Posts posted by Brucealanevans
Added "nails" for the ceiling and decks with mono-filament line dipped in a touch of CA, inserted into pre-drilled holes, then clipped with a flush-cutter.
Stained the interior. To get the used-up look sanded the central "traffic" areas after the first coat of Minwax stain dried and applied another light coat.
Put in the knees and coaming with nails and bolts simulated. For the bolts cut out small circles with a punch from a card colored with magic marker, punched a small hole in the center with an awl, and slipped over a protruding piece of mono-filament line, glued down, and clipped the protruding line.
Now on the the repetitive job of nails for the exterior planking.
- Tigersteve, hexnut, Elijah and 3 others
- 6
Finished the ceiling planking. Had a look at the Smithsonian plans which arrived afterwards, tho, and the interior planking was wider than the 1/4" (6 scale inches) the kit uses. Oh well.
Put the decks in - I cut the deck pieces into individual planks as I didn't like the scribed planking which ended up really highlighting the midline join between the port and starboard pieces. The cuts "lost" enough of the total width that I had to add a small piece to either side to make up the difference. Suggested by the Ships in Scale series. Also some fiddling due to the "drift" of the false keel amidships (see posts above).
All in all tho I'm pleased with how it looks at the moment.
Before I stain the interior I'm going to simulate the decking nails (they were iron nails, not trenails) with holes/black mono-filament line. Since I want to give those a light sanding I have to do it before I put the stain on.
I reinforced the place where the hausepipe hole goes through the exterior planking since those planks were not edge-glued. That's visible between the exterior planks and the ceiling near the bow in the pictures.
The arms chests are just placed on the deck in these pictures. I'll not glue those or the knees in until I've done the staining. I'll stain those pieces individually prior to gluing them in.
Having a lot of fun with the Smithsonian plans (I'd better since getting them was a real splurge) - a real wealth of detail for fitting this boat out.
Interestingly, also shows fascines - bundles of small diameter wood - hanging above the bulwarks to give sailors some additional protection. I'll have to decide if I'm going to include those.
- Captain Poison, coxswain, hexnut and 4 others
- 7
Good work Elijah!
I have the bottom strake to go before I finish the exterior planking. So much 3-4 day travel over the last few (and next) weeks that it's hard to forge ahead.
Are you planning on adding the nails to the exterior in some fashion? The photos seem to show nails rather than wooden pegs. Fresh water boat maybe?
Bruce
I thought I'd share the procedure that seems to work for me for spiling planks for this build, where the planks, due to the scale and the construction of the boat, are quite wide.
I fit a template made from card stock to the upper plank and then mark the laser tick for the bottom of the new plank at each bulkhead on the template. After drawing a smooth line with the help of ships curves through those points, I cut out the template and double check its fit.
I tape the template over an appropriate width plank and trace the edges, then cut outside the line with a knife and smoothly sand down until the line is just obliterated.
I'm soaking the plank and giving it the approximate curve passing it over the plank bender pictured so that it follows the curve of the boat quite closely, then clamp and let it dry. Once dry, some final fitting and sanding, knock off the upper inner edge with a sanding stick, and apply #2 pencil to one edge for the visible caulk. At that point the plank follows the ship and bulkheads quite closely so the clamping is mainly to make sure it's firmly against the plank above throughout its run.
Looks like I can do one strake (3 planks) each morning, and take a bit of time in the afternoon when its good and dry to glue it in place and clamp it so that I'm ready for another the next day.
At this rate (4 strakes each side below the wale) I should have the outside planked in a week or two.
- Elijah, Tigersteve, Captain Poison and 5 others
- 8
Started in on the "easy" part of the planking - the first 3 strakes that are constant width.
Instructions state aligning with the tops of the frames, but at the bow that seems off and the profile plans show an angled taper on the very end of the plank to meet the angle on the bow-piece. Also if aligned to the top the spacing is off according to the template for the bow strake widths. So I elevated the top of the first strake at the bow and will sand the taper on them as shown on the profile plans. Now the bottom of the 3 constant width strakes line up perfectly with the hood template at the bow. You can see this at the far right of the pictures below.
As I prepared to add the wale (which is considerably thicker) I also felt it should stand proud of the adjacent planks by half its width, including, I think, at the bow and stern. So I'm carving the ends to have 1/2 the width fit into the rabbet and the other half lie flush against the side of the bow piece rather than sanding the whole width down to a wedge to fit into the rabbet.
Not sure how authentic that is, but I like the look (potentially).
