Posts posted by KORTES
- aviaamator, dvm27, Ondras71 and 21 others
- 24
After consideration, I decided to glue using PVA glue. For several reasons - cyanoacrylate glue, even gel, binds very fastly, and I was afraid that the pin will be fastened sooner than it enters fully, on its full depth. The second reason is that once the cyanoacrylate glue is binded is gets very fragile and the junction may crack even at a slight bend. PVA glue is more flexible even after drying, and if there are few gashes on the pin it will hold tightly and more so as the binding time is long enough it allows to put the piece right in place. There’s only one thing bothering me - how much time does it take to bind inside the wood? Perhaps it would be better if i heat up the place where the pin is set?
My best regards.
- Keith Black, JOUFF, JpR62 and 8 others
- 11
- michael mott, GrandpaPhil, JOUFF and 17 others
- 20
Greetings, dear JanWhen I was working on the La Jacinthe, I was following the principle - all that I could make myself, was made by myself.The blocks were not an exception, so as the required number wasn't high, I made them myself. The exception were only 10 pieces of 2mm, that were too many to be made, so I had to buy them.
- amateur, aviaamator, mtaylor and 10 others
- 13
- mtaylor, Captain Poison, G.L. and 15 others
- 18
- paulsutcliffe, KARAVOKIRIS, archjofo and 23 others
- 23
- 3
- JOUFF, KARAVOKIRIS, druxey and 12 others
- 15
My greetings, dear colleagues,
I Submit for Your judgement anchors.
I never did the casting, and after talking to my colleagues I realized that in order to obtain the desired result, among other things you need to get some practice
,through a system of trial and error for which time is needed.Therefore, after weighing everything, I decided to just cut the anchors, for the lack of brass, I used 3mm iron sheet. I had to make 4 pieces, taking my time I spent days on it. I used a cutting wheel, files, broaching file, a drill, of course, and
the final stage a micro-drill.- KARAVOKIRIS, JOUFF, Valeriy V and 10 others
- 13
My work on the sails is coming to an end. After a series of trial and error I got almost two sets of sails. I present the final version. Material - cambric, painted with artistic oil paint diluted in white spirit.
For the moment all that is left is to make a reef-band.
La Jacinthe by Kortes - FINISHED - 1:42 scale - French schooner
in - Build logs for subjects built 1801 - 1850
Тhank you very much .
