Everything posted by shipmodel
	Hi Chris - Looking forward to following your progress from the beginning. With such an ambitious building timeline it should be quite the project. One small word of caution - as much as I respect the work and scholarship of M. Budriot, I have found some significant issues when working with his monographs. He has a tendency to re-use his drawings from the 74-gun ship project for designs of smaller ships by simply reducing them in size, without taking into account the fact that humans cannot be similarly reduced. So check headroom clearances, ladder riser heights, and similar details before incorporating them into your model. Best of succcess. Dan
	Hi again – Just a quick note. In the last segment I was uncertain about how the stern access doors were represented. Even though they are just 2mm x 4mm, the dark lines were visibly jarring. Others noted this as well, and one sent me a private message with his opinion that the doors did not match the quality of the rest of the work. He was, of course, correct. Taking that to heart, I removed the inked lines and, after several experiments, replaced them with lines drawn with a sharp, soft pencil guided by a flexible straightedge. Below, the before and after photos. I think you will agree that the look of the doors has been substantially improved even if, under magnification, they are still not perfect. On a side note, I want to thank the modeler who was brave enough to put forward a criticism of my work in a timely manner. Although I do appreciate and cherish the compliments and likes, we are none of us perfect. Certainly not me. So if you do see something that you think can be improved, please, Please, do not keep it to yourself. If I have stopped at ‘good enough’ I need my feet held to the fire until I go back and make it ‘good.’ PS - since I saw it under magnification, I removed the little green tab that sticks up from the green sheer stripe just to starboard of the doors. Not a big change, but I felt better after doing it. Thanks again. Dan
- 287 replies
- michelangelo
 - ocean liner
	Hello again to all – A rewarding installment this time. No major problems at all as I finished the lower hull. While I was waiting for various deliveries during the boot topping odessey I worked on the hull details. The first were the two stowed anchors. These started life as Bluejacket castings, but were cut and ground to proper shape as shown in photos of the ship. They are not inset into the hull, as on most liners, but mounted on a triangular cleat and held with the stock in the hawse pipe. The ship’s name is a decal made on my ink-jet printer using a white decal sheet made by Testors. Clear sheets also came in the packet, but my printer works less well on it than on the white. You may have noticed during the last installment that the name appeared and disappeared out of sequence. That was because several were made, tested and rejected for one reason or another. It is not difficult to remove a bad decal with a little more water if it has not been overcoated with finish. This is the final one. At the stern the ship name is not done in black, but in gold. You can also see the outlines of the two sets of stern access doors that were mentioned earlier in the build with rust streaks coming down from the corners. The doors were simply inked on with an ultra-fine tipped marker. In the photo they look a bit too bold, so I may yet adjust them. The name and home port of Genova are decals. To get them to curve around the stern I scored between each letter through the decal film but not through the paper backing. I left a small band at the bottom to hold the letters at the right distance from each other. With careful manipulation with a small paint brush and a toothpick each letter was adjusted around the curve. Decals were made up for the plimsol mark. The mark is correct for ships flying the Italian flag, but at less than 10mm overall the letters “R” and “I” which denote the country are so small as to be almost beyond the abilities of my eyes, much less my printer. Several copies were made then varied slightly in tone before being printed out so I could select the closest match. Once the decal was applied and had dried the edges were overpainted with a bit of red and green decanted from the rattle cans. Decals for the depth marks had to be tiny Roman Numerals. They are beyond my printer, so they were ordered and installed. These were the last decals for the hull, so everyone was snugged down with setting solution and overcoated with clear varnish to secure them permanently. A pair of 20mm diameter counter-rotating brass propellers were sourced from Europe. A quick polishing with jeweler’s rouge on a felt cone and they were secured into the prop shaft tunnels that were tipped with brass collars. The rudder shape was taken from the plans and cut from 2mm hardwood. An airfoil profile was sanded into it from fore to aft. It was notched to fit the rudder hinge on the hull and a hole for a brass pin was drilled up through the rudder and hinge and into the hull. After a few coats of primer and final sanding it was painted to match the lower hull and installed. The final items on the hull are the fin stabilizers. These are small wings that take the place of the bilge keels to keep the ship from rolling. They were first reported on a Japanese cruise liner in 1933. As fixed wings they were not very successful, and were supplanted by gyroscopic stabilizers. These were too large and heavy, so they in turn were supplanted by automatically adjusted fins. It is known from newspaper reports and articles in engineering magazines that the Michelangelo had adjustable fin stabilizers, but none of my photos of the lower hull have any visible fins. I was never able to find more details, not even how large they were. Some fins are very small, and some very large, and some in the middle. Most stick out horizontally from the hull, but some angle down perpendicular to the curved hull. All modern ones are retractable to allow closer docking without the danger of damaging the fins. Some slid straight into the hull, while others, like the one in the photo, folded into slots in the hull. I found some drawings of the internal machinery of the retractable fins, and two are here just because I thought my audience would appreciate them. I made my fins from 2mm hardwood sanded to an airfoil shape and tapered from the hull outward. They are 5mm wide and 12mm long, which fits with the general appearance of fins in photos, and with my eyeball of what looks right for the size of the model. They are mounted horizontally in brass sleeves inserted in the hull. The lower hull is now complete and the model was firmly attached to its building base. This will be replaced with a presentation base once the model is finished. In the meanwhile, the fins were removed to safe storage and the lower hull protected in bubble wrap while work on the upper decks continues. So it’s off to the NRG conference in Florida. Hope to see many of you there. Be well Dan
