Hubac's Historian
Everything posted by Hubac's Historian
  1. Hey Dan, These were photo-etch pieces. I’ll show you what I mean at our ZOOM meeting on Tuesday. Leading into Labor Day Weekend, I realized that I would need to cram-in a ton of hours, if I had any hope of getting where I wanted before the Joint Clubs meeting. And so, my wife and kids went off to CT to stay poolside, with family, and I got to work. The primary objective of the weekend was to erect the forward bulwarks. I gave the lapping joint of each bulwark piece a third going-over to ensure absolutely the best fit possible. Unfortunately, it cannot be avoided that the part will always be under tension, as it must bend significantly to conform to the run of the hull. Anticipating this, I had affixed a styrene tab at the point where tension is greatest. My glue plan was to cement a welded bond along the rabbet with liquid styrene cement, but also to apply CA to the additional tab for a contact bond that would assist the tweezer spring-clamps that I bought for this purpose. Where the bulwark joins the beakhead bulkhead, I similarly used styrene cement below the forecastle deck ledge, and a spot of CA above the ledge. There was simply no good way to clamp this corner, owing to its extreme tumblehome, so I used a tape clamp to assist during drying. First, I put some blue tape down to protect the deck from any errant glue drops: I also applied two layers of blue tape to the clamp jaws, as these particular spring clamps apply a really strong bite onto the material; I was hoping not to mar my paint. For better leverage with the smaller clamps, I made up small styrene clamping cauls that hooked beneath the wales to which they were taped in-place. As with any significant glue-up, a dry-run really helps steer you away from potential pit-falls; before making the cauls, I found that the small clamps only had a tenuous grip on what is really a very shallow lap-joint. With only a few small gaps that touch-up paint will fill, I ended up with really tight-fitting joints and enough small squeeze-out to convince me that there is a strong welded bond along the part’s entire length: The relative mass of the model is becoming apparent now: I will say that while the skid segments lined up near perfectly, I will still have to fill a few gaps, here and there, with sanded shims of styrene strip. This is not a big deal, and I prefer to use plastic, rather than putty, wherever possible. Also, the squeeze-out is not a major chore to clean away. I have a purpose-ground #11 blade that works like a semi-sharp glue chisel to scrape away the excess. Now that the bulwarks were up, I could install the gusset pieces that serve a dual purpose: they re-enforce the lap-joint by increasing glue surface area between the deck and the bulwarks. Also, they will eventually serve as mounting points for my deck beams. After scribing-in and glueing, the bulwarks became notably stiffer: Unlike the lower decks, this time I thought to black-out these gusset pieces, as more light will penetrate below these upper decks. Next, I wanted to final fit the open sheaves I made for the top corners of the beakhead bulkhead rail. I also wanted to make knees for these corners. While the sheaves are a contrivance, on my part, to cover for the height discrepancy between the bulwark top rails, these knees were an actual feature of real practice. Just as they do on a real ship, the knees I made increase surface area and do quite a lot to strengthen the area. Frankly, I just don’t trust CA to do the hevy lifting of holding these corners together, over time: Although it is not readily apparent in the picture above, I simulated the bolt heads that hold these knees in place. Also, above, I am holding in-place the forward beam ledge for the forecastle deck. So, finally, I’m approaching the finish-line for painting of the aft port bulwark piece. There is still some gold work to do on the siren figures, as well as the quarter piece, but now the full color scheme comes into clear focus: My objective with the paintwork, because I have chosen such a vivid scheme, is to identify areas where I can replicate the same colors and techniques, in order to create a sense of continuity. All throughout the ship, anything with a fishtail gets painted first with a grey enamel under-wash, and then top-coated with the ver-de-gris wash. I also really liked the use of silver metallic beneath a more natural green wash, that I used for the female Four Seasons figures, on the stern. The siren on the aft end of the amortisement received this particular treatment for her dress, and the wash-coat really highlights the sculpted folds of the dress very nicely. For the face and neck of the quarter piece, I decided to use the same enamel grey wash and wipe-away technique that I applied to the horse-head of the figurehead. It’s subtle, but it really brings out the small facial features of these sculptures. The four Continental figures will also receive this treatment. I think it lends these statues a sense of aged neo-classicism. So, soon I will make and fit the gusset pieces for the aft bulwark piece, and hopefully get the whole assembly glued-up and touched-up in time for the show. Thank you all for the likes, comments and for looking in!
