Everything posted by Ian_Grant
Interesting. Are you still actively using your Malabar? I tried to interest my son and nephews years ago, with no success, and mine has only seen water once since - I got the notion to relax with it at the cottage and she sank stern first before my eyes! The little block of wood glued in to support the rudder post detached from the hull after 40+ years and water poured in. Fortunately I was able to snorkel out and find it on the bottom. The RC set worked after drying in rice but the battery was not happy. Fond memories. I guess there's little demand for these winch products now? Young people playing video games instead? 🙄😭
- 56 replies
- Colin Archer
- Radio
Hi Doug; Nice boat with the barquentine rig! Do you have just a couple of yards on the foremast braced and the others follow? I agree with Reggie about the Williams book. I have one and it's a good read with many helpful drawings. I never heard of "standing" torque; sounds the same as "stall" torque: the torque at which the winch will no longer pull in, but will resist being pulled out, if you will. Hitec quotes 1.8A as the current drawn by a stalled 785HB. Regarding the 785HB, Hitec specs its max torque as 153 oz-in at 4.8V; 183 oz-in at 6.0V. They never list nominals, only maximums. 😏 I cannot find a drawing that shows the supplied drum diameter, but judging proportions in the drawings I think the 1" radius you mention is the diameter of the outer flanges. The actual winding surface is the smaller circle within the larger one, meaning the "pull" with the supplied drum will be greater than 7.6lbs, perhaps about 9lbs. Just as a brief intro, there are two types of sail servos, drum winch and arm. A drum winch has the advantage of constant torque no matter the length you are trying to pull in, but the problem of the line perhaps coming off the reel and tangling if you try to ease a slack sheet. A sail-arm servo has as the name implies a long arm at the end of which you get a lot of movement (like 765HB below). The advantage is that you never get tangling problems if you try to let out a slack sheet; the problem is that the longer the arm the less pull you get. Hitec used to have a "mega sail arm" 815BB with 300-350 oz-in to provide more torque than a 765 but it seems to have been discontinued. Frankly I don't understand this as my old M-class yacht with 800 sq.in. of sail needed that old 20lb winch; you could hear it working hard if trying to pull in the sheets to get close hauled in a strong wind. Don't know what your sail area will be on your CA but you should figure an estimate and compare to the 785's capability. Also does the 785 have enough range for your sheet movement? If not you need to rig the sheet in a way which doubles the total range, but halves the torque. The Williams book goes into all this. The book shows many systems with drum winches pulling back and forth on a continuous loop around another free-wheeling drum, with sheets attached somewhere along the loop. This eliminates tangling at the winch since the "primary" loop is never slack, and gives maximum possible pull at any position. Great idea! But you need the space to contain the potentially long loop. https://hitecrcd.com/products/servos/analog/boat-analog/hs-765hb/product What is a crawler? HaHa!, I was asking myself the same thing a year ago when looking at ESC (Electronic Speed Control) units with the notion to modernize my old WWI battlecruiser from the 70's. Crawlers are RC models of off-road trucks with huge wheels that are raced (?) over rocky terrain and I guess have winches just like real trucks. Looking forward to seeing your CA on the water! Keep up the good work. Ian
- 56 replies
- Colin Archer
- Radio
Nice looking planking job! Out of curiosity, what sail winch do you plan to install? My old sailboats are from the seventies, reliant on a winch of the times which has 20 lb pull but is about the size of three hockey pucks......
- 56 replies
- Colin Archer
- Radio
.... or perhaps the word is just "stubbornness" .... 😏
- 536 replies
- Quadrireme
- radio
Thanks Michael, that's very flattering coming from someone whose builds I admire tremendously! Just had our replacement pool installed today so I'll be all set for initial water tests..... 😉
- 536 replies
- Quadrireme
- radio
Thank you Botra; I noticed you were a new follower. It's about to get very interesting..... 😮
- 536 replies
- Quadrireme
- radio
Marc, Don't know how you find all this great info! I browsed through his belaying plans and he, perhaps not coincidentally, has drawings for many ships of which you can buy plans drawn by Harold Underhill. I think this is the guy who drew my Preussen belaying plan. Great find! 👍 Postscript: I did some screen captures and when I magnify the image the belay names are illegible. I imported to "paint" ...... is there a better way?
