Posts posted by Baker
Ratlines
what do you prefer to hold in your hands?
a tarred rope.
or one without tar. -
- king derelict, mtaylor, CDW and 6 others
- 9
Thanks Ab, this is much appreciated.
The further build up of the rear castle
Frames 6, 8 and 10 are laid out using the laser
All frames are in place
Started with the cannon ports
And planking of the stern
Some filler pieces are first atteched
sawing...
On almost all drawings of the Antony roll a beam (wale) can be seen just below the opening for the tiller
Follow the drawing as much as possible
Result
An oops moment. Where there should be a hole for a cannon are frames.
Time to bring out the isopropyl alcohol. Soak off the glue of the framing and do it right
Thanks for following
- mtaylor, scrubbyj427, Louie da fly and 17 others
- 16
- 4
Complated shape of hull 🫣.
but, i have confidence in you that everything will turn out well 😉
- mtaylor, Scottish Guy, GrandpaPhil and 1 other
- 3
- 1
Much, much better than my attempt. 50 years ago 😉 👍
Great work.
- mtaylor, Old Collingwood, Canute and 1 other
- 4
Very nice work 👍
- The Gimps Chimp and Loracs
- 2
11 hours ago, GrandpaPhil said:
Everything is a lot more square than it appears in the pictures.
Is that meant for me?🤣
(Rember my comment on your Revenge build)- GrandpaPhil, Canute, Javelin and 2 others
- 5
10 hours ago, Snug Harbor Johnny said:
One can always cut or trim off extra wood as needed, but its often troublesome to add back on.
5 hours ago, BANYAN said:Oh so true!
cheers
Pat
4 hours ago, druxey said:You don't have a wood stretcher in your workshop? Pity. Neither do I.
A long time ago I sawed a plank too short.
I sawed off another piece of this plank, and it was too short again....🤪
Lesson learned 🫣Haha
Very beautiful models.
- mtaylor, Keith Black and Shipific
- 3
Thanks for the positive comments and likes.
Further with the reconstruction of the rear castle.
Sawing "beams"
Preparation.
The first frames.Take into account the cannon ports of the upper deck.
All frames have been placed. The drawings of the Mary Rose were followed for the approximately correct position.The chaotic inside has also been cleaned up a bit. (not exactly the same as the original, you won't see much of it later anyway).
The plywood pieces are the basis for the cabins.
Result
Next: port side
10 hours ago, GrandpaPhil said:
Would it be safe to assume that the seats of ease in a late 16th century English ship would have been in the usual location on the head grating, on either side of the head?
For me, yes.
10 hours ago, GrandpaPhil said:And that each one would have seated two?
For me, no.
Just one on seat on each side.
- Canute, GrandpaPhil and mtaylor
- 2
- 1
Great work.
Your buildlogs are always nice to follow.
- Glen McGuire, Louie da fly, Knocklouder and 1 other
- 3
- 1
Thank you for the explanation.
Very nicely done again 👍- Canute, thibaultron, mtaylor and 2 others
- 5
Hello from Perth, Ontario - On to Victory!
in New member Introductions
