Ondras71
Everything posted by Ondras71
  1. Greetings Ab. I have read your documents carefully and I must say that you are doing a very good job. All forums discuss the quality of plans. Especially whether to build only according to them as the rules of competitions state or to modify the model according to the rules of history. I'm building a Dutch ship according to a book Risse von Schiffen des 16./17. Jahrhunderts and I myself have found discrepancies in the plan and I'm trying to improve them. Unfortunately, the shape of the hull is elementary and can't be adjusted. Thank you very much for your messages and contributions, I'm looking forward to reading more. Ondra
  2. Thank you again Peter Cane. Your words are encouraging!! For smoothing clean shapes I created shaped tools and used a belt sander.. Varnish for wooden pores..🎨 O.
  3. I warmly recommend.. O. https://www.hismodel.com/lodni-haky-3mm/tl-0-3mm/12ks
  4. Thank you Peter Cane, I am still learning as well .. I continue lining colored strips, Using discarded planks with poor grain of wood.. Still loose Wales .. Putty..
  5. Fairly built ship. Congratulations. Ondras
  6. Aligned height of the main deck ribs.. Finished base of the stern with the upmost deck..
  7. Drilled holes for the klinkbout.. The model rotated on its stand.. Broken off the rest of the construction ribs and modified the railings' shape..
  8. Working on klinkbout. Here Dutch type, reconstruction Zeven Provincien .. Modified nails 0,7 mm .. wales test..
  9. Absolutely perfect work from scratch !!! Another building in the plan I have the French. I follow with interest !! Ondras71
  10. Thank you for like .. I'm continuing to prepare holes for klinkbout on wales. I painted and pinned the studs clamped on each rib..🔨
  11. Thank you very much Hubacs Historian a Backer..!! Last pins installed and ground .. I really like the graceful shapes of the high torso galleons with lots of wales.. To compare the sides of the Vasa .. O.
  12. For me a great progress, finally impaled and then drilled holes on the last pins .. O.
  13. The last unpainted boards finished. I paint lines for pins ... O.
  14. Unpainted left side planks finished. The window has not been stuck yet..
  15. Slow Laying of Expanding Planks .. Side Window Manufacturing ..
  16. I continue on the last strip of uncolored boards. Front of the gunports .. O.
  17. Thank you all... Now silver in C8 confirmed at Polish Championship 2019 C in Olešnice .. O.
  18. Greetings Backer and thank you for the information, I will definitely use it..🔎 I placed the drain on the left side and added wales.. O.
  19. Greetings SHIPSCAT. Here's another observation about building this kit. Problems started with skeleton .. I keep my fingers crossed for the building .. Maybe this information will help you.. https://www.modelforum.cz/viewtopic.php?f=177&t=100656 O.
  20. The deck is already in shape.. I decided to place square drains on the top deck. There are none in the plan, but all ships had them. Preparing the lath... I studied the cannons: The ones in the plan look older..😳 At the end of the 16th century, cast cannons were already used. I've found a current build of a same age replica of Barents' ship from 1595, which already had cast cannons with a carriage with only front wheels. The build is based on archaeological findings of wrecks.. http://debarentsz.nl/home/foto.html A video of awreck of aSwedish ship Mars sunk in 1564, also with cast gun barrels.. Regarding Roter Lowe (1597) there isn't much to be found, I've only found this on Wikipedia.. https://de.wikipedia.org/wiki/Roter_Löwe_(Schiff,_1597 As to all the plans in the "Risse von Schiffen des 16./17. Jahrhunderts" book, I've read somewhere that these aren't very good reconstructions..
