Remcohe
Everything posted by Remcohe
  1. Congratulations Mark, you have made a beautiful model. Remco
  2. I tried to fix the bite mark with some water Druxey, but unfortunately it's to deep and wide. I can fix it with some colored wax or, we make up a good story how the musket was discharged and hit the riding bitt. I'm with Mark here let's blame the rat Piet one's enough! So here's all painted, blackened and assembled. The wood turned out a little darker than I would have liked, but it will go nicely with all the other mini projects like the wicker basket, cutlery, etc to show off the model. Remco
  3. Piet I really enjoy watching how you are doing this. Your next project could be a fully brass build steam locomotive Remco
  4. Thank you guys. Yes Druxey that is a good trick for dents, unfortunately her little fangs cut the fibers so I nee to fill the gap or go for Greg's story. Might as well throw in the musket as well....... It's a Brown Bess Sea Service Pattern 53.5 inch long musket, making it just over an inch long to match my model. Only dry fitted, brass will blackened and the boxwood darkened with mahogany stain. Remco
  5. Finally I got around to do the redo, and guys I'm mortal too and with the rest of you doing my fair share of redo's every once and a while.... I had a few set backs like the new plank snapping when I was heat bending it, resulting in taking some leave from the shipyard. Tonight I got back and fixed the sheer plank. Eagle-eye Druxey I measured it up and the upper sill is correct, but the run of the planking creates the illusion of the still sitting too low, with the sheer strake corrected it still looks wrong so I'll make some adjustment to make it look optically okay too. My Kingfisher also suffered her first battle damage, it took some small arms fire on the riding bitt's Actually Pebbles took a bite at it while I was not paying attention The bitt cannot be replaced without mayor surgery, so I'll keep her signature om my KF From now on the shipyard will be off limits for my little furry shipmate...... Remco
  6. You make it look like easy peasy Piet. Looking at the picture of the real thing I see you can still make a kazillion parts if you feel like it Remco
  7. Mark, she looks great. At first I had to get used to the angled base you choose but now I real like it. Remco
  8. Oh my, the oiled deck looks wonderful Remco
  9. Indeed a tricky set of parts, but they came out really nice. Remco
  10. Looking good Piet, I can't wait to see the launch tubes finished, but I'll be patient Remco
  11. Good to see you back in the shop Piet. Wow you installed ball bearings right? Remco
  12. Nice! I'll save that picture for the moment when I put my KF up for display and the admiral starts complaining Remco
  13. Thanks. The sweeps were easier than I thought, but the sheer plank not. A pesky little plank to shape as it widens over the gun ports. And when I glued it in place I noticed that it does not run in a fair line over the first gunport (second port from the bow) The last row of planks below it are the source of the problem, so this needs to come off and I'll call for a redo...... Remco
  14. That is really neat to have a cross section of a long boat on your cross section. Remco
  15. The pinnace looks insanely good You'll find clinker planking not as difficult as it looks, do you have the cutter practicum from David Antscherl? Remco
  16. That is some very sweet planking Bob. I bet trimming the edges at the ports was tricky with the sides already painted red. I'd say option 1. Remco
  17. So back on the real topic, I sanded the planking and now I'm in the process of cutting out the gun ports. A piece of sanding paper on a stick makes the process a little easier. The sweep ports will be a different challenge.... Remco
  18. Thanks for the likes and compliments. Piet I will take an order from you, but be aware I will do the assembly on site only So I have a new apprentice in the shop, 9 weeks old Pebbles is taking a real intrest in ship building. She's already very skilled in making small parts disappear, I think that is a sign of a great shipwright in the making In the background you can see progress of planking above the wale. They will be sanded before I add the sheer strake. Remco
  19. Piet, Jan is right if you look at the drawings, she was designed with 3 blades. Of course it could look like 4 if you think it's 4. So no domkop or strike two here if you ask me just lucky as you only need to make 6 blades Remco
  20. It's a joy to watch Bob, I really like the details you added to the deck and leaving most of the planking off to show this detail. Remco
