GrandpaPhil
Everything posted by GrandpaPhil
  1. I finished painting the base of the binnacle and added windows (clear acrylic sheet glued behind the cabinet). I made the stovepipe looking thing from a piece of a sewing pin.
  2. And, it’s glued in. It’s not perfect, but it’s not bad for a first try.
  3. Thanks, OC! Thank you everyone for all the likes! The ship’s wheel is ready to install and the binnacle has its first coat of paint:
  4. The ship’s wheel is assembled and partially painted: I had to cut a piece out of the base and reglue it, so it’s set aside to dry. I’m cutting out the cabinet doors for the binnacle. They are tiny.
  5. For the binnacle, I photocopied (at scale) the side and front profiles of the binnacle and carefully glued them side by side, so I could fold them into a box: I put clear sealant on both sides to make working with it easier. Then I carefully it out and cut out the windows (The middle row is all windows): Then I carefully scored the outside edges with my scalpel and folded it/glued it. Then I measured and left a 1/32”clearance and cut the top and glued it on: I photocopied the front plan view again, twice, to make the doors on the front (and sealed both sides again): After the cabinet doors dry, I’ll paint the entire part black, inside and out. Then I use the sheet acrylic that I have to make the windows. There’s a stove pipe looking thing coming up out of the top, which I will make with a piece of sewing pin. My source book is John McKay’s The Hundred Gun Ship Victory.
  6. The parts of the ship’s wheel: They still need painted and I’ll wrap a line around the barrel to simulate the connection to the tiller, below decks.
  7. Keith, I’ll detail how I made the binnacle, when I get back around to it. That will be when I get closer to finishing the wheel, which sits behind it.
  8. Thank you all for the comments and the likes! The barrel is actually part of the ship’s wheel which is a double wheel. The barrel goes between the wheels and acts as an axle. The card stock for the skylight is poster board from Walmart. I’ve been buying the 8 packs, because I go through a lot of it. The thinner card stock I am using for the binnacle is just the printing paper card stock from Walmart. I have been having a lot of fun with this build. I have really enjoyed scratch building what I have. It is fun to find solutions to problems when you run into them and then implement those solutions. The detail work has let me try many techniques that I will carry forward to my future projects.
  9. Dry brushing works well too, to paint the raised area, if you wanted a faux metallic (what I like to use) or a painted metallic (if you didn’t like the look of the brass) look for your model.
  10. I have heard really good things about the Caldercraft kit. Also, Amati is releasing a kit of the Victory in 1/64 scale that should be really impressive.
  11. The binnacle is roughed out: The Victory is starting to really take shape:
  12. Thank you! The start of the ship’s wheel: Also starting on the Binnacle.
