Everything posted by Chuck
The molding is cut away....
- 1,784 replies
- winchelsea
- Syren Ship Model Company
Nicely done!!!
Burn it off. Run it through a candle flame quickly! it will be nice and crisp.
I am having trouble following your question without pictures. Try just following the monograph. No need to switch it up. Just read ahead if you need to. it is all covered. Finish up the stern as indicated. I believe you are being too cautious and may be overthinking things a bit. No need to develop a new method as you can see by the many build logs....it all worked out wonderfully. Remember the first time you tried to develop a new approach with the stern? Dont be afraid to finish thing up when its stated to do so. As you may be screwing the pooch down the road. There is usually a reason why I created the order and approach back at the stern and it was to hopefully avoid issues later on. But show some pictures and lets see what you are referring too. Just use the template showing the stern frames and if yours line up you are good to go. Then fair them to the dotted line or even a bit further as shown on the plans... Chuck
Should ship out on Monday …Tuesday at the latest.
- 389 replies
- winchelsea
I think I got mine from staples. A small can.
- 1,784 replies
- winchelsea
You dont have to start over at all... Many folks have found similar issues. Just remove the sill and fillers between the stern frames carefully. Then reshape slightly narrower and glue them in position again. Work from the inside ...out. Closing the gap so-to-speak to reduce that 3mm issue. If you can get it down to 1mm it will be tolerable and not at all noticeable. It wont effect the outcome in the slightest. You will easily be able to shift those stern timbers and clamp them against the top fillers to make up the space. do one at a time until you are done working towards to outside on the offending side. Easy-peasy. If you need new fillers you can cut them yourself or I can provide them foe you. Its a much easier solution and much cheaper solution. Chuck
- 389 replies
- winchelsea
Make sure you fair the outside of the hull back at the stern sufficiently. I am referring to the outside stern frames. You want to have enough space after you put on the transom for the stern window fillers back there. So they leave a nice lip for your window inserts for the false lights on the stern. Hope that makes sense. Most folks under fair and they dont have enough space for it. Chuck
- 389 replies
- winchelsea
That looks lovely. Its starting to come together.
- 43 replies
- Mayflower
- Model Shipways
Frank, welcome to the forum. I hope as a newbie to the hobby you will enjoy it and stick with it. I do want to point out to you however that your build log for the Harvey was removed. Being new to the hobby there is no way you could be aware of this but I must i form you that the Company in China you bought the kit from pirated it from a legit company. They stole the design which is typical of what happens in China. Buying or building or promoting these pirated kits is prohibited here do to the fact that it does unthinkable damage to the hobby and the legitimate companies that prepare these model kits. Please do take some time to learn about the countless Chinese companies as well as a few others in Russia and elsewhere who steal intellectual property. Please read through this topic which should give you an idea what to watch out for.
How the hell do you ship an 800 volume book collection. It would cost a fortune. Yes indeed it sounds a bit sketchy. Doesnt make sense. unless someone lives within driving distance this is just not a very good idea. Especially sight unseen. Take some pictures maybe. I have this bridge….not that one…its a smaller bridge. But its for sale and only in its entirety. Buyer must make arrangements for delivery.
Beautiful...you will never go back to planking any other way. The proof is in the pudding!!! Well done and she looks great. Onto chapter three, LOL. But lets see some pictures of her right side up!!!
- 840 replies
- winchelsea
Nicely done....Looking forward to seeing you at the Admiralty workshop Ben. You should bring the model. I would love to see it in person. Chuck
- 399 replies
- winchelsea
