amateur
Everything posted by amateur
  1. I dont see major errors, but then, I've only your version which looks pretty good. Will the model be live-steam? Jan
  2. Sorry Sjors, Couldn't resist this one. Here is your lion!
  3. i used these pushpins lot cheaper, and essentially the same functionality. Jan
  4. Neither did I, but I found a discussion that only after titanic sank, there was a ruling that said that they had to be painted red/white. Before that, it was cork covered in white canvas. Jan
  5. Hi Nils, She's looking great. With respect to the buoys: the ones on the Titanic and the Lusitania were just ordinary plain white ones. Jan
  6. The joints are looking very sharp . Make sure the paint of the paper doesn't bleed out as a result of the finish you are going to use. Jan
  7. Hi Carl, Question on your tools: Where did you get your tweezers? Mine have problems in keeping the points neatly centered opposite to each oher when I try to hold something small. (resulting in potential loss of parts, as they are launched into outer space....) Jan
  8. Fun, the end of the booms, yellow disk of around 1.5mm diameter. Don't even think of breathing while you try to pickthese up. Fun: the designer made a mistake: heprinted 12 booms, while there should be 14 of them. A well, what would a kit be without small problems? Jan
  9. Not a log, but to show I did some modelling these last weeks... This guy is sitting on one of my shelves for ages (not as long as my others, but still....) So I decided to give him a kind of boost this week. Modelling at the dinigroom table has it advantages when it is cold upstairs The model is made by Scaldis, a dutch company. She shows MS Axeldijk, one of the ships of the HAL shortly after the war (she is a coverted victory ship, as you will probably see) All in all the model is around 55 centimeters, still workable, but small enough to drive me mad with the tiny pieces of paper. No scale 1:500 PE models for me And no, I don't know why my iPad turned some of my pictures 45 degrees .... Jan
  10. With all those interesting builds, there isno time to do something myself...... Jan
  11. Great. Would definitely like to give this a go. Still trying to find a type of paper that is good enough to do these kind of models, but also acceptable to my printer..... Jan
  12. The carvings are nice, but why did you choose not to model rge knights head on the main knight? Those carved heads were quite typical for the ships in this period. Jan
  13. Great! New updates coming! (although I have to admit: cheating on your side takes a while to accept on our side....) Jan
  14. I thought something completely different: these ships must have been quite daunting for new crewmembers: how much drills did you need to find your way in this maze of turrets, gangways, decks and guns. And not only in broad daylight in harbour, but also at see, in darkness, in the heat of battle. Glad I wasn't there (nor on any other battleship in action) Jan
  15. I'm following with interest. Still contemplating my possibilities is such a model (Although greatly hindered by lack of space, and lack of powertools, not to mention time.....) Jan
  16. Do they have to be working, or just 'cosmetic'? I did some hinges, using just using ordinary white paper, painted black. (yes, closed ports.....) Jan
  17. Ithought so. Time flies when you' re having fun
  18. But he still needs the upper gundeck before the masts can be stepped...... And considering he is only into his fourth (?) year for the lower gundeck, I 'm not sure whether we normal mortals will see this beautiful ship fully rigged..... Jan
  19. I never had white pva glue fractured. It remains slughtly pliable for quite some time. Sounds like bad ju ju.... Jan