  2. Consider me a "like" for every post! I really appreciate your methodical approach and precise workmanship. I will follow with great interest.
  3. Super crispy! This is the standard of work that I would like to read more about in the Nautical Research Journal.
  4. Fair enough. Pictures often don’t do justice, so I will definitely give you the benefit of the doubt.
  5. The model is first-rate, but that plastic base is lacking, IMHO. The manufacturer should consider upgrading this, even just a little.
  6. Really nicely done, Bill - just coming to this now! Congrats, my friend!
  7. EJ, your carving skills are improving exponentially! Fantastic work on the headrails and figurehead!!
  8. I believe the head rails wrap behind this opening and conceal it.
  9. Not having built the kit myself, yet, it’s a little difficult to say with certainty, but I believe the lower extension of these round houses is deliberate, so that the waste pipes have a means of ejecting through the headrails.
  10. An excellent look behind the scenes: https://youtu.be/ZTJBXmFnxOU
  11. I’m not sure how this one escaped my attention, but this model is truly extraordinary. What a beautiful piece of work!
  12. Thank you very much, Dan! Yes, I’m really looking forward to New London. While I have you on the line, so to speak, what company produced the PE gun tackles you gave me a while back? And yes - to the stars and beyond, hopefully!
  13. I managed to get the red sprayed before leaving for the Cape. We had a wonderful week in Hampton Bays with lot’s of family fun, good dinners, and plenty of medicinal scotch. I also managed to have a productive week laying down all of the primary colors: Unfortunately, in my haste, I forgot to mask off the monogramed escutcheons between the main deck guns. The centers, which will be painted ultra-marine really require a white undercoat for the color to come out right. This now necessitated hand-priming of these little ovals. I deliberated, from the start of this whole project, whether the red should extend up into the amortisement. Ultimately, I decided that it made more sense to follow a continuous, banded approach to each of the three primary colors, with the yellow ocher serving as a unifier. The impression of the amortisement is a bit skewed, at the moment, because I have yet to pick out the supporting dolphins in gold and silver. I took great care to hand-paint subtle edge borders, in yellow ocher, around the triangular panels of the upper section. From here, it is the long, steady march of careful cutting-in, followed by rounds of re-touching: Perhaps, above, it is more apparent how my idea to use ultra-marine along the lower band of fleurs, accentuates the scalloped design of the frieze. This is probably more ultra-marine than would have actually been applied, owing to the expense, nonetheless it is an artistic choice that highlights the effort of making the whole thing. Slowly and surely, we are getting there! As ever, thank you for looking in.
  14. The beauty of our hobby is that it rewards us for our resourcefulness - for simply finding a way that works for us, individually. The beauty of your ship is that it is remarkably beautiful, and a testament to your skill and craftsmanship. It can be difficult to filter out the “noise,” but try not to pay any mind to blowhards like that. Your presence, here, has been missed very much YankeeD. Welcome back!
  15. I can believe it, yes! I remember buying my first pair of titanium eyeglass frames, which were wonderful in every way, but EXPENSIVE for the times. At least I got about six years out of that pair. I would certainly agree that that experience has been beneficial for you. Disciplined best practices, taught from the outset, instill a rigorous approach. My woodworking apprenticeship was administered by a man who insisted I mill material to the nearest thousandth of an inch, as I did the final planing on a KUNDIG sanding machine. His point was not that those tolerances were critical to the work we were doing, but that paying attention to the process was. David was forever reminding me to think things through, in order to avoid “negative pre-determinants.”
  16. This is really a very impressive kit, and your finish work is impeccable.
  17. Wonderfully, practical approach, very well explained and a beautiful result!
  18. It is nice to see you again, Marc. Beautiful work on the port framing!
  19. Thank you for the birthday wishes, Bill, and thank you very much for reading through my log! Over the years, it has grown to an absurd length for the progress made, but the research, therein, is essentially the book I will eventually write, in its unedited long-form. To your question, I would probably display one side with a fully open broadside, and the other side fully closed - if I wanted to show the contrast in appearance. On my first SR, I closed some ports on the lower tier, because I was copying the box cover artwork. As time went by, I came to regard that as a sort of arbitrary display without much logical grounding in what would have really happened on the ship. One other possibility would be to close all of the ports on the lower deck, as would be done if weather conditions would not allow for those guns to be run out.
