Landlocked123
Gone, but not forgotten
Everything posted by Landlocked123
  1. Hi Karl, I must echo all the praise on both your boat building and photography.. I do have one question; What is the material you used in the photo above to guide the saw cut and how do you attach it to the ship? Thanks,.. Best, John
  2. Hi Brian, I didn't start on the road your on until way too late. Nevertheless, I've made some changes and lost 35lbs in the last 4 months! I found the trick is to incorporate the changes you want to make into your life. If you have a bad day, or week, so what? If you try for a particular diet or workout regime, it's too easy just to let it go when you weary of it. But, in my experience, generally try to make the right choices, incorporate them into your daily practice, and everything will work out. Concentrate on the process. You will make it happen. Best, John PS. If you have the discipline and patience to build a model the quality of your AVS, the rest should be a piece of cake.....I mean carrot
  3. Thanks Ed, That is very helpful. I guess I owe you another beer!
  4. Hi Mark, Jesse nailed it!!!!! You are a vital part of this site and we're all behind you!!!!!! Best, John
  5. Hi Ed, You've left me in my usual state of befuddlement! (Usual to me, not your instruction). I guess where I'm confused is where the beeswax mixture is applied. Is it one the first stage, after sanding, but before the acrylic? I would think the wax would interfere with adhesion of the later layers of finish? Would you please lay out the finishing process in a more linear fashion? Thanks, John
  6. George, I'm sure you're right re opiates, but I'm hyper-sensitive to the issue. My boss's 20 year old son overdosed on OxyContin about a year ago. He was a great, smart, and funny kid and I still miss him. He started out on the pain killers due to a football injury in High School. Best, John
  7. Hi Mark, I've missed you as well and pray for Janet's speedy recovery. I'm sure you know, but try to be careful if their "pain management" techniques involve a lot of opiates. They can be a lot of trouble in the long run, even the the short run for that matter. Please be careful. Warmest regards, John Ps. George, my wife is a lot more stoic than I......when I'm in pain, I play it up to the hilt.
  8. Hi Tony, I also have a Dremel 580. I've tried to improve it with some after-market products from Bill on E-bay in Florida. His workmanship and customer service is outstanding. I've bought his fence, mitre gauge, slip-free belt and gears, and backing plate ( not yet installed). But the saw is still not suitable for ripping accurate timber for planking or decking. What is the Accurizer you mention? Is it still available? Would it solve my problems? At this point I think I could sell the Dremmel with the accessories and come out even. I then wouldn't be to far from buying a Byrnes saw. What do you think? Thanks, Best, John
  9. Hi Ed, In this and your other builds you use pins to keep things in place while gluing. Do you pre-drill the pin holes? Also, when I've tried to use pins while gluing, I've found I need to use excessive pressure to pull them out. Am I missing something? Do you then go back and fill up the holes? Thanks, Best, John
  10. Hi Jules, I'm looking forward to following your build. I'd wish you the best of luck, but somehow I don't believe you'll need luck as much as perserverance. Best, John
  11. Thanks Chuck, I'll give them a try. Best, John
  12. Hi Guys & Gals. I've been looking for brass tubing with a .020"" ID. I've looked in a few catalogs as well as the K&S stands at local shops. No luck. Does anyone have an idea of where I might find some? Thanks. Best, John
  13. Jud, That sounds like the kind of good advice one can't find other than on MSW. Thanks Best, John
  14. And don't forget the sea gulls and what they do!
  15. Hi, What would you guys recommend as a very "white" wood which bends relatively well. I will soon be starting the MS New Bedford Whaleboat which I do not plan to paint. I'm looking for some contrasting woods. For the "gunwale strakes" I am planing on cherry or walnut and would like the frames to be in high contrast. Any ideas? Best, John
  16. Hi Diwang, I'm just a novice. However, I know that Nic is a master builder with a special expertise in rigging. He also runs one of, if not the best, manufacturers of extremely high quality model ship kits in the world. Felted or not, there were about 14 people in the round table with me, and he definitely showed that there was some kind of orientation to the fibers he was using and it was a "best practice" to sandwich the sheets 90 degrees to each other. I also agree with Brian, if you have a "practicum" on sail making, why not share it with all of us? John
  17. Congratulations Brian, Not only Is the ship incredible but your build log is one of the best on MSW. Bravo! Best, John
  18. Hi Julie, I think you might be putting the "cart before the horse" a bit. Nevertheless, at the NRG conference a couple of weeks ago I attended a fabulous sail making workshop run by Nic Damuck from BlueJacket Ship Crafters. He showed a very simple and effective way to create sails. Using Silkspan (a specialty fabric used by radio controlled airplane builders) he created very realistic sails. Silkspan is very light and somewhat translucent. It also has a barely noticeable weave. Nic drew a sail pattern on one sheet using pencil, then using watered down white glue, he sandwiched that between two more sheets with the weave at a 90 degree angles. Then, very carefully worked out any air bubbles. He then trimmed it to shape with scissors, placed it over a frame (of coat hanger wire) contoured in such a way that when the sail dried it mantained its shape. The pencil lines in between the layers gave a very realistic and subtle impression of the panels comprising a sail. To me the most important aspect was that the sails appeared to scale. Best, John
  19. Hi All, Ther way I see it, is that given this is Sal's second build, he is mere steps away from Danny V., Remco, EdT and some of the other great builders on this site! Best, John
  20. Michael, You must be so proud and happy! Seeing that picture made me smile from ear to ear! Congratulations on having "built" such a marvelous family!!!!!!!! Best, John
  21. Hi Sal, I totally echo George's sentiments and when I saw the pics the first thing I thought was SWEET!!!. I hope you bring it on 11/14, I'd love to see it in person. Best, John
  22. Hi Druxey, After you cut or file the profile, does it need to be sharpened? And if so, how do you do it? Thanks. Best, John
  23. Hi Ed, At various times in your different build logs you use something which looks like a cross between a rasp and a file. Would you please share the name of the tool and where I might find them? Thanks, Best, John
