GrandpaPhil
NRG Member-
Everything posted by GrandpaPhil
I use clear plastic packaging for glass on models, too. It has always worked well for me.
- 393 replies
Ferrus, The cat ship is similar in basic shape to a fluyt, but it is a separate type of ship. The cats are a more basic design and are intended to be more of a working ship. They were mostly flat bottomed and have a nearly square cross-section for more cargo capacity. Cats only had minimal decoration and their sterns typically had a painting on the transom instead of more decorative carvings like the ones on the fluyts or pinas. Think of a seagoing Mack truck. I wanted a cat ship as soon as I saw it in the book and I had so much fun making my last workboat that I decided to build it and try to build a hull with more structural pieces than I had used in the past. I have been enjoying this project.
For my buddy from work: To line off the deck, I measured the middle of the decks at each end and made a line down the middle. Then I laid a center plank down the middle, lining up on the centerline. Then I laid a plank on each side, alternating until I filled up the deck. Next, I flipped the deck over and trimmed all holes and excess. I forgot to take pictures of that part. Here are my decks installed: I know that there are gaps, but my planks are contact paper and do not have thickness. You won’t see the gaps once they are painted (and on this model, everything is getting painted). For a wood model, you will want to color in the sides of each plank with a colored pencil or charcoal to give the impression of the tar that would have been between them on a full sized ship. You will also not want to have gaps. On a separate note I cut down the sides of the ship to the tops of the bulwarks, just below all the layers of railings
What are the best detailed plastic models?
GrandpaPhil replied to Ray1981's topic in Plastic model kits
In my personal opinion, Heller makes the best plastic sailing ships, although I have never built an Airfix plastic sailing ship, which seem to be well regarded. -
From what I understand the San Felipe of 1690 did not actually exist. Why not release a kit of a Spanish 3-decker from that time period that actually existed?
Stuns’ls aren’t too bad. I made them for the first time for my Prince de Neufchatel. Their rigging run can take some adjustments to prevent them from interfering with other sails.
I would not add any more running rigging or sails yet, but the mainsail and mainsail rigging shouldn’t interfere with the standing rigging. You have already built the hard part and done it well. You’ve got this.
Sorry to hear about Maggie! I hope she gets better soon! We will be praying for her here!
Jan, Thank you for the information. I will put that in my list of things to do better next time and integrate it into my next build (of which hopefully there will be many). Here is where I am at now. The hull is sanded now and the decks have been fitted. I made the baseboard already and the model sits perfectly on it. I need to plank the decks with wood grain contact paper prior to permanent installation. One of my coworkers who is used to building plastic models saw my Sampang when I had it in my office and really liked it. He purchased a Mamoli Il Luedo that evening. It will be his first ship model. He asked me to do a tutorial on measuring off for deck planking, so I will do that. For this model, I need to seal the hull next and add wales which will add structural integrity.
The first covering is on: The next step is to trim, fill and sand. Somewhere in here, I need to drop in decks and templates/thickeners for the bulwarks. After being fitted, but prior to permanent installation, the decks need planked with contact paper. Then I will seal everything and add wales and most of the deck fittings. Then it will be time to second plank the hull with wood grain contact paper and seal it. Somewhere in between I need to make a cradle/base and add waterways, bulwark frame extensions and railings. After that it will be time to add the rest of the hull fittings and cut out the rudder. After that everything is getting sealed and painted. Then I’ll add the rest of the deck fittings, and prep for rigging. Next it will be time to mast and rig the ship, including sails. While we’re on this topic, the plans have ratlines but the models in the book do not. Did cats typically have ratlines since they were designed to be worked from the deck?
Welcome!
Artreides Ornithopter by RGL - Meng
GrandpaPhil replied to RGL's topic in Non-ship/categorised builds
Very cool! Looking forward to this build! Dune has been a long time favorite of mine since reading the books many years ago. -
Thank you very much for the vote of confidence! Truth be told, the hull at the stern reminds me of the whaleback freighters, and the whaleback type designs of the late 19th century or early 20 century French battleships like La Hoche, La Redoutable or Charlemagne. The kicker is that the cats drew very little water and had a nearly square cross-section for the entire midsection of the vessel, and a very bluff bow. It’s a neat design.
The back 3/4 of the ship is covered: To include the stern: I need to cut out and attach a bracing piece for the bowsprit up forward before I can cover the bow area. As soon as the sternmost pieces dry, I am going to fit in and glue the transom in place to provide support.
Hello from Seattle - looking to buy a built ship
GrandpaPhil replied to wyapa's topic in New member Introductions
Welcome! I do not usually sell my models so this is not for me but for those who may be interested in selling off a piece of their collection. What sort of ship are you looking for and how large of a model? Also, Bluejacket Shipcrafters, operated by @MrBlueJacket on this forum, will sell their models prebuilt. -
Making progress! The first covering is looking pretty rough, but then again, most of my models at this stage are not usually particularly pretty. The cat ship has some sharp compound curves in the design which complicates things a bit. Once I get the hull covered and sanded, this ship will look a lot better. As a quick note, I’m starting to realize exactly how big this model is going to be, so I need to start planning on a place to put it when it is done.
I got my pulp board and covering resumed/started over: There’s going to be a LOT of filling and sanding to fix the starving cow look.