While waiting for the glue to set I got to work on a display base. The model is wide, and I also wanted to display a period map of Lake Champlain. Consequently I needed 12" in width and lacking full size tools to deal with a plank of nice wood of that width, I decided to take the coward's way out and use a laminated piece of MDF meant as a bookshelf. To elevate the model making clear it's a flat boat and not a waterline model I got a couple of unfinished wood candlesticks and drilled a 1/8" hole through them with matching holes in the base and the ship into the false keel. When inverted, the broad end gives good support to the boat. I'll glue the other end and the 1/8" dowels to the base, and the model slips nicely onto the protruding dowels with the broad end of the candlestick pedestals giving good support without gluing. I'll stain the pedestals with the grey stain I'm using for the interior, which also goes well with the base laminate. The space to the right of the map is where the nameplate will go.
The case I'll be using is wide enough to accommodation the base with the off-center mounting of the ship while still allowing the ship itself to be in or near the middle of the case so that the 14-15" width of the lower yard will still fit well within the case.
The admiral has informed me that this ship will be living downstairs across the room from the shipyard in the "TV" half of the basement room (area visible in part in the pictures below) because there's no more room on the main level.
My next builds better not need huge tall cases - thinking Echo cross section and Confederacy Admiralty model (both on the shelf).
Admiral may be taking a job that will require 50 business days of travel a year attending national and international conferences with "spouse expected to accompany" so my retirement shipyard hours may be somewhat limited if she gets the position. I'm quite certain they're thinking of "wives" since few surgeons of her seniority are women, but what they'll get on their entertainment activities for the spouses while the "guys" are meeting is a rumpled and occasionally grumpy old guy who is not interested in shopping, fashion, etc. Ha!
Anyway, my projects on the shelf (plus Chuck's barge when it comes out!) will likely take me to or beyond the end of my fine motor skills.
Glued everything down.
I put in lateral supports in two sites along the false keel and drilled vertical holes for later mounting. I have a print of a period map of Lake Champlain that I want to work into the base if I can.
Floor boards in the cockpits added as well as a few support pieces for the ceiling planks in the cockpits.
I'm going to go weathered/grunge look with this build. Chose a grey stain for the inside and stained the cockpit floorboards before installing them. I have made the bailing well grungier as you can see in the second picture. I did put some very thin planks at the bottom of the bailing well to represent the bottom planking that doesn't exist in this model. The exterior will have a different stain.
Now I should be ready to start the planking.
I got two books on the Philadelphia from Amazon yesterday with a lot of pictures of the raised ship and the reconstruction. A lot of ideas for super-detailing this build which should be fun at this scale. The exterior planks were nailed and the pattern was not the perfectly aligned and symmetric pattern OCD model builders strive for. I'll probably use black mono-filament glued in pre-drilled holes to represent the nail heads.
It's worth remembering that these were hurried purpose-built ships and fit and finish were not high on the priority list.
I'm also interviewing crew members - likely will use one or two on the ship, including a commander.
- Tigersteve, coxswain, hexnut and 2 others
- 5
Well, I got tired waiting for the replacement piece to arrive, so I worked on the keel, stem, and bowpiece I removed from the incompletely lasered sheet and managed to bring them up to useable form. I still need the replacement piece for a number of other parts, some quite small, that were very poorly laser cut. But I won't need them for a while.
Keel was straight, and putting the bow and stem pieces on straightforward, as were constructing the bow and stem rabbets with shaped and glued on pieces as shown below.
I cemented the floor, and glued the keel to it.
Oh, Oh!
Although the keel was dead-flat, and I carefully aligned the bow and stern to the midline, I didn't realize that in adjusting those two spots, the drag on the middle of the keel from the glue kept it from perfectly following the adjustments. When I test fit the bulkheads, which need to meet the upper edge of the floor exactly, it became clear that although perfect at the bow and stern, the keel "bulged" to port by up to 1/16" midships. I contemplated the old alcohol reversal (on the keel, not me) but such an extensive area was involved I decided against.
This meant that most of the bulkheads had to be adjusted (sand one half, shim the other) to bring each bulkhead on port and starboard exactly to the upper edge of the floor (picture below).
A lot of extra work because I didn't either draw a line off center to align the keel with or check the port/starboard measurement before the glue set and the assembly was nudge-able. That's assuming few adjustments would have been required. At least now I know the alignment with the floor is perfect throughout.
