Everything posted by G.L.
I do not quite agree with Peter. I suppose that you prefer to use self-made portholes rather than bought ones, Nils. Brings me to my question: Did you cast yourself the portholes?
The center board case is supported by six metal knees, three at each side. The knees must be 2.5 mm thick on the model. I do not have such a thick brass plate, so I will laminate the knees. First I saw some brass strips of 0.8 mm thickness. I forgot to make a picture of the first step: First I folded one strip in a right angle, L-shaped with two equal legs. Then I covered the two legs of the angle at both sides with a tinned strip. I try to show it schematically: Then I solder the whole knee together by heating it with a gas burner. Filing the knees. Drilling the nail holes. The six knees for the center board case. The metal knees stand on wooden floors. Between the keelson and the floor piece there is a small gap for the smooth flow of bilge water. Thank you to follow. Thank you for the likes. And thank you for the constructive comments. Till next week!
HMS Enterprise by AlexBaranov - 1:36
G.L. replied to AlexBaranov's topic in - Build logs for subjects built 1751 - 1800
Alex, I agree. -
Thank you for your answer Alex. That is probably what you mean by 'using technology and vintage style' in your first post. It looks very, very nice. -
Alex, A beautiful hull! I am curious how you did build the hull. It doesn't look like a POF or POB built hull, more like a hollow block model. Do you have pictures of the making process of it? -
Thank you Ab, your complement means a lot to me. Planking on a 1/10 scale is indeed not easy. I would like to master the skill so I believe that one of my next projects will be a simpel vessel like a rowing boat on a 1/10 scale to further qualify myself. Thank you for your comment Pete. Thank you Patrick. Just lik you with the Golden Hind, I do my best to improve.
When they will be racing one against the other it will be interesting to see what will be the effect of that difference on their speed.
Part 5: The center board case and center board. Next thing is making the center board case. Here you see the different parts. Gluing them together. The center board case is standing on the keelson with a slot and groove connection. I make the slots in the case with the table saw. The groove in the keelson is stabbed with the chisel. The center board box in its position. Paper template of the center board to glue on a 2mm thick aluminum plate. Sawing out the center board with the jigsaw. I lubricate the saw with some fuel oil. The center board sawed and filed. Fitting the board in the slot. with the center board case...
The hull, released from the board. The excesses of the planks at the transom are sawn off. The surface of the inside of the hull is a bit rough and here and there you can see the traces of the paint stripper heat gun. I crape the unevenness at the inside of the hull away. To reach all the inside curves of the hull, I file a small rounded scraper out of a piece of a cutter blade. The inside is cleaned up. The hull waiting in its new chair for further treatment.
Nice furniture for the captain's stateroom. Bad news for us that this project in a lower acceleration.
- 756 replies
- galleon
- golden hind
The last episode in the smack cross section story is the evaluation of the model during the model discussion of the modeling club last Friday. There the evaluators are much more demanding than my local modeling friends of post 196. The model discussion is moderated by a senior modeler with a lot of experience and a critical eye. The author of the cross section handout was also present (right on the picture below). Before his retirement he was a ship carpenter. My model is thus a bit his spiritual child, he examines it with a lot of attention for detail. In general all comments were positive.
- 219 replies
- smack
- cross-section
The shell is surprisingly solid. I make some supports to hold the hull on its width anyway. Thank you to follow. Thank you for the likes. And thank you for the constructive comments. Till next week!
With an increasingly growing respect for real boat builders, I continue the laborious work of placing plank after plank. Fitting another template. Only one more plank to go at both sides. Port side completely closed. Now filling up the starboard side When the glue dried up, There is glue residue and a lot of unevenness's on the hull therefore I scrape the surface. The I sand the outside with sandpaper grit 080 up to 600. Before taking the hull from the building board, I make a new chair in which I can finish the model. Now it's time to lift it from the mold. I remove one after one the station boards. It is an exciting moment; will it keep its shape or will the shell collapse like a pudding?
Another problem: By the force of clamping the planks, the stern is coming to sit askew. I have to unfasten all the planks from the stern. To make sure that the stern is remaining perpendicular to the keel is make a support to secure it. Once the support is fixed, the planks can be re-glued to the stern.
You are right Druxey. Anyway I managed to plank the gaff sailboat in a more ar less proper way, but it can be done better. I will look for a next project in which I can exercise planking in a 1/10 scale using the information of the articles. It must be a simple vessel like a rowing boat, just to improve my modeling (planking) skills. Thank you for your remark!
Yes Mustafa, that is as least the plan. Next thing to do is making the sails. The reason that it takes me so long is that I first will have to learn to work with the sewing machine. It is my plan to make sails first for my gaff sail boat because they are a lot less complicated. Below you see the model with the paper templates of the sails.
