Mldixon
Posts posted by Mldixon
That is a ridiculous price...not realistic by any means
I'm suffering from lamp envy...great job,and exceptionally clean
- Rustyj, FrankWouts and scrubbyj427
- 3
👍👍good luck Tony, and your welcome.
I looked at your build logs, very impressive work...
- tkay11, mtaylor and thibaultron
- 3
3 minutes ago, tkay11 said:
Yes that is the printer I used. The good news is, once you push print you can work on other things. Most printers are going to charge you a lot. Just buy the printer and resin. If you model a lot of parts it pays for itself pretty quickly. And yes it does have a learning curve, but it's not too steep
- thibaultron, mtaylor and tkay11
- 3
I thought it looked pretty good considering the scale.
- thibaultron, tkay11 and mtaylor
- 3
So here are the results of the print of the stove. I primed it in black with an airbrush on about the finest mist i could produce.
I did no post cleanup on this, an alcohol wash and blew it off with air compressor. It was a .01mm layer setting and it took 5.5 hrs to print. Cost was 1.5 Cents plus paint, 5 drops.
With the naked eye (mine are 73 years old) it appears as a black sugar cube. You will need a magnifier to see any detail at all. And the paint tends to wash out details at this level of printing, so it's got to be very light coats.
I'm fairly certain any type of brush on painting would obliterate the details at this size. This was your file as provided. If you exaggerated the details, they would stand out to the naked eye pretty good. I would think the print services are being ultra cautious because of the small size and customer satisfaction.
Size verification🔻
Top of stove, Painted to reveal details🔻
Side shot
I'll run it this morning.
- thibaultron and mtaylor
- 2
I just 3d printed a latern for my Winchelsea model. It seemed an almost impossible task, but I was able to get a pretty good result.
I draft in full scale, then scale down to model size. At that point you are correct, the parts are too thin to print. So i make things thicker to overcome this. When printed and viewed very few can detect the difference. If your a purist well none of this will work.
Link to lantern
https://modelshipworld.com/topic/22779-hms-winchelsea-1764-by-mldixon/?do=findComment&comment=926251- mtaylor, tkay11 and thibaultron
- 3
Lantern
This was modeled in Sketchup Pro 2021 from the drawings Chuck posted in his thread. It was adjusted for size based on the prints. Then I used a Anycubic Mono resin printer to get the final product. Airbrushed the piece to match the Alaskan Yellow Cedar ( which was by far the hardest part of the job) the interior parts were hand painted with a very fine brush to get the details of the candle and the floor.
Mounted on the first side 🔻
Hinged Door shot 🔻
Here is what the sketchup model looked like🔻
and this is what the pre print file looked like 🔻
and what it looked like when it was out of the printer before the removal of the supports
I really need to get a crappier camera, or boost my skills by a magnification of 10...but it really looks good when your just standing and looking at it.
I'll post some nice white screen backdrop shots when I clean the model up at the conclusion to this build.
- Edwardkenway, rafine, JGR and 10 others
- 13
Well we've been cutting through molding already in other areas. So I kind of like the way you drafted it, by the way those fenders are really intricate I'm not sure how you manage these surgically small cut lines....
- scrubbyj427 and KentM
- 2
- CaptMorgan, Captain Poison, JpR62 and 9 others
- 12
22 hours ago, scrubbyj427 said:
Lookin good! Crew really bring it to life!
Thanks, nothing is glued down presently, always keeping the options open. I do like the figures at the present time but I am going to finish the entire ship before I make any giant leaps. Assuming I live long enough😂
Thanks to all for the likes...
- scrubbyj427 and FrankWouts
- 2
Well thats one more than I've done...that looks great 👍
- FrankWouts, Matt D and Saburo
- 3
5 minutes ago, Chuck said:
Those rails are tough...so you should be very happy with how it came out. Well done. I havent even started chapter 11 yet sadly. I hope to next week. Dont forget the ladder in that companionway.
Chuck
Yes, the rails made me very nervous...on the transom it was like sink or swim, making the cuts I left lots of extra just in case, and sanded to the fit. Lots of moving parts involved in this Area. The ladder is still in the works, but coming along. Thanks for making a great ship for us....
- 2
Chapter 10
🔺️cannons are not complete yet
🔺️I'm okay with how the rails turned out.
🔺️Still no lids on for lower cannons, just too easy to knock off.
🔺️4 more cannons to make then details, no stairs in place yet, have yet to make them.
🔺️Transom rail...touch up painting will be required after I finish knicking it all up
If your willing to go through the rather steep learning curve, and the higher cost, Zbrush by pixologic will import the object file from Daz export, and will resolve all the problems. Ask me how I know.
- lmagna, mtaylor and thibaultron
- 3
HMS Winchelsea 1764 by MLDixon
in Member Build logs for the HMS Winchelsea
Chapter 12 parts are now in hand....all I have to do now is finish.