Oh well, it's all good now. Outer and inner faring of the bulkheads was done off the ship following the engraved line outboard and paralleling that inboard, which made the use of a small hand belt sander fixed in a vise possible and a relatively quick job resulted. I got facile with that tool making the Morgan's 7 whaleboats from lifts.
Tomorrow I'll glue them on using the small machinist right-angles visible in the picture, and sand the edge of the floor to match the vertical curve of the bulkheads. The extra work should make the planking a lot easier!
- Ryland Craze, hexnut, coxswain and 4 others
- 7
Kind of a bummer...
sat down to get started with the first pieces - keel, stem, and stern piece - and found the thickset wasn't laser cut all the way thru and cutting the complicated notches with a knife resulted in unsatisfactory accuracy and snapped bits along the grain.
Checked the other thicksets (all ok) and contacted Model Expo thru their website to request a replacement.
Oh well, enforced holiday in the shipyard while I wait. If I had some materials I've ordered I'd use the time to build the brick stove but they're not here yet either.
I'll work on other projects for a while.
Jim, as usually happens after asking for help I found some figures from Model Dockyard that should work with some creative painting. If they're good I may stick one on my Picket Boat #1.
Update: While I was typing above got a response from John Garcia of Model Expo.
Great customer service as always!
Nice. Hope mine looks as good.
- Elijah and Tigersteve
- 2
With the Charles W Morgan safely in her case awaiting only a brass engraved nameplate before moving upstairs, it's time to start a new project (projects?).
Going to start with the gunboat Philadelphia which I've had on the shelf for some time. I need a break from 1/64 fully rigged ship so the Granado will wait for this project to be completed. [note: Granado will wait a while longer]
I'm looking forward to (super)detailing a 1/24 build with minimal straight-forward rigging (at least compared to the Morgan).
I've ordered replacement blocks and line from Chuck, and gathered materials including the 6 part series on this build from Ships in Scale.
I'm not detailing in photos the box contents as they have been covered in a current build log and several fairly recent finished ones.
Will start construction next week. I've been at loose ends in the mornings as that has been my shipyard time through the (long) end of the Morgan build. There is a nice case awaiting this rather wide model (nearly 14 inches) that I had bought years ago for a Victory model I bought but did not build. As my house started to fill with MY completed models I decided to give that ship away to a friend who had admired it. I was tired of explaining to people that I had built the New Bedford Whaleboat, Picket Boat #1, and now the Charles W Morgan but NOT that one.
At the same time (now that I'm fully retired) I'm going to practice Byrnes saw, scroll saw, and mill skills to begin the Echo cross section on some ordered boxwood before I break into the wood included in the Admiralty Models package. These are things I've not done so need the practice for this entry into the shallow end of the scratch build pool.
Thanks Joe
Granado will be next after Philadelphia. I need a break from fully rigged ship and would enjoy a large scale build as a change of pace.
The Echo x-section will be a simultaneous side project going forward. Now that I'm retired I have more time.
Build log tagged as finished, and some photos of the model uploaded to the gallery.
Thanks to all.
I'm going to build the gunboat Philadelphia next for a change of pace, expecting NOT to take anywhere near as long as the Morgan did. Replacement rope and blocks ordered.
While doing that I'm going to spend some time practicing wood/mill skills for the Echo x-section.
I finished the Morgan today!
Put up the last two whaleboats, added some rope coils to the cleated lift lines, and did a small bit of touch up painting. It really is a very busy model, and especially so with any added detailing.
I'll take comprehensive pictures once I set up some good lighting and a backdrop and post them in the gallery.
Now I need to decide on the next project, with the following on my shelf: Confederacy, Gunboat Philadelphia, Mortar Vessel Granado, Echo X-section, and English Pinnace (oof - how did I collect this much stuff while building the Morgan?)
I have an empty full size case since I gave away a Victory model I bought but did not build into which the Morgan will go so the case I got for the Morgan is empty. Which argues for the Granado or Philadelphia, but the x-section is muttering to me from its shelf.
I'll just bask in finishedness for a bit and decide later.
Thanks All.
I like them.
Mounted 3 on the Morgan today. The other 2 go on tomorrow and the build will be finished.
Big moment.
The whaleboats are finished with the content they will have when mounted - oars, spars/sail wrap, and paddles.
Next is to retrieve the Morgan from her case in the living room and mount the boats, hopefully without snapping a davit for the umpteenth time.
So close to done now I can taste it, but will have to wait as we have a week in Napa coming up.
Thanks to all for the comments and likes on the boats. The effort to have the details match the work on the mother ship was really worth it, and was quite fun once the hull carving was completed.
