gangways, decks and guns. And not only in broad daylight in harbour, but also at see, in darkness, in the heat of battle. Glad I wasn't there (nor on any other battleship in action) Jan
Willem Barentsz by ceestoorn - FINISHED
amateur replied to ceestoorn's topic in - Build logs for subjects built 1501 - 1750
Nice! Jan -
But he still needs the upper gundeck before the masts can be stepped...... And considering he is only into his fourth (?) year for the lower gundeck, I 'm not sure whether we normal mortals will see this beautiful ship fully rigged..... Jan
Poor results with carpenters glue
amateur replied to a topic in Modeling tools and Workshop Equipment
I never had white pva glue fractured. It remains slughtly pliable for quite some time. Sounds like bad ju ju.... Jan -
file, caliper, and some eyeballing (but I'm not an expert ) Works fine as long as there are not too many yards. The drill didn't work for me: problems with centering en getting the whole thing stable. Jan
Hi Marcus, Some ofthese ships had a second (small) mast set up, like the haringbuis. Mainly to help them keeping position while at work. Notvery common on these ships, though.... Jan
- 434 replies
- pelikaan
- beamtrawler
This one, for instance You see the typical design of the bomschuit: it is like a box... They were designed to get ashore at high tide, so that they could be unloaded and serviced at low tide. This because many of the fishing villages at the northsea did not have a harbour (completely impossible to dug a harbour in the flat sandy beaches. Jan
- 434 replies
- pelikaan
- beamtrawler
Fokker Dr.I by Torbogdan - FINISHED - Model Airways
amateur replied to Torbogdan's topic in Non-ship/categorised builds
I checked on the internet, it is different: the model is only showing the inside! Great model to look at when finished! Jan -
Airships are also ships Question: the drawings show the construction as build (the framework of the body, the ribs in the wings, with the cut-outs to keep the weight low) Is the kit also 'as build', or is it only showing the outside of the plane as it was? Jan -
That's a serious drop in quality..... Areal shame. Unlessthis is tobe used to plank the inside of the hull (which it isnot, i presume) you have an issue there. Jan
- 305 replies
- deagostini
- vasa
sharpening stones which are best for the price
amateur replied to John Allen's topic in Modeling tools and Workshop Equipment
You mean you never break the tip by letting it go down on the floor? (Or did you just by an increadible amount of those things in 1984. ) Jan -
Did you made up your mind with respect to rhe paintjob? Jan
- 749 replies
- albertic
- ocean liner
Hi Greg, i already suspected this type of modelling is not my cup of tea. Now I know for sure Thanks for sharing your techniques! Jan
Lookimg at the last picture: this area has been repainted, bur it looks as if two portholes were missing before the last repaint. Or are these two recent damage? Jan
- 749 replies
- albertic
- ocean liner
