DARIVS ARCHITECTVS
Everything posted by DARIVS ARCHITECTVS
  1. There isn't a lot of room as you say, but the frame locations for the model are not accurate to the actual ship's construction, and they crowd the guns even more. In my build, I used three sizes of guns, closer to what the ship actually had. The nine pounders on the upper deck are slightly smaller that the 18 pounders on the lower gun deck, and as you can see below, the 6 pound sakers are smaller still, such that they fit better along the forecastle's forward bulk on both upper and lower gun decks. The saker carriages are scratch built and gun barrels are bought seperately. I agree that the stained wood appearance is far better than painted wood, and Corel did a great job providing quality stained wood to work with. Your build is coming along beautifully! I see you're in Wisconsin. I'm in Minnesota. Hi ! 🖐️ I finished this model in 2 years 8 months, and it's complete with full rigging and full sails. If you have any questions or need research information on La Couronne, PM me.
  2. These are amazing! Do they fly well under rubber band power? It takes a special talent to make custom models this small with such detail and get them to actually fly. These are a unique art form.
  3. As the bowsprit goes, you are certainly on the right track. Your multiple research sources are generally more credible that a kit designer's choices, even if it is Chris Watton, and even if artists' painting also can contain errors. Common sense also applies. If you can't use the spritsail, something is definitely not right.
  4. NOBODY operates steam ships anymore? I was a US Merchant Marine engineering officer, and ran steam ships for years on bunker C. Bunker C is not as heavy a polluter you think it is. at 18,500 BTU/lb., it's cheaper and more efficient that diesel at 17,900 BTU/lb. The trend has been for decades to go diesel, but steam ships are still around. Steamships are more efficient than diesel in larger ships, such as supertankers. There certainly are steamships operating today. The MSC ready reserve ammo ships are steamships. I ran one in Desert Storm in 1992. All 8 fast Navy owned sealift TAKR ships in MSC are also steam, and have the largest marine boilers in the world, holding 36 tons of water each, and they are twin shaft and capable of 36 knots, probably the fastest cargo ships in the world, and sailed 3 of them.
  5. I have some experience changing the tuck on a shape with an incorrect shape. It you were to attack the edge of the stern with a coarse sanding block, you will soon opening up the space between ends of the planks and the last frame. I had a similar problem with DeAgostini's HMS Sovereign of the Seas. Luckily for me, I had filled the spaces between frames with balsa blocks, so when I sanded the corners off the stern, the plank ends still were attached to the balsa block and were not floating in free space. All that was necessary was to use some filler to smooth out the modified area, and the filler provided good purchase area for attaching the final planking. In your case, after you sand away the corners, you will have to insert some blocks of balsa, gluing them to whatever internal surface presents itself (forward face of the last frame, internal surface of the planks, etc.). Then you can shape the blocks to the desired profile, and add filler to smooth the shape. Even if the hole you sand open becomes large, you can use blocks of balsa, sticks or blocks of a soft wood such as basswood, and reshape the entire stern without worry. You're going to cover it with finishing planks, so it doesn't matter where the seams of the wood underneath are. You just need the structure underneath to be sound and have some strength. It doesn't have to look pretty. Such is the advantage of a dual planked hull. I am of a mind that, if you leave a feature in your model that you know is not the best, you will ALWAYS be bothered by it, even years after the model is done. Take the time to make things right as you see them, and you won't have any disappointments of your own making. Balsa fill is a lot of extra work, but after shaping and sanding to match the frames, it guarantees a smooth overall hull shape without visible sharp bends at frames and flat spots. Stern before modification, demi-round tuck, and far too wide. Sanding the corners round exposed plank ends, and balsa underneath. At least the balsa is a strong foundation for the final planking. The shape after final planking. After painting the bottom with white stuff.
  6. The main problem I have with paper sails is that they they bend easily in only one axis, and have almost no belly, which is essential for models of the early 17th century. Cloth sails can be stretched in two directions, and held in shape with starch. The course grain of cloth can be overlooked, but improper or unrealistic shape can not.
