G.L.
Everything posted by G.L.
  1. Will you take out the mails of the planks afterwards?
  2. I experience that this method of lofting the strakes is not ideal. It worked well for my shrimper because the planks were maximum half a ship's length long. On this model they stretch from bow to stern, therefore their shape must be more accurate or they wrench or there are gaps between the strakes. I have to try another system. I try it this way: I attach a narrow strip of fairly stiff drawing paper along the edge of the strake that I want to draw. I take care not to wring the strip along the edge of the adjoining plank. Then I draw from the inside of the hull with a sharp pencil along the plank edge the edge shape on the paper. I mark also the stations on the obtained pencil line. The paper can be taken off the model; the line must now be retouched until it is smooth enough to follow the last strake. Now it is again the usual procedure of measuring the stroke width and to displace the widths to the paper pattern. The obtained shape of the plank. The pattern cut out and on the model to check the connection to the adjacent plank. The pattern glued on the plank to saw it out. After the plank was curved above the heat of the paint stripper heat gun. Holding the plank on its position. The plank glued and clamped. Clamps removed the day after Thank you to follow. Thank you for the likes. And thank you for the constructive comments. Till next week!
  3. All the further strakes do not have one straight side, so from now on I will have to use an adapted method. To determine the shape of the strake which is in place, I attach a strip of transparent paper to the model. The paper has to be attached as much as possible winkle-free. I mark the different stations on the paper. Now I rub with a pencil along the entire stake edge , that's how I get a sharp line of the plank side. Now I take the paper off the model and measure station by station the width of the adjacent strake and mark them on the paper. I connect all the markings with a continuous line. Where the connections are too angulated, I round them off. When all the is done I have a paper template of the strake which I glue on an oak plank to saw out and to sand into shape. It is always a bit of surprise to see how the strake is bent. Here you see the strake sawn out and still with the paper template on it. When peeling off the paper template, I take over the station markings on the plank to have a reference to place them on the model. After a check to see that everything fits, I bend the plank (paint stripper heat gun method), ... ... glue and clamp the plank on the model.
  4. Is looking very nice. What is the wood you are using for the planking?
  5. Svein Erik, That is a very elegant Coast Guard cutter, a bit like a steam yacht. I wish you much pleasure with the build of it and just signed in to follow.
  6. Part 4: Planking the hull For me, an apprentice modeler, planking is still a hard nut to crack. Certainly in this model where the planks are 3 mm thick oak and uninterrupted from bow to stern. Mr Van Byelen explains a method in his handout. I have tried it out several times and was never able to make a workable plank, therefore I try to use the method by which I made the strakes for my schrimper. As a non-English speaking it is difficult to explain it, but I will try to clarify how I work. The model will have ten strakes on each side. I start with marking ten equal divisions on the side of each station. I presume that for the top (wale) and bottom strake (garboard) one side is straight, but as those strakes run convex over the stations they do not stand perpendicular on those straight sides and despite their mutual distances are equal on the keel, they are not on the curved strake. To determine those vertical station angles and their distances on the surface of the hull, I clamp a straight lath around the stations with the upper side equal to the tops of the stations and mark the vertical direction of each station (unfortunately the picture is a bit hazy). I take over the station positions and angles on the plank from which I will saw the strake. Next thing to do is measuring the strake with on each station and bring it over to the respective markings on the plank. I saw and sand the plank and I attach it provisionally to the model to check the shape. When all last corrections have been made, the strake must get her curved shape. Therefore I wet the plank and bend it over the heat of a candle flame. After this heat treatment the strake keeps her curved shape... ... and can be attached to the model. Next day day it's up to the other side. The two wale strakes are now in place. They are only glued at the bow and the stern and are therefore very fragile. Now I will place the garboards. It is a similar procedure as for the wale strakes. They have also a straight side were they lie against the keel. I try another system to bow the planks. This time I bow them dry above a paint stripper heat gun. It works a lot faster and better than a candle flame. The starboard garboard... ... and the port one. All the further strakes do not have one straight side, so from now on I will have to use an adapted method. But that is for next post. Thank you to follow. Thank you for the likes. And thank you for the constructive comments. Till next week!
  7. Alexander, You accomplished a splendid work. Your log was a real pleasure to follow. I learned a lot of it, thank you very much. Your boeier model is a masterpiece!
  8. Thank you very much, Heinrich Thank you for the complements Pete. I searched on my memory card for more pictures, but they show all a bit the same. The problem is that this is a retroactive log and that the shown construction stadium dates from about a year ago. The hull is now planked and the garboard notch is filled, it is not possible anymore to make more pictures of it. At the time I probably failed to make a picture of the notch in its totality. Using the chisel with one hand and making a picture with the other is sometimes an awkward operation. The principle is as follows: At each station there is a possibility to check the shape of the garboard notch. The vertical cut with the chisel has to follow as much as possible the direction of the station edge (sketch 1) and the horizontal cut of the chisel must be as much as possible perpendicular to the vertical cut (sketch 2). That means that the shape of the cuts are slightly different from station to station. Between the stations the notch has to be cut in a way that the shape transitions happen gradually. The garboard strake has to fit in the notch along the whole length of the keel (sketch 3).
  9. Part 3: The building board I make the 'building board' as described in practicum of Mr Van Beylen. It is a simple rectangular frame in which the model is fixed with some nails and some small wooden support blocks. A piece of string is stretched to center the stations. With the stations lined up and centered. I add support blocks between the stations for strength. The handy thing about this kind of building frame is that you can clamp it in the workmate in all kinds of positions. With the stations in position, the edges of the inner keel can be chamfered in accordance with the angle of the station bottom. Thank you for the likes and till next week!
  10. The inner stem. Before gluing the inner stem into position, I make the notch for the planking in the stem. I saw also the knee for the stern post. Knee into position. My project is a boat with a centerboard, so there has to be a slot in the keel to house the centerboard. To make the slot I start with drilling some 2 mm ᴓ holes right next to each other to be able to jig saw the slot. The slot is sawn, It still has to be cleaned up with a flat file and sandpaper. Preparing the stern of the boat. Some 4 mm thick mahogany planks glued together on the stern template. The stern sawn out. Gluing the stern into position. I made paper templates of the seven remaining stations and glue them on a piece of plywood. and saw them out. Thank you for the likes and till next week!
  11. Very nice work, Nils. The engine turned out very good. The two men crew gives a real live touch to the model.
  12. Thank you very much for the explanation. All the best for your daughter.
  13. Ab, How do you make the crew for your models? They look awesome.
  14. Part 2: Keel, stem and sternpost I start with making the keel out of a 65 cm long piece of oak. At the front I saw the joint for the stem. The stem, also in oak is sawn out and the joint is checked with the keel. I leave the upper side of the stem a bit longer than needed. It will be sawn in model later. The width of the keel is not the same everywhere. The keel is widest in the middle and becomes narrower towards the ends. I shape it with plane and band sander. I scrape off the angles of the upper side of the keel to make the notches for the garboard strake. A major part of the stern post is sunken. I use a fixed-base router to shape the stern post. Then I saw it out with the fretsaw. The connection between sternpost and keel is strengthened with a pin at the sternpost and a hole in the keel. Checking if everything fits. The inner keel is a four mm thick plank which narrows towards the ends. The different widths along the keel are measured at the bottom of the eight stations. Time to glue and nail everything together. Thank you for the likes and till next week!
