Remcohe
Everything posted by Remcohe
  1. Thanks all for your kind words. You are welcome to come over and cook a meal on the stove. I've been busy with a side project, inspired by Geatans tool drawers I decided to rebuild one of my tool cabinets and upgraded a 5 drawer Ikea cabinet to a 9 drawer tool cabinet. After that is was time to add more planking (more than I had intended before I started on the hearth. And making bulkheads. Here the first is ready with added small strips to act as rebates The bulkheads are made from 20 cm strips, glued and then cut to size. I think this works better than my previous approach by gluing each strip in situ. Along the way I needed to make the upper deck hook to test fit the bulkhead. Remco
  2. Great progress Piet! One of the drawings shows a lot of mechanics in the mine tube but I cannot make out whether it was released from the bottom or mechanically hoisted upwards in the tube. But the drawing suggest lids at the bottom too. Remco
  3. Really great to see you're doing the mine bin. Although I had expected you would make the lid from brass as you did such a fine job on all the lids on the conning tower........(hint...) Remco
  4. Wow Piet what difference with the green on it. I had to get used to it but I like it, it's something else than the usual dull gray (or occasion pink ) Remco
  5. I think we all played with the same thoughts at some point in time, well I did more than once. I find scrapping a part I worked for a day on hard, scrapping a build with an unknown mass amount of hours in it is something else. Very brave man, you won't regret this. And you're absolutely right, it's a hobby and it has to be fun, working on a project you're not satisfied with is no fun. Remco
  6. Nice hinge work Piet, looking at the pictures it's easy to forget how small they actually are. I guest if you used the 0.5 mm tubes, the hinges would have looked to flimsy. Remco
  7. Maybe seal the stain first with minwax poly before gluing? I had the same issue with my first bottle of stain. It looks great with the deck slats . Remco
  8. A chart room.... lets's see. look now, Piet's getting carried away already First the chimney, I was looking through my books because these came in al sorts and shapes But fortunately TFFM hinted me to also check my NMM plans and guess what the chimney was drawn in so getting the shape right was easy peasy. (reminder look more on the NMM plans there is more on it than I had thought) The pyramid shape was diver soldered from some scrap pieces, the funnel turned and tapered on the lathe. The floor was added in front of the stove. And here it is ready to be lit this was really a fun challenge to do, thank you Druxey for inspiring me to give it a try. Remco
  9. Hi Piet, so I went to my scrap box only to find out I had scrapped the scrap box some time ago when I sold or threw away all my plastic kits. Of the kits I still have left I could not find appropriate sized handwheels. I looked on the internet and I think you guess pretty good that railway supply's are the best place to look. Sorry I couldn't help you out on this one.... Remco
  10. Thanks guys. Ed, I will make a brick base underneath. My NMM plans don't show additional carlings or pillars so I'll leave the layout as it is. Yes Sir Druxey, soot coming up, I had to make a little fire in the hearth to create this All it needs now is a chimney to the upper deck and then I'll ask permission to call this challenge completed Remco
  11. That's lovely Gary. Pan's are on my to do list as I plan to make some sort of cupboard opposite of the hearth. But only a few, I don't want to turn the galley into a doll house......
  12. Such a torch is good for general soldering, but if you need to do really small stuff you'll need something like this: Remco
  13. Piet, maybe it's an idea to look for a simple PE set to add details to the gun or scavenge a 1/48 plastic artillery kit for parts ? I'll have a look in my scrap box for you. Remco
  14. Christian, based on what I know probably a brick hearth or a Brody style stove, but not a real Brody stove. Sure Gary, I'll start taking orders The pots are tubes turned on the lathe to give it a small rim, bottom and handles silver soldered. I made a smaller fish pot for the stove. Work began on the doors fitted to the sides of the stove, hinges and locking mechanism works, I think they look a bit heavy for a simple door, looks more like a safe door. Have to think about this ..... Grant, remember the wicker basket... Remco
  15. Wow thanks guys! It's really fun to build this little stove, much more than I had imagined. Now I understand why people build small buildings from individual brick, one ought to try once. Tony, I think a simple stew would be appropriate. Gee Rusty you're tough to please So chimney added, time to make some pots and pans.... Remco
  16. An other trade to master, stone masonry ... I cancelled the stones I had ordered and got a rubber mold from dioramadebris.co.uk instead , now I can cast my own bricks in the color I want. First I made a big batch with slightly different colors (plaster & pigment) Then I had to find a way to make the mortar. At first I glued the sones with thin paper sheet in-between to get an even spacing. I had planned to use sculpey to make the mortar but this doesn't stick to plaster :-( So I had to find an other solution, from the DYI shop I got a pack with powder mixed with water this is used to fill holes in walls, as this dries in just under 1 hour it looked good, but this didn't stick to the plaster too :-( So I mixed it with titebond and pigment and this was a working formula. The surplus removed just before it dries and with a wet brush I softened the flushing. At this point the chimney needs to be made, I'll make this from brick and not steel like my original plan. In the two holes two big cooking pans are fitted. The square hole's on the sides will get a metal hinged doors. Opposite to the hearth I'll make a pantry with different kitchen utensils. I must say it's really time consuming to make but this is really a lot of fun to do. The admiral is complaining she didn't see me all weekend :-D Remco
  17. Your stove look tremendous Sir. Lovely display of metalworking. Remco
  18. Hi Alexander, Hann is correct my NMM plan also shows the drop in hight on the deck plan. But I noticed this too late and the deck was already installed, I'm not going to tear this out as long as all you guys at MSW don't tell anybody about my mistake. I followed the deck plan from TFFM and the layout of the hanging knee's that's why there is no additional hanging knee at the bow. Remco
  19. Ok , I accept the challenge Mr Druxey......... So first I need a plan to work from. Based on what I found researching the hearth I drafted this, no grill on the opposite side I guess as the hearth stands agains a bulkhead. Comments more than welcome! Now how about making it from real bricks.... First a little testing with dummy wooden bricks to see if this could work. Woodglue tinted with pigment to give a mortar look. Not quite satisfied with that its to thin to make a real layer... need to think about this, maybe thin strips of paper to make the spacing between the bricks first.. This could work so I ordered some ceramic bricks from a modelshop, now all you guys have to do is wait until they arrive.... Remco
  20. Well Druxey let's see what song this Swan is going to sing over the stove.... I might make an early brick type galley to see how it looks and decide then. Between looking at stoves, hearths and all that comes with that (does give an appetite seeing those big grill's...) I dry fitted most of the upper deck beams so now I can sart working on the bulkheads on the lower deck. Remco
  21. Glad to be of help Gary, the table with the stove's dimensions is quite comprehensive. Jan, I added a picture of the plan, in the middle you'll see two beams just above each other. Thanks Mark, you're so right. I guess the positive side of our learning is that now we know how it should be, it's just that the model is one version behind our current understanding. I guess the only way to overcome our agony is to build less time-consuming projects like ship's boats. Then making a second one is just a matter of weeks. Remco
  22. Nice Ben you'll be treated with hours of fun. Remco
