Baker
Posts posted by Baker
  1. Hopefully this info will help you further,
    The lengths and widths of the planks varied during this period
    More info can be found in my log of the Golden Hind (approximately from post 50)
    Following the information found the planks were 4.2 to 5.2 meters long
    The average  thickness is 7 cm
    The width varied between  36 and 48 cm
    The widest planks were located at the bottom of the hull
    Greetings,
    Patrick
  2. Hello everyone,
    Update.
    Grooves are made in the channels.
    marking with a pencil
    IMG_20190606_191749.thumb.jpg.c73e8881fe1358a78ebb501141fff298.jpgIMG_20190606_191934.thumb.jpg.f4b09889f2ea19cf1bf4f12c3091b7e0.jpgIMG_20190606_193325.thumb.jpg.de6ada8cf8ef74016e43386ebe889eb8.jpg
    I think (hope) that they are big enough.
    To bring some life into the model varied personal items will be added. "Bags" of crew members, small barrels, a crate with material for each cannon and a crate with ammunition for the present cannons.  Gunpowder was not stored near the cannons for safety reasons.
    An example how it could be
    Bags are of wood and tissue. Barrels of wood and rope
    IMG_20190608_140117.thumb.jpg.fd2e2edc11d8c9aac4362b4a11c0041f.jpgIMG_20190608_140552.thumb.jpg.291b13f9739e5d9540e6f85a183680ba.jpg
    Crates an varied ammunition
    IMG_20190614_183204.thumb.jpg.c16c9fbf88470958c2e3949d1c136746.jpgIMG_20190614_210915.thumb.jpg.5ce1b6a00b081ed4d0aaafd0db3202ff.jpg
    Cannons (3) are placed. I still have to make 1 cannon. This will be a different type,
    Current state
    IMG_20190615_185838.thumb.jpg.661e58ca22a9187d9968cefa482a8022.jpgIMG_20190615_185911.thumb.jpg.f0d70876c24ba13eb673fbb50bb94f21.jpgIMG_20190615_185935.thumb.jpg.aef6a3312d4d6753f8b6bcb9880c163b.jpg
    Thanks for following
  3. Thanks
    We have a large garden. Nice, but sometimes with a little too much maintenance work ;)
    before I glue the cannons on the rearcastle. It is probably best that first make grooves in the channels where the deadeyes come.
    The intention is to get something like this.
    As is quite the case with this build, I first had absolutely no idea about what, how much and where to place them. So first i have to find out what we are going to do.
    On average there are 6, 7 or 8 deadeyes for the main mast.
    At the beginning of the 17th century there were apparently already rules to determine the length of the masts.
    But i obtained confusing results with this method.
    I continue with a sketch by Mathew Baker.
    this gives the length of the lower part of the main mast is 1.77 times the beam.
    IMG_20190605_184359.thumb.jpg.c784c77fc83495d8878f8ddb3f2ab65a.jpgIMG_20190605_184344.thumb.jpg.7f1bd561ed81ef12452e816f18244ea6.jpg
    The "test mast"
    With improvised standing rigging (8 deadeyes). This setup seems ok to me. She will stay that way for the time being
    (i think about it first and then make the grooves in the channels)
    to be continued
  4. Due to other activities (painting and gardening) there is little time left for modeling.:(
    I made 2 doors. These doors are made in the same way as the doors in the stern and the beakhead. The only exception is that these doors are only finished on one side because the back is not visible.
    IMG_20190603_072638.thumb.jpg.99eec89c83349a187ffd8bacc8753c7e.jpgIMG_20190603_072725.thumb.jpg.78d06bba6eb3c5b2c7a3acfe37866196.jpg
    I also attempted to install the LED lighting. Each LED light is "hidden" by a simple lantern.
    I am not completely satisfied with this solution, but once the ceiling is installed it seems pretty ok. And there is sufficient light.
    The intention is to make the hatch of the helmsman removable and provide power to the LED lamps at this location.
    IMG_20190531_184719.thumb.jpg.a577093f5d4daa420b634f0a3d0e2892.jpgIMG_20190603_072622.thumb.jpg.5fc429880dd14233f91f23a2bf826af2.jpgIMG_20190604_150404.thumb.jpg.dea98e20736d52d15e1e5b938e9461c2.jpgIMG_20190604_150422.thumb.jpg.b4c6fa0c43ed16adc6db0e4ace1f4cea.jpg
    Thanks for following.
  5. 3 hours ago, G.L. said:
    Good solution. Je moet er maar aan denken!
    2 hours ago, Barbossa said:
    Errors ?
    I didn't notice.
    Wonderful work
    Thanks,
    It was my lucky day.
    The square parts of the bars measure 3 mm, the space between 2 frames is 9 mm. And there could be 2 bar behind each other between the frames.
    So just enough room to place the 6 bars of the capstan.
