Posts posted by Baker
After washing with water and soap, a first layer is painted.
further built.
Further painting is done by cannon per cannon.
First the Pak. Dry brushing with light gray, and further applying colors.(Not ready yet)
Next to a figure, an immense anti-tank cannon.
Hard to handle
Hard to camouflageBut probably very effective, when a tank was hit ...
Thanks for following
- hof00, GrandpaPhil, hexnut and 4 others
7
On 9/25/2019 at 6:25 PM, popeye the sailor said:
amazing how identical these frames are
Yes in real the 2 russian carriages were identical. Saves time in development and production.
The German version was actually a quick emergency solution.
How do I build an effective anti-tank gun against the Josef Stalin tanks that are becoming more and more numerous on the battlefield?
Take an existing barrel and use captured Russian material.In the meantime, construction continues.
Drilling out the barrels
This part is cast so badly that plan B is needed.
The 15.2 cm will be built in transport version, and is provided with canvas protection.
The 3 cannons are built as far as possible before painting.
- Canute, popeye the sailor, lmagna and 3 others
6
Hello from Belgium.
And
These are to absorb the recoil during firing. They are actually 4 heavy metal pins that were driven into the ground.
This way the cannon remained in place during the firing (a cumbersome way to set up a canon).Other versions have a kind of spade directly attached to the back of the legs of the
carriage (setting up is of course much faster). see the pak 40 belowThe carriage in transport arrangement also has these 4 pins. attached to the sides of the legs
(foto from internet)
- mtaylor, popeye the sailor, Canute and 1 other
4
Beautiful and accurate work
well done !!- EJ_L, mtaylor and Hubac's Historian
3
My idea
because I then think I could build it better
I have this problem with every model that I build. Once it is finisht, errors pop up.
I learn from my mistakes and try not to do them anymore in the next model.
How much of the material could I reuse if I tear it down?
That depends on how much you want to change.
And how much would the new material cost, approx?
Dont now, but buying a new kit and starting over is probably the cheapest, I think.
Greetings,
Patrick
@ GL
I prefer, as good as possible, in a lower acceleration.
It remains a hobby for me.
@ Michael
Yes, the idea is to build a model with full rigging and sails.
Thanks for comments and likes
- GrandpaPhil, hexnut, mtaylor and 2 others
5
Started with the cabin under the poop deck.
This was the captain's cabin. There is one door for access and 3 small hatches.
A table with 6 chairs is provided.
At the back there is a couch that can also be used as a bed.
Am actually not satisfied with the finish of this cabin (interior and exterior).
Given the long buildtime of this model, I struggle to stay focused
That's why I restarted with military 1/72 modeling ( build log in the shore leaf topic) and later the Bounty project will be restarted again.
Building on this model will temporarily be a bit slower in the near future.Thanks for following
- mtaylor, G.L., GrandpaPhil and 9 others
12
Ace model is still "alive and kicking"
But these 3 models are no longer in production.
Every year there is an exhibition of IPMS in Hoboken (Belgium). With a wide range of kits for sale at fair prices.
So then it's "shopping time"- Canute, popeye the sailor and mtaylor
3
This is the build of 3 cannons on a 1/72 scale
The models are from Ace from Ukraine. They produce well detailed models, not always easy to build. but always a pleasant addition to the collection.These models are the so-called short run method. A mold is made, and with this models are made until the mold is worn out.
Why build these 3 in a serie, it saves me time and especially thinking about the construction method (once you understand how a certain component is built, then the next 2 to build are easy).
We build 3 cannons from WW 2 (All have the same carriage).
A 122mm A-19 from Russia https://en.wikipedia.org/wiki/122_mm_gun_M1931/37_(A-19)
A 152mm ML-20 from Russia https://en.wikipedia.org/wiki/152_mm_howitzer-gun_M1937_(ML-20)
A 12.8 cm Pak.44 (K81 / 2) from Germany https://en.wikipedia.org/wiki/12.8_cm_Pak_44Step 1 opening the boxes. Most parts are identical. only the parts for the barrels are different.
The first part is ready
The legs of the carriages are now being made.
The first piece is a bit of a puzzle. Drawings from some plastic models are sometimes as simple as those from wooden boats....to be continued
congratulations.
You have a nice collection -
The best way to get answers to these questions is to start a build log.
- JeffT and pontiachedmark
2
As always
Beautiful work and nicely detailed.- EJ_L, popeye the sailor and md1400cs
3
Boeing B-17 by popeye the sailor - FINISHED - Lindberg - 1:64 scale - nose art edition
in Non-ship/categorised builds
A small story that happened in a big war
In 1943 these fell down from the sky (emty 0.50 casings).
They were large planes, where other small planes flew around...
That's the story my mother always told.
My mother witnessed a fight between American B17s and German fighters. And the empty shells fell to the ground next to her.
All this happened above Sint Gillis (west of Antwerp). No plains were lost on that moment.
