Everything posted by JpR62
Superb work on this longboat. It is true that the rigging immediately gives another dimension to the model. Your rigging is precise and will be an example for me to follow. Thanks for sharing !
- 170 replies
- medway longboat
- Syren Ship Model Company
Outstanding work. Really a very high quality model. Many thanks for sharing your work !
- 315 replies
- master korabel
- avos
Bob, Thank you for your nice comments. The Medway longboat is really a high quality kit ! Yes, the Mikhail chisels are really fantastic and are very useful to me because I currently have neither a table saw nor a milling machine. For the diamond mini file I prefer them to the regular files. They must come if my memories are good from Modelexpo.
Thank you for all the 'Likes' The bolsters are done. I used the magnificent Mikhail wood micro chisels. I'm lucky to have been able to acquire a set and it is a purchase that I do not regret. I also stuck sandpaper on wooden sticks of different diameters. I have allowed myself to not follow exactly the form provided by the plan and I have given to my bolsters a more personal touch. It took a long time and I had a good day to shape these two pieces. It's time to reduce the width of the caprail.
So precise and clean ! 🙂 It seems so simple with your explanations and yet it requires a high level of execution quality. What a wonderful job ! Thank you for sharing your build with us !
- 607 replies
- winchelsea
Yes, when the Medway Longboat will be finished, I will start the 'Cheerful' cutter. I'm a big fan of the Syren Company kits ! The Frigate 'Winchelsea' also occupies my thoughts. 😉
- 221 replies
- queen anne barge
Superb work. I really like the smoothness of the caprail. She will become really beautiful. Take care of yourself and your family during this difficult time !
- 221 replies
- queen anne barge
Thank you all for your kind words and thank you to all the 'Likes'. The longboat was taken out of his baseboard. Just take your time. First I start by cutting with a small file. When the cut mark is formed, I continue with a saw. I remove the reinforcing tape with a tweezer just before finishing the cut. Time to prepare the installation of the caprail.
After my stop due to my surgery, happy to go back to work on this longboat 😄 If for the side decorations, I will use the friezes supplied with the kit, for the transom decoration, I opted for a more personal version. I take advantage of the stability offered by the build board, to paint a small freehand motif. So I took out my tubes of extra fine oil paint. and it allows me to work again with my right hand 😉 Time to remove the baseboard.
Thank You Michael, Chuck, Ryland and to all the 'Likes'. Ryland, it's really nice to be able to find your way to the workshop and especially to be able to reuse your right hand. Shaving with the left hand is not always very safe. 😅 I finished all the carvings. They are now in place and I am not unhappy to have opted to use them. I steel have to order the wood for the base. And it will be my first completed project 😁
- 103 replies
- queen anne barge
It's been a while ! Unfortunately, I was away from my workshop for 5 long weeks following a surgical operation on my right hand in February (see the photo taken the day after the surgery). I can now start doing some small jobs and it is also a good thing to regain the mobility of my hand. So I take this opportunity to finish the carvings for the Queen Barge. Work in progress...
- 103 replies
- queen anne barge
A wonderful book on many modelling techniques. Book published in German at VGB Verlagsgruppe Bahn GmbH under the title 'Marcel Ackle, Ein Natur-Talent', 2018. ISBN number of the German edition : 978-3-8375-1963-1 French edition (2019) proposed by LR PRESSE, www.lrpresse.com contact@lrpresse.com Author of text, photos and models : Marcel Ackle Book cover : Marcel Ackle ISBN number of the French edition : 978-2-37536-030-9 208 pages Format : 25 cm x 30 cm Contents : Some extracts Not directly a book on ship model making but a real 'gold mine' on painting techniques and many build tips. Unfortunately only in French or German but a lot of step by step photos. The address of Marcel Ackle's blog : http://www.feldbahn-modellbau.ch/ Thanks to Wefack for letting me discover the wonderful work of this talented model maker.
I think Mike used two layers for the wales (see post #121 - page 5). It seems to me in 2 stages: first the upper 3 strakes then finally the last strake once the first strake below the wale was in (the strake which included the drop plank) - post #133 But Mike can confirm my answer.
- 607 replies
- winchelsea
Wonderful planking job ! Taking the time always pays ! A beauty !
- 607 replies
- winchelsea
Thank You Chuck for your advice and Gary for your kind support. Thank You to all the 'Likes'. The planking is now finished. For the second layer, I used a more traditional method because I was afraid of not being able to give the exact shape that perfectly matches the first layer already in place using the heat of an hair dryer. As I was afraid that humidity would cause the first plank to curl, I protected it with masking paper using the laser sheet as template. The masking tape is then set up. The plank is soaked for 2 minutes in hot water and then placed on the hull. After a few hours, you get a plank that perfectly matches the shape of the hull and which can be glued without having to exert pressure. The masking paper prevented any deformation of the first layer already in place and facilitates the removal of the second plank once dry. The last board before its installation ☺️ The treenail simulation is finished and the second layer thinned at the bow and at the stern. A good stage completed 😅
Chuck, Thank You for the quick answer. I will order it.
- 1,784 replies
- winchelsea
Hello Chuck. On December 30, you indicated that Elmers wood filler had the exact same color as yellow cedar. I need it to finalize the hull of the Medway Longboat (some micro small gaps to fill between the keel and the planks at the bow...). As this product is not available in my country, I will buy it via Amazon. But I will be sure to buy the good product... It is found in several shades : natural, golden oak,... Can you give me the right reference (or put a picture of the box) ? Thank You in advance and all my admiration for the wonderful job on the Winchelsea ! 😍 Happy New Year !
- 1,784 replies
- winchelsea
Superb work, Ryland. Happy New Year 😊
- 263 replies
- Medway Longboat
Very nice work. Russian master replace ebony with black hornbeam. This wood species seems easier to work. Take a look at the wonderful build log on a 'Friech Boeir Yacht' from Kortes https://modelshipworld.com/topic/19572-friech-boeir-yacht-sperwer-by-kortes-130-scale-finished/?tab=comments#comment-597413
