paulsutcliffe
Members-
Everything posted by paulsutcliffe
NO problem, glad to help, the elm pump definitely goes inside the well, mine rubbed the top of the well as it went down and backwards and also cuts in the side of the mast partner very slightly, you have already cut the octaganol holes ready for the tops so they will slant a little more but should still fit, I placed pins down by the keel as per ed's naiad and had no choice where they came out Regards Paul
- 127 replies
Pandora by marsalv - FINISHED - 1:52
paulsutcliffe replied to marsalv's topic in - Build logs for subjects built 1751 - 1800
Beautiful work marsalv -
Looking awesome, nice work on the framing Regards Paul
- 504 replies
- washington
- galley
I think the elm tree pumps angle backwards and inwards slightly as they go downwards to end behind the mast step and inbetween the step and main pumps at the side of the keel The elm pumps aren't shown on the first profile picture you posted, that I can see Hope that helps Regards Paul
- 127 replies
Nice job though on the planning hakan Particularly like all the c**p behind in the picture ha!!!!! Regards Paul
Hi B E Just read through your log from the beginning, great work on the model and fabulous rigging Regards Paul
- 366 replies
- pegasus
- victory models
HMS Pandora
paulsutcliffe replied to Magnus's topic in CAD and 3D Modelling/Drafting Plans with Software
Awesome -
I have realised that I am following the boat plans from the aots Diana the wrong way round, the first one I did in the background above will now become a rigged display model, the 24ft launch should be a two masted affair and clinker built planking, so I will have to redo that one and make the 26ft cutter with anchor winch at the back All from mahogany so they match the syrius which will look better in the long run anyway I really envy how all you people show such beautiful clean pictures, that last picture of mine looks awful with all the cr** in the background Regards Paul
Hi chuck When will the rocket be back in stock?? Thanks Paul
- 22 replies
- ropewalk
- rope rocket
Hi Rob Those small ports you have mentioned on the counter i don't think are gunports but are for access to the rudder, I am using the Diana book for my Sirius build as well as I only have the nmm plans to work from and the Diana is a very similar ship/time frame, they wouldn't have been able to get a gun back there, ,look at my transom framing and you can see there wasn't much access, hope that helps Regards Paul
