Chuck
Administrators
Everything posted by Chuck
  1. I am sure you can make another. Rich that looks pretty darn good. Those came out great. I know how tiny they are and that makes it even more impressive.
  2. That looks excellent. It must feel good to be making sawdust again.
  3. Capstan experiment one. I got bored and burnt out making inventory items. So I decided to test out my parts for making the lower capstan. I have had the parts laser cut for a while. I didnt take any construction photos as this was just a test but keep in mind this is way before we will actually need it. I am always just a little ahead with the design stuff. So I will make another and document each step. I want to make the center spindle a bit heavier that goes between decks above the capstan drum. So I will tweak that before I make a new one. But what I wanted to show you guys is how I did it. I tried a new design for fitting the chocks into the whelps. Below you can see my very first proof of concept testing to see if I could laser etch notches on both sides of the whelps. It worked beautifully. So all you need to do is slide the chocks in after test their fit. This was a challenge even at this scale because these parts are still pretty tiny. The other parts including the capstan drum are all built as usual in layers on a 1/16" x 1/16" stick to register them. Very similar to the way I designed the stern lantern mini-kit for the winnie. This was a fun mini kit to build and will look great painted or left natural. I will detail its construction in Chapter 5.....sorry to jump the gun. I couldnt help myself. These will be made available as stand alone mini kits in 1/4" scale and 3/16" scale as well.
  4. Cant see why it wouldnt work. Although I prefer to start at the top of the wales. This way, if I screw up and have to shift some of the lower planks it wont be as noticeable.
  5. I am not sure what you are referring to but yes there are eyebolts between the chainplate straps.
  6. Not really....you should be able to buy sheets the correct width already. If you buy an 1/8" thick sheet then it should be 1/8" thick. Although some sizes may not be readily available. If you cant find 5/32" sheets then yes you will have to thickness down from 3/16" thick. Chuck
  7. Funny...I will add one. Its my last vise. I cant seem to quit. Yes, she will have guns. Prototype below. But with the carriages painted red. I havent decided on how many yet. She was supposedly launched with 26 twelve pounders and 6 six pounders. But my research indicates that during the revolution she carried 24 twelve pounders and 8 six pounders. I am leaning towards the later because that is the time period I am building. It also allows me to show the last gunport closed which I prefer and also having 6 quarter deck guns and 2 f'castle guns.
  8. Thanks....indeed it holds a close resemblance. I am sad to say. LOL. It freaks out my kids when they see it. Chuck
  9. Its from shapeways. I just browsed 1/48 scale figures and picked a few. Then a friend of mine painted them.
  10. Well done...that looks really good. You should be very happy with those results.
  11. Jim she looks good!!! I can tell your having fun with project. It might be a bit of wait for the chapter 4 stuff as I am not finished with it myself. I cant believe you actually caught up to me..... Chuck
  12. Sure the lighter one is cedar.....other than the slight color difference they both look and perform the task beautifully. Keep in mind I just took this with my phone. But you get the idea. Chuck
  13. I forgot to mention that I will not be drilling the deck for the masts since there wont be any. I simply painted the circles black on the false decking. The partners are really thick and then there will be the mast coats so these holes will be pretty deep. So it will look nice and neat this way and nobody will ever know. AND they are so deep that if anyone was crazy enough to rig her, that they would be sufficiently deep enough to stick your masts into.
  14. Looks good but that window glazing will get so dusty on the inside and impossible to clean. I wouldnt add it until much much later. No need to do it now at all. I have also just switched to black on the top of the roof after much contemplation. It looks better to my eye and make the fancy rail stand out much more. See the photo below. Something to consider. Chuck
  15. I am not even sure this thing as designed can be built. It is only 8" long. But I basically drafted it exactly like my barge kit. The only difference difference is it will be carvel planked. But I drafted it with frames to be built in a jig just like the barge kit which is 19" long. I must be nuts trying to build it with floors and futtucks. I may change that but I am curious if it can be done. What do you think???? Too ambitious. It will certainly be a detailed almost stand alone kit.
