GrandpaPhil
Posts posted by GrandpaPhil
5 hours ago, catopower said:
Hi GrandpaPhil,
I had trouble keeping the next layer nice and smooth on my last paper model. I don't have any advice for you, but there are definitely some ideas out there on the subject. Hope you have better luck than me!
I’ll use drywall spackle on the under layer to make a nice smooth surface to “plank” a second time.
I used a similar method to plank the hulls of the Hannah and the Prince de Neufchatel.
I will definitely need filler (drywall spackle for card models).
I usually use pulp board for the first layer. So this is kind of interesting.
I’m taking notes for future builds.
- Bill Morrison, Edwardkenway, KurtH and 9 others
- 12
Thank you all very much for the comments and the likes!
I started covering the hull today.
The first covering is with very thin card.
Yes, the laser cut pieces on this kit are amazing!
Their HMS Alert and Le Coureur kits are very nice, too.
The full set of 3 models (including the Mercury) only ran me $85, with shipping, from Age Of Sail.
It’s the Northern European Sail, Part II set.
The Alert or Coureur would make an excellent starter kit.
- Bill Morrison, Oldsalt1950, mtaylor and 3 others
- 6
Bulkheads/Framework:
Here’s the first lower deck pieces:
Here are the lower decks in place:
The false main deck is on:
I’ve never built a model with an actual enclosed gundeck before, so I’m paying very close attention to how it goes together for use on my Magenta.
Also, the framework is very rigid on this model. I would like to duplicate it on future builds (Magenta at the moment).
- Theodosius, Paul Le Wol, AJohnson and 15 others
- 18
I started my HMS Mercury by Shipyard Models. I couldn’t help it. I had to do it, lol.
I’ve been wanting to build a frigate for a long time (a few years now).
So, I started one.
HMS Mercury was a Sixth Rate 28-Gun Enterprize Class Frigate.
Her primary battery consisted of 24 x 9 lb. guns.
This is a POB kit, out of card.Something I have learned in my last two completed builds is that I work well in card and I enjoy it.
I am intending to build it straight out of the box, with hand carved guns and decorations.
Sails will be made from muslin again.
So here’s the start:
Here’s the lower deck pieces and the false main deck:
The Mercury is a little farther along than what I’m showing here.
The laser-cut cardboard framework, which came with the base kit, is fall together quality.
I had the frame assembled and glued within a couple of hours.
Everything lined up perfectly.
If you have never tried a Shipyard kit, I cannot recommend it enough.
I have not been this happy with a kit for a long time.
- Bill Morrison, Edwardkenway, BenD and 11 others
- 14
- Gahm, BenD, Edwardkenway and 10 others
- 13
- Edwardkenway, DanB, mtaylor and 4 others
- 7
I really like fully rigged models, with sails.
I bought a Shipyard Models HMS Mercury, a British 28-Gun Frigate from 1779.
It should be rigged very closely to the Winchelsea (and the Triton).
I am going to use the rigging and sail plans for the Mercury, adjust for size based off the mast proportions in zu Monfeld, to generate the masting, rigging, sail and belaying plan for Winchelsea, once I print the plans (I haven’t made it that far yet).
This will be fun!
- Edwardkenway, Paul Le Wol, Rustyj and 3 others
- 6
Welcome!
- Dave_E, Gizmo2K2, Keith Black and 1 other
- 4
Congratulations! Well done!
HMS Victory by tedrobinson2000 - Caldercraft - 1:72
Congratulations! Very nicely done!
