Everything posted by amateur
Papegojan 1627 by mati - FINISHED - 1/48
amateur replied to mati's topic in - Build logs for subjects built 1501 - 1750
But the last post is quite old. Did something happen to the ship or its builder? Jan -
I'm in the same group as popeye: untill now i did not realize that you would stop after setting up the lower masts. But, in fact, it helps setting your model even further apart from all those out of the box stuff. I've said itbefore:this one is amongst the best Wasa models i've seen ( if not: the best) Jan
Tyne or Clyde built steel barque. First guess: Glenlee Jan
At least, I had her country of origin and date correct
I think it isso ething like a steam screw sloop/corvette of the royal navy, somewhere around 1880 Jan
Hi everyone, I did some work over teh last days. I reshaped one of my anchors (Still not perfect, perhhaps I'll need to build one myself). The problem is that it is to short, and too wide for the timeperiod. (and Corels casting is lousy) I did some rigging on the foremast: Problem is: miniature-rope does not quite behave like the real stuff. It allways curves in the wrong direction. That's particularly annoying at the topmasts... This is 0.15 mm Amati rope, it has been stretched, moisted, and waxed, and still...Problem is that the yard is so light, that it will not counterbalance the force of his springy rope... I made some addiotional holes in the fore-tope to get the ropes down to the deck. A bit fiddly work, but I managed. (some of my ratlines worked themselves loose in the proces of rigging , That's a problem I still haven't solved) In the meantime: on to the next ropes.... (same mast, other side of the ship) Jan
- 139 replies
- corel
- prins willem
Yup, that's him. The first, last, one and only whaler we had in the last century. Jan
The same to you!
Looks great. One question though: I see that your rudder sits quite high compared to the bottom of the keel. Danny's rudder has its bottom side flush with the keel. Is that why number 5 went out of sight? Jan
- 1,215 replies
- sloop
- kingfisher
possibly, yes Jan
Interesting idea! Btw: does your admiral alrady realize that therewillbe enough to do two half-hulls from a full-hull kit? Jan
- 28 replies
- ballahoo
- caldercraft
Not much time to find a new one. I post an old one from MSW-1 (But I'm presumable the only one to remember) Jan
I'll post something tomorrowmorning. .
Uss Choctaw, 1864, perhaps?
A cloathing pin in a vice does the trick for me. Put the rope around the block, and put in the pin, such that the rope is held in place. Tie theknot, put someglue onit, and you're ready for the next. It even works with blocks that are smaller. Jan
HMS Leopard by gobi71 - 1/300 scale
amateur replied to gobi71's topic in - Build logs for subjects built 1751 - 1800
And i repeat that: WOW!!! How did uou get those strops around the deadeyes so neatly formed? Jan -
ROYAL CAROLINE 1749 by Doris - 1:40 - CARD
amateur replied to DORIS's topic in - Build logs for subjects built 1501 - 1750
Nice! How did you het those colours so nice? They are not just out of the can revell-colours, it looks as if you did some aging and weathering on them. Jan- 883 replies
- royal caroline
- ship of the line
Hello wayne, Probably on a site of torpedo-casualties.... Or perhaps a wrecksite, quite a lot of english ships around there... Jan
Some time around wwI, I guess.... Jan