- 1,508 replies
- Le Soleil Royal
- Heller
I looked through Heller's drawings again. I see what Ferrus is saying - one of the large drawings shows the two mainstay links becoming one immediately behind the foremast, and also the knighthead is further back than I thought. From what Anderson said I had pictured the collar ending further away from the mast, and the halyard tackle passing up immediately behind the mast and through the collar loop. But this would mean a VERY long collar. So I vote with Ferrus and Henry now. Sorry to have brought up this whole digression. From now on, I'm 🤐
- 1,508 replies
- Le Soleil Royal
- Heller
OK, I'm a little confused about this interference of foreyard halyard and mainstay. According to Heller the mainstay splits around the foremast which is in agreement with Anderson for the first half of the 17th century. He says the collar was long enough for the deadeye or block on the mainstay to lie abaft the foremast (pg 100). So we have a stay rope passing each side of the foremast. It seems to me that a central knighthead for the halyard makes sense since the tackle from the halyard block to knighthead is then in the "shadow" of the foremast. Doesn't moving the knighthead to one side mean that the stay on that side will then interfere with the tackle? Note I haven't built this thing yet so I may be talking out of my a*s here......
- 1,508 replies
- Le Soleil Royal
- Heller
Nils you are moving very quickly! Looking great!
- 330 replies
Sorry to disappoint, but she will not be planked except maybe the deck. Hull just painted and epoxy resined inside for strength and waterproofness, if that's a word. As a planked deck would be a LOT of work I'm thinking of trying a painted plank deck using various tones of dry brushing. Not sure.
- 536 replies
- Quadrireme
- radio
Glen, I'm excited to hear that! No doubt you will astonish us all again with another imaginative build.....👍
- 536 replies
- Quadrireme
- radio
Don't worry, no rank amateur could produce the SR you 🫵 are bringing to life! 🤙
- 1,508 replies
- Le Soleil Royal
- Heller
What an incredibly immaculate build! Flawless even in the merciless eye of the camera .....
Really Bill, at this point I would not risk it. As I recall the transom plastic is pretty thick and as you say you might damage your balconies, or the gallery floors you added. Stick to your "officers only" story. 👍
- 1,508 replies
- Le Soleil Royal
- Heller
Beautiful, just beautiful, Bill! Regarding your stern view though - does it make sense to have doors between the stern portion of the galleries and the side portions? I believe Berain's picture showed no grid here, implying just an opening. Sorry to bring it up at this late stage......feel free to tell me to SFU.....🫢
- 1,508 replies
- Le Soleil Royal
- Heller
Looks great! There's nothing like scratch building.......
- 330 replies
Thanks! Yeah, I bandsawed the little bracket shape across the end of a 1" wide piece of cherry, then had to slice it into 3/16" thick brackets which gave me four pieces. Repeat. I at least had the sense to glue the inch wide bits onto some scraps for handles before using the saw! Thinking more, I might just try it on water with one mechanism. That should be enough for a go/no-go on continuing the build. Fingers crossed.
- 536 replies
- Quadrireme
- radio
Took a while to recover from our trip but I finally started on the galley again. Added the external keel, faired into the stern post, and trimmed the stern post to suit the hull. Added the outriggers for the 2nd row of oars. Plan now is to fill/sand the hull some more, then get epoxy resin on the inside and some form of protection, probably spar varnish, on the outside lower hull as a base for painting. But before adding decorative trim or building the hull above the outriggers and the decks, I want to test it on water to verify it will work, even before bothering with steering platforms and twin rudders. Thus, I need to build the second mechanism then install both. If it actually does row along then I will proceed to the finish. Here are some pics of the current state. Those little brackets under the outriggers were a bit unnerving to slice off on a 3HP table saw even with a thin-kerf blade and a zero-clearance insert. I see now why wood model builders buy Byrnes saws ..... 😀 By the way, I got a new laptop with Windows 11 .... why do all the smiley face memes look so evil now? Or is it just a setting I need to change?
- 536 replies
- Quadrireme
- radio