  7. An excellent rigging job. Running rigging lines are not pulling the stays out of position, demonstrating true skill at setting proper line tension. BRAVO! 😀👍
  8. As someone who as a young boy was totally fascinated by dinosaurs and prehistoric sea creatures, this is SO COOL!!!! 😃👍
  9. Greeting from another HMS Sovereign of the Seas builder. Best wishes on a successful build of one of the most challenging ship models ever! 👍
  10. Corel models are appealing to me even though they are smaller in scale, and as such don't allow you to make details as easily, but the plans are nice and the wood materials are great quality. But Corel makes more models from the the 17th century than other kit makers. The 3-D printed decorations and parts you made for the Greyhound are fantastic! They add so much tiny details which are very hard to carve at this scale. I'm trying to learn the same thing for my current model, using Aspire and Blender to make decorations and carvings, and am farther down the ladder on learning. There is such a long way to go just learning how the 3-D printer works, starting with taking it out of the box, which hasn't happened yet. Love your work!
  11. CA = cyanoacrylate, commonly known as Superglue.
  12. Rigging tools are not complete without a razor sharp set of scissors which allow you to trim that line after it's belayed to the belaying pin on the fife rail. These have served me so well, I bought a second one.
  13. My compliments to Majq for making such a clean and elegant model of La Couronne as designed by Vincenzo Lusci by way of the Mantua kit. Splendid work! Rraisley, if you are interested in another build of La Couronne, my build log is a heavily modified version of the Corel model for that vessel, located here: La Couronne Build I have a specific interest in early 17th century men of war, and am currently working on HMS Sovereign of the Seas. Let me know if you need specific help with a La Couronne build, particularly with the rigging and sails. Best wishes!
  14. As kits go, Winchelsea is up there among the finest. It deserves to have rigging and sails. For me, a ship is incomplete without them.
  15. Thanks Ed, but this is only my second ship model. Experience in other craft hobbies translates over very well. It's 1:78 scale, unlike what DeAgostini claims as 1:84 scale. The hull got started as the DeAgostini model, then went totally wild with scratch built bashing. What's really neat is that all three interior gun decks are fully modeled and rigged! Many say it's a shame to hide all these details, but I know they're there, and I have a borescope. Each deck is fully structured like the main deck shown below. Look inside! A 1" long gun looks almost real even at this magnification when properly rigged. The gun tackles use 1.5mm boxwood blocks.
  16. I'm about halfway though a mostly scratch built HMS Sovereign of the Seas, and it's a huge challenge. After it's done in about 6 years (wild guess), privateer Rattlesnake is next. I'm collecting info on the details of Rattlesnake from other Rattlesnake builders to prepare. Rattlesnake is a fine and unique ship, so different from other vessels in the fledgling US Navy.
  17. Hello Ed, I just started following your Rattlesnake build and will be starting my own in a few years after my current model is complete. Congrats on a successful build so far. The discussions on the fitting details are fascinating!
  18. Thank you, Allenyed for the great gun barrel .STL files! I have yet to break open my new printer and learn how to use it.
  19. As one who based a model on the DeAgostini kit, I can tell you for certain that the model used in the advertisements in not the one in the kit. The model in the ads is an Italian made scratch built model. The kit is based on that model, with several simplifications to make it easier to build for beginners, which is the target customer base for DeAgostini. The instructions are certainly well made for beginners. This has generated many accusations of false advertising which still ring out today. However, the decorations and other features were changed from what we know the Sovereign featured. The decorations were simplified into multiple stamped out copies spread across the hull in some cases. Many of the decorations are well made, others a big disappointment. The culverin carriages are the wrong type on the upper most decks of the fore and stern castles in that they should be half trucks, not full truck carriages.
  20. The RC looks fantastic, Messis. Clean and neat, and the colors on that ship are striking! 👍