My advice to all Morgan builders - use work on the whaleboats as a break from the main construction so that only the fun stuff remains at the end.
- Pete Jaquith, Tim Curtis, pjofc4 and 6 others
- 9
There is a heck of a lot of scratch work involved in the Morgan build.
I've learned a lot in the 3+ years I've been working on it.
The best decision was to fabricate the rendering furnace from individual "bricks". There's a PDF around the site somewhere with useful instructions.
Took a while but the appearance is really worth it. Working on oars now - drawing 1/32 square boxwood strips through Modelworks drawplate down to scale width. Works a treat. I can even create the handle on these little tiny dowels by carefully working the end for 1/8 inch into 4-5 smaller yet drawplate holes.
Thanks Russ
i like them.
Whaleboats are done. I've had to stop myself from adding a few more details that don't really add anything to the visual impact of these, and I'm declaring victory!
I've put the boats aside to begin working on oars, probably paddle sets, and the spars/sail bundles. I haven't put the eyes for hanging on yet, as I want to make certain the lines hang straight down from the davits, so will customize them for each specific boat's place. It looks like there may be a few mm variability.
Final boat photos below (25 cent piece for scale)
- wrkempson, alde, Mirabell61 and 8 others
- 11
The whaleboats are now done except for the rudders. Today finished the rigging of the steering oar braces, added the steering oar rests, two cleats inside rail aft, and did some touch-up.
I'm not sure if I'll give the boats a coat of white (below the rubbing strips) since I kind of like the weathered and beaten look of the primer coat.
Tomorrow, detailing the rudders and deciding on the rigging of the 2 lines that suspend them in the stored position.
- hexnut, alde, Salty Sea Dog and 8 others
- 11
Thanks for the comments and likes.
I'm having a lot of fun now with these whaleboats. Just how much detail can I cram in? Referring frequently to the plans for the MS New Bedford Whaleboat, with occasional simplification in deference to the scale.
Painted the boats. Added (25) oarlock supports, and made 25 oarlocks out of 28 gauge black covered copper wire by twisting it around a small drill, adding a drop of CA to keep it from unraveling, and clipping off the top of the loop, and trimming the stem. Added them to the oarlock supports in pre-drilled holes. They look good and in scale. A touch of black paint to hide the copper where clipped.
Now I'm adding the steering oar support, which is actually a bit complicated as the rope goes thru the stem (which I had to build up to be big enough for a transverse hole) and has a small closed loop at the end. The loop is attached to a lanyard which ties off on a cleat on the lion's tongue aft of the loggerhead to allow the loop around the oar to be tightened. Will post more pictures when that is done.
Next up will be the (suspended in storage position) rudders, which also require either one or two (depending on how compulsive I feel) lines. I have cut and painted the rudders, but not added gudgens and pintels yet.
Approaching the end of the boats themselves - probably another week. Only additional detail will be a steering oar rest on the port rail of each boat.
Then I start making oars and sails wrapped around spars.
After review of the literature, and some opinions from experts here, I will not be adding the stuff that wasn't put in the boats until they were getting ready to launch them, including line tubs, implements, casks, etc.
I've finished the interiors of all five of the whaleboats. After completing the detailed thwarts, I added the "metalwork" for the mast support and "hinge". These were cut out of cardstock and painted. Rivets were simulated with pinpricks from the reverse side prior to painting. The hinge pieces on the thwart were wrapped around a small piece of metal wire prior to painting. A long small eyelet was used to simulate the centerboard pull.
Overall I'm quite happy with how these look. The detail work after the thwarts were stained and glued in place took about 6 hours.
Next up are the lion's tongues and the loggerheads. Once I got past the carving of the hulls this became fun again.
- tarbrush, Salty Sea Dog, Cathead and 6 others
- 9
Gunboat Philadelphia by Brucealanevans - FINISHED - Model Shipways - 1/24
Prior to staining the exterior, I've been working on placing the nails for the exterior planking. These were iron and clearly visible, as on the modern reconstruction.
Drilled all the holes with a pin vise, slightly widening the entrance with a sharp awl.
Placed short pieces of black mono-filament held with the needle nose pliers (tweezers don't work due to twisting or "snapping away" of the line piece) illustrated after dipping the end in a drop of CA. Then cut each nearly flush with the flush cutter illustrated. The second picture shows a row of holes, a row filled with the mono-filament pieces, and a row after clipping.
After some sanding with the grain of the planks the look is pretty good (last picture). They will be somewhat less prominent after staining of the exterior.
