Everything posted by Trussben
I'm sure your stove will turn out superb. Ben
- 1,449 replies
That's a beautiful figurehead Danny, Janos did you proud. I think I will be getting a commission done for my Pegasus figurehead as I'm not a carver either. Ben
My Arm is getting sore from the sanding but one side is pretty much faired, now to start on the other side ben
- 889 replies
Thanks Chris! Greg - I find I can " hear " it better than I can feel it! The sanding block ( 80 grit ) makes a note when I'm there! Anybody else do this by ear?? Maybe I'm just weird! Not the first time this has been true, as an engineer I've worked on a lot of equipment that I know more about the way the equipment is running from its sounds and the vibration I can feel through my feet and hands. Ben
- 889 replies
Hull fairing well under way, if you look close you may be able to see the pencil marks that I am using to look for high/low spots. Ben
- 889 replies
Thanks Augie, Greg - I have noticed some movement over the last two weeks since we rapidly went from hard winter to spring in a short space of time! Hopefully it will normalize. Ben
- 889 replies
She really does look great Augie, you must be proud! Ben
- 2,191 replies
- confederacy
- Model Shipways
Thanks Everyone for the likes. Druxey - Yep the fillers were added at the same time as the square frames, I do see some small gaps here and there which will need to be filled. Greg - the pencil method is what I used for internal fairing and it worked well so I will use it for doing the external. Ben
- 889 replies
Hey all, Well the internal fairing is pretty much completed so I released the hull from the build board, so I can start external fairing and will also help to complete the internal as I can hold the hull in my lap and be able to access parts that the buildboard made difficult. I see a lot of sanding in my future! Ben
- 889 replies
Another addition to the wood stock pile, a couple of billets of nice white Holly stacked on top of my boxwood, Holly is getting really difficult to obtain here in US, So I get whatever I can when the chances arise. I may have some updates to show on Pegasus next week - Ive been working away a lot lately and the sanding and fairing of the inside hull is taking quite a bit of time to get really good. ben
- 889 replies
Meet Your NRG Directors and Officers
Trussben replied to tlevine's topic in NAUTICAL RESEARCH GUILD - News & Information
Always nice to put faces to names, I met a couple of you at last years conference and commend you all for the work you do with the guild. Ben -
Scroll saw operation
Trussben replied to bigcreekdad's topic in Modeling tools and Workshop Equipment
Hey guys, A scroll saw is just another saw, same rules apply. Blade selection all comes down to what material and how thick it is. Druxey hit on the head, 3 teeth in the material is a good rule of thumb. Also practice with speed of saw, speed of feed and blade type. Cutting basswood compared to boxwood is obviously a different thing. Blade types like reverse, ultra-reverse, circular all give different results. It's just practice guys, horses for courses. Take the time to learn your equipment and how it performs under different conditions. Ben -
Nice Grant, I need to make spales too when I start work on Pegasus interior, thanks for the reminder. Ben
- 456 replies
- finished
- bomb ketch
Well done Jack, we all have that moment when the hard work actually pays off, look forward to seeing all the frames done. Ben
- 60 replies
- granado
- bomb ketch
