GrandpaPhil
Everything posted by GrandpaPhil
  1. Thank you, Richard! Thank you all very much for the likes! I’m making progress: The foremast bitts are done and installed: The stern bitts are painted and the mainmast bitts are installed, but the fife rail still needs finished. Due to the variance between Mantua’s kit and the AOTS plans, I needed them in place to measure off the location of the belaying pins (made from sewing pins).
  2. The bottom of the topmast sits on the crosstrees or mast top. The top is secured by the mast cap. Here is mine from the Prince de Neufchatel: It is from before I painted the masts so you can see how they go together.
  3. The blue and white with the gold fleur de lis was difficult to paint when I built the Heller version. I am still going to try it when I build my replacement for it in a couple of years.
  4. Thank you very much! I bought the scalpel on EBay for $8. It came with 100 blades. I personally like them better because they are much sharper than x-acto blades and cheaper. The only downside is that they cannot take side pressure or the blade will break where it snaps onto the handle.
  5. Thank you very much! Thank you all for all the likes! Everything made last night is now painted: The mast coats for the fore and main mast are made, painted and installed: The stern bitts are made and installed, but not yet painted: The forward foremast bitts and fife rail is made. The pieces of sewing pins are my belaying pins. Even at 1/72 scale, they are close enough to being in scale that they look like belaying pins. At 1/98 scale, they look perfect (to me at least).
  6. Thank you all! I’ve been having a lot of fun with this build. It has definitely been a good challenge. I made some more progress last night. I finished the rail, except for the hammock cranes. The hammock cranes and netting will be one of the last deck fittings that I make. I fixed a minor issue with the hatch going to the upper gun deck by the main mast. I did not like the tops of the quarter galleries, so I made filler pieces that I did like.
  7. All eight of the upper stanchions are made and installed: The upper rail is made and ready to install: It will be installed after the stanchions are painted and touch ups to the lower rail are done (probably tomorrow).
  8. Using copper tape is a really easy way to copper a hull and it looks fantastic.
  9. Thank you both very much! Thank you to all who have hit the “Like” button! The silver lining of the current situation is that it has greatly freed up my schedule. Bearing in mind that I am the one who has previously taken vacation days from work to work on my model. I am still working on the upper stanchions. They are right on the borderline of what I am currently able to carve, due to their small size (which is why all subsequent builds will most likely be at 1/72 scale).
  10. Part two (the lower rails) of the aft railing is done and part three (the upper stanchions) is under way:
  11. Welcome!
  12. Welcome!
  13. That comes with experience. I am still learning, too. One example of a valuable learning experience is that I drilled most of the holes for the eyebolts, for the cannon rigging (on the bulwark side), from the outside of the hull because I failed to plan for them during construction. That would also work for you in your current situation. Just put a little filler in the holes from the outside and paint over them. Your build is coming along beautifully. Well done.
