I've finished cutting out the Great Republic and the Young American...but still need to contour and finish carving them(as well as the three just cut) into their final designs. that takes the longest, because the true hull design is captured in the final carving and great care must be taken to make an accurate representation. More to follow. Rob
Thanks Druxey. I intended the scale to be small so as to allow me to fit at least 8 hull models/designs on the plaque. The plaque must be large enough and small enough to accommodate the half models, descriptions of them and a characterization of the particulars of why hull models were used and to demonstrate the varied size of clipper ships being built during the clipper era and be able to comfortably find a wall space. Thanks for your fine comments and interest. Rob
Thanks Jaager...so very much. I should have stated 1 inch equals 35 feet...your scale is nice 1:420.... I used the " and ' marks for the measurements. I thought the half hull comparisons would help clarify the problem we can sometimes have when we have similar size models of different scales and no real way to demonstrate the actual size comparison between vessels. I hope it is a great visual aid...and one nice to have on the wall of my nautical Den. Rob
Here are some images of the three after I made the cuts on the band saw...co carving or shaping yet..... Rob
I wasn't sure if half hull models were considered a legit topic...but I'm sure many have either put their hands or wanted too, to creating half models of their favorite ships. Thanks for all the likes everyone. More to follow. Rob
I still have rudders to add and painting the muntz bottoms. The Rainbow will have a green bottom and a wide white band along the hull. These are simply the primed wood half hulls and lots of details left to bring them up to the finish I want. I still have Young America and the Great Republic to transfer to the pine blocks. I use my bandsaw...and drum sander along with hand grinders to shape the hulls. Rob
Next I'll post some images of the first three hulls already cut and primed. Here is the small Rainbow
I'm A SHIPYARD. Well I took a few images of the blocks of wood for the next 3 hulls...the Sovereign...the James Baines and the Cutty Sark. Drawn on the wood in 3D...I'll go to the bandsaw and cut them out.
Searching for a good place to start this..and since I will be building wood half models of at least 8 clipper ships..this looks like the right place. I have several builder half models of several clipper ships..ie...the Lightning and the Cutty Sark. But my problem is, in all the clipper models I build they are all roughly the same size models..but do not represent the actual comparative size to each other. To keep the scale issue from being clouded as folks view my collection..and from misconceptions being formed that this ship was the same size as that ship; I am embarking on a new project. To scratch build from carved wood a plaque that will contain some significant clipper ships through the period from 1845 to 1869. A representation of the evolution of the clipper design. As far as I am aware...there is no such collectors plaque currently available...so I am taking it upon myself to design and build one myself, for my library. This means I will draft and scale 8 clippers...that I feel represent significant design changes and establish a visual representation of scale between these clipper ships. I'm first starting with the Rainbow..of 159 ft built in 1845. The Sea Witch of 170 ft built in 1846. The Cutty Sark of 212 ft built in1869. The Flying cloud of 229 ft built in1851. The Young America of 243 ft built in 1853. The Sovereign of the Seas of 258 ft built in 1852. The James Baines of 266 ft built in1854 The Great Republic of 335 ft built in 1853 Each one of these clippers represents different designs and sizes...just what I want to demonstrate. The average clipper's size fell between 170 and 260 ft in length....so I selected vessels that fell within that norm. Not to be eclipsed by the Giant of them all the Great Republic. I will be carving each of the half hull models from soft pine and the scale selected for rooms sake will be 1": 35'. So the Rainbow will be roughly 4 1/4" long and the GR 9 1/4". All will be situated in row on a nicely detailed plaque of wood(Painted antique green) with gilded trim. Lets get started. Rob
I read the article and the author did do some nice tricks with his approach. I did like his application of wire edging to support the natural bow and billow of the wind filled sails. I do agree the stitching he used was slightly out of scale...but his sails were far better then any unmodified vacuum formed sails one may use....and a mile better then the bulky outta scale cloth sails some use. Rob