  16. Thanks guys. Yes I am aware of that stove. I am not sure it would fit perfectly but I guess it wouldnt hurt to try. Its a bit a cheat though....especially since we should at least try and build one. Having it all done like that defeats the purpose in my opinion. It doesnt have to be made from scratch but it should at least be made....not just painted and stuck on the model. Just my opinion though.
  17. I am going to use 1/4” wide planks. But for those who prefer a slightly narrower look you can go with 7/32”. They will be 3/64” thick. You will need a few 5/16” wide plans also for cutting the scarph joints and tabbed deck planks every now and again.
  18. I have completed all of the partners and coamings......I can almost start planking the deck now. I forgot one last detail which I will show you guys soon. But here are some pics. The foremast partners are made from laser cut parts and then I added the bolts. I used 15 pound filament for those. Use a #75 drill bit for the holes. You can also see the base plate for the stove. You have a few options with this. I have laser cut a nice base for you. At this time the base was most likely just a large iron plate....but in some cases they used flagstone or slate. If you want to depict the iron plate....just flip it over and paint it matte black. But if you want to show some slate or flagstones, I have laser etched the other side with a stone tile pattern. Simply paint it matte black first but keep the coaming natural. Then use some weathering powders on the tiles to make them only slightly lighter. Leave the etched grout lines (which are deeper) dark black. But use some grays and rust colors to make a subtle stone base. Dont over do it!!! The main mast partners were done the same as the fore mast partners. None of these are glued in position yet but I will be doing so soon!!! Any comments or questions!!!!!!!
  19. Back to the Winnie.... To make the gratings for the gun deck you will need 3 packages of my cambered grating mini kits. I will not be including these in the package for chapter 4 because I sell them in either cedar (less expensive) or boxwood. Both would work and you guys can choose. You will also need the grating jig. One jig should last you the entire project. To start, figure out how many cambered laser cut grating strips you will need to fit the space in your coaming. Only build what you need. For example this grating below on left side needed just seven grating strips in the jig. My coaming were designed so each grating will fit perfectly when finished. So dont use more than the space needs. Then use the supplied strips and press them into the notches carefully. You will notice they will probably be too tight at first. This is by design. You need to run some sandpaper down the strip until it becomes a nice press-fit into the notches. Once again only use the number of strips you need. In this case 13 strips pressed firmly in position... At this stage you should look it over to make sure no grating strips went crooked while you were fitting the batten strips. If they did your holes wont be equal in shape and size. Fix those now using a toothpick if they lean over. Its easy to do. Then paint on some watered down tite-bond. Get it in all the nooks and crannies. Not too thick. If the holes start clogging....add more water. Wait about 2 minutes but not so long that the glue will dry. You want to carefully pry the grating free of the jig before it dries and is glued to the jig!!! Then clean up the jig for the next grating. But you are not done yet. Brush more glue on the bottom underside of the grating. Set it aside to dry fully. Now you are probably saying.... how in world will these ugly dirty gratings look good. Right now they look awful. Snip off the excess from the perimeter and file the sides smooth. Check the fit in the coaming. Then start sanding the top surface. In the center photo below you can see I have sanding that grating only on one side. The finished grating can be seen coming to light. The one on the right is completed. These are cedar gratings by the way. Now should you sand the bottom too? You dont have to.....BUT, I am sure you have seen those contemporary models and have seen how thin they are. I wouldnt recommend going too thin. But it does change the way the grating looks in the coaming. And here are the finished coamings with the gratings in position. ANY QUESTIONS????
  20. Im just really bored with seeing so many Syren kits getting built. Since there is a huge lack of American ships on the market that are any good I figured I would rectify that situation. All you ever see are Syren and Constitution kits being built for the most part.....and the occasional Hahn colonial schooner. Time to diversify as there are so many to choose from.
