Posts posted by KORTES
After a very constructive critics regarding the direction of the winding, I spent 2 days on the making new ropes with the right winding. Alexander (Beliy) has explained really well the difference and the reasons for the established tradition, I quote:
The rope of cabling winding is inweaved out of 3 ordinary ropes, and if those ropes are laid in a clockwise direction, than the rope of cabling can be made ONLY counter clock wise.
The standard of winding was created for a reason, the ropes of two windings cannot be laced together, because they will unwind each other, and the the ropes winded counter clock wise dont hold the knots. That is the reason the running rigging is clock wise, and vangs, jackstays, anchor cable - counter clock wise.
While I was winding the anchoring cable I clearly verified this rule - if winding is made in the wrong direction the component ropes will simply unwind.
- billocrates, Sea Hoss, JpR62 and 21 others
- 24
- muratx, druxey, paulsutcliffe and 15 others
- 18
Thank you very much dear Colleagues.
Such a long and thorough preparation has given the result of an amazing quality. Bravo.
My best regards.- John Allen, KeithAug, FriedClams and 2 others
- 5
This is an outstanding work on toning the wood.
- mtaylor, Keith Black, druxey and 2 others
- 5
- bruce d, mtaylor, GrandpaPhil and 23 others
- 26
Thank you Yves and Johann for such a high evaluation of my work.The pear tree has turned this color with time, after being coated with tung-oil.My best regards.
- Keith Black, BETAQDAVE, FriedClams and 3 others
- 6
- BETAQDAVE, mtaylor, billocrates and 22 others
- 25
- wefalck, Keith Black, Mirabell61 and 10 others
- 13
On 3/31/2019 at 11:48 PM, wefalck said:
That is some artisanal talent 👍 I also would have thought of how to do this on the lathe.
BTW, I had seen the 'pulling threads' somewhere before and think it gives better results than sewing on the sails. I was wondering, whether one couldn't splice the thick thread to the end of one to be pulled or to twist them together with some CA glue to make them easier to pull through, than the double thickness of the thicker thread
Unfortunately , I don't have a lathe machine. This is the reason I have to apply non standard solutions.
To my point of view , the glue , in this case , will not simplify the process , so the knot would be more appropriate.
- BETAQDAVE and Keith Black
- 2
- GrandpaPhil, druxey, KeithAug and 9 others
- 12
Gary, your diorama is so realistic, that studying the photos I wanted to visit this cozy building shop very much, then I realised how small it is. A great work of the True Master. Thank you so much for showing us your work.
My best regards.
- druxey, Keith Black, mtaylor and 1 other
- 4
Gary, thank you so much for such kind words.
To my mind the light perfectionism is good for every master.
- FriedClams, Keith Black and mtaylor
- 3
I’ve made the carronades.
The method isn’t too technological, but since I needed only to of them I decided to use it. The barrels are turned using a lathe, all the other parts are ‘filed’ of brass using the rat-file and broaching files. All the parts have been soldered together and after blackening the solder had to be painted.
La Jacinthe by Kortes - FINISHED - 1:42 scale - French schooner
in - Build logs for subjects built 1801 - 1850
Posted · Edited by KORTES
Much to my regret I had to redo all the rigging, which was already installed, except for jackstay of foremast , which, as it turned out ,had the right winding on. I put a bit of tone on the turnbuckles of the shrouds, although to my point of view they looked better before. I won’t post many photos, as nothing had changed except for the winding on of the cable.