Fantastic job Ed...really. Just to let you know..I made some of these myself..almost exactly like yourself..however I only needed one solder joint. I compressed the tubing like you did..but I then only cut out the two corners of the compressed tube on the end and had a *T*... which I then added the bolt eye and soldered, then I made the final bottom cut and there you go. My blocks were a bit bigger, but basically the same. Your's are very nice. Rob
- 3,618 replies
- young america
- clipper
MONTAÑES by Amalio
rwiederrich replied to Amalio's topic in - Build logs for subjects built 1751 - 1800
Absolutely magnificent! Just Extreme fabrication..... Rob -
Thank you....if it ain't one thing...it's six other things. I have so many conversion models I'm working all at the same time...I feel exhausted. Which one to work when I have so little time to give to them ? Glory of the Seas...needs finishing up on backstays and yards(running rigging). Donald McKay...needs Fore and main masts and yards(Rigging). Great Republic...needs shrouds,backstays, yards(rigging) Ferreira...needs(running rigging)
- 1,208 replies
- great republic
- clipper
Yes..the flat head punch concentrates the force and makes very nice flat portions to the wire. Rob
- 1,208 replies
- great republic
- clipper
Doug...when smashing wire..use a flat head punch to contact the wire and strike it, instead of the wire. This way you can have more control of what the wire does under compression. Then you can return to them and use a moto tool and grind/file them to make them all similar.
- 1,208 replies
- great republic
- clipper
Steve....I'll try to add more pages so you can have something to follow. Thanks for your attention and comment. Rob
- 1,208 replies
- great republic
- clipper
Well Pat..I can be relatively fast when I'm actually working on the models. As of late, time has been precious and that tends to keep my modeling hours to a severe minimum. Thanks for the comments. Rob
- 1,208 replies
- great republic
- clipper
- 1,208 replies
- great republic
- clipper
Boy it has been a while, hasn't it? I've only just now installed the port and starboard davits and rigged the boats to them. I've had much family issues as of late..new grand babies, in-laws passing away...so I've not been doing much. But to answer your question. I didn't use brass strips...I used soft metal rod wire about 1mm dia., cut them for convenience sake(bout 1.5"long) and then using a hammer and anvil smashed one end to represent the chainplate mounting plate. I then cleaned the smashed area up and evened them...bent them in the correct locations and pressed them into pre made slots in the channedl. Leaving just enough of the metal exposed on top of the channel to secure the dead-eye to. Then I covered the recesses with a finishing strip. I then secured several finishing rivets on the plates. Thanks for asking. Rob
- 1,208 replies
- great republic
- clipper
From what my study has revealed , unlike men of war, clippers were heavily spared and generally had taller masts to accommodate those spars. Double channels simple allowed the stresses of the shrouds and backstays to disperse their loads over a greater surface. Double channels allowed such forces to be fixed as have been mentioned earlier, over a greater area of strength on the hull...plus more points of contact for the chainplates allowed for greater retention against the pull or force applied against them. Enormous lateral stresses were placed upon the shrouds and backstays and many captains who were bent on *DRIVING* their ships in extreme conditions, far beyond what would be expected in ordinary ships relied upon well built *STRONG* vessels to *Do the Impossible*. these ships had to be extremely strong to endure what they were expected to do, in the hands of a driving captain. Rob
- 3,618 replies
- young america
- clipper
Wonderful job indeed. I appreciate the sentiment for the one you care about. I plan on making a half hull model of the clipper ship Sovereign of the Seas for my study/library. I did, however, make a half hull model using one half of a broken model of the Revell 1/96 Constitution. It worked out very well and it was nice to detail out the chain plates and deadeyes with metal and wood parts. I have no images of this build because it was so long ago and I never thought to take images. It was given to a friend. I'll enjoy following your log. Rob
- 23 replies
- constitution
- frigate
Pat the technique works on any thing you want to weather. You can substitute brown Ink for the black if you like. Here are some images of the Revell Cutty Sark I converted into the Portuguese Ferriera. This is modeled when she was at her lowest, rotting in some backwater. before she was purchased and rebuilt to her original glory. I applied the alcohol technique to everything and then applied cerium oxide(which is an extremely fine(5 micron) powder to dust and add further ageing. Rob