- 287 replies
- michelangelo
 - ocean liner
				Le Soleil Royal by Nek0 - 1/72 - Marc Yeu
shipmodel replied to Nek0's topic in - Build logs for subjects built 1501 - 1750
Magnificent, Marc. Your pre-planning of every piece is resulting in a truly outstanding build, first time or not. I am even more impressed by your dedication to such small details as making square bolt heads. Inspiring work. But is that Darth Vader standing next to your row of cannon? Do you have a battalion of tiny storm troopers who are actually doing the work? If you do, that's even more impressive. Dan Dan- 208 replies
- le soleil royal
 - 104 guns
	Thank you all for the support and kind words. Love it though I do, there is only one thing more frustrating and rewarding than ship modeling, and that is golf. I have spent many masochistic hours chasing a little white ball around beautiful grassy fields. And into the woods, and streams, and sand traps. Now I do this. What was that definition of insanity again? Dan
- 287 replies
- michelangelo
 - ocean liner
	Magnificent work, Keith. Your attention to detail and accuracy are inspiring. Your results are amazing. I am sure that you mentioned it before, but what is the purpose for the openings in your deck? Will there be any problem working on them with the sails rigged? Dan
	Hi again to everyone looking in - Thanks as always for the likes and compliments, and to all who made suggestions for my boot topping problem. I believe that it has been solved, but not without lots of backpedaling and redoing. Here is how it went – When the last segment closed I had the Promenade deck structure done and was working on the upper decks. The upper hull had several coats of gloss white and the narrow green sheer stripe had been successfully applied using 1/16” green vinyl pinstriping tape which is made for the car detailing market. The next element was the wide green boot topping. I sourced 3/16” vinyl striping tape from the same people who made the 1/16” tape so the colors would be identical. The vinyl is somewhat flexible and here in the midships area and at the bow I did not have any trouble laying it down along the waterline. There were, however, several problem with the tape. First, it was too thick, measuring out at .008. It was not very noticeable, but in glancing light the raised edge could be clearly seen. A bigger problem was that despite its thickness, it wasn’t really opaque, and the demarcation line where the red and white met was visible through the tape. Not a lot, but hard to miss once you see it. But the biggest problem was that it was going to be very difficult to do the area under the counter. Due to the curvature of the hull the boot topping has to bend in three dimensions and, to keep the same vertical distance, has to get wider as well. The vinyl tape could not bend to fit the curves, and the thickness would make it lumpy if it was layered to make up the added width. I could have tried to cut and piece it in, but with the other problems I decided to scrap this product. With some care I pulled the tape off the waterline only to find that it left green residue along the edges. RATS ! Fortunately, it was removable with mineral spirits on a cotton swab. And while I was at it I cleaned the entire hull, removing all my pencil marks as well. To replace them I carefully mounted the model upside down so the keel was perfectly parallel with the work table and the stem was perfectly vertical, or as perfectly as I could make them. Then I used and old waterline marking jig that I made about 25 years ago and kept around ever since. A sharp point on a soft lead pencil did the actual work. To replace the boot topping I located and ordered some striping tapes that were described as being very thin, and some Tamiya masking tape that is meant especially for curves. While I was waiting for delivery, I tried Druxey’s suggestion of making thin paper strips. I used the thinnest paper I have, some art quality tissue paper. I could, with some care, cut strips with parallel clean edges. These were misted with water to relax the fibers, then I laid out the strip on the hull without glue. The water was enough to make a temporary bond. The results for me were uninspired. I could lay out the tape fairly well, and could move it around with some additional wetting, much like a water-slide decal. But it never laid down completely on the curves, even some of the smoother ones, much less the tight curves in all three dimensions under the counter. Maybe it was my paper. Maybe my technique. Whatever, it would not work for me. It would all have to be removed and discarded, along with the work invested. DRAT !! But as long as I had the paper tape in place on the hull, I tried masking both above and below in preparation for spray painting the green boot topping. The Tamiya tape had not arrived, so I cut long 1/8” wide strips of painter’s blue tape and laid it above and below the paper strips. This, too, was not completely successful. No matter how careful I was, I could see that there were small crinkles in the edge that would let paint bleed underneath, even after painting with a clear finish. The masking tape would have to be discarded, along with the work invested in laying it down. BOTHER !! Finally the thin striping tape arrived. It was Chinese, of course, and I had to buy 5 rolls in 5 different colors of 40’each, none of them green. But it was only .002” thick, which was promising. I used the white tape and laid out strips about 8 inches longer than the model on a length of waxed paper. They stuck well, but came up easily enough when tested. They were spray painted green from a rattle can. Repeated light coats were laid on till I was satisfied that the tape would be opaque. After drying overnight I carefully lifted the ends of a strip and pulled it up, only to find that the dried paint was stronger than the bond to the waxed paper. Attached to both edges of the striping tape were flaps of paint, some large and some small, but more than enough to ruin the tapes and they all had to be discarded. GRRRRR !! For the next set of tapes I made them a bit longer, but did not paint all the way to either end. When I was happy with the depth of color the tape was removed while the paint was still wet using the unpainted ends. It was immediately stuck back down on a clean section of the waxed paper and allowed to dry. The next day the tapes were carefully set along the penciled waterline. They were lightly pressed against the hull until I was satisfied with their placement, then burnished down. I finally had a clean, crisp, boot topping in the right color with a tape that was barely thicker than a coat of paint, and - - - next time - - - will be easier to achieve. Under the counter there were still some issues. With the tape so thin I could layer it over itself without major lumps, but it still would not bend, so a good deal of piecing in was required. The photo looks worse than the actual model because I have already hardened the tape with clear varnish and have started to sand the overlaps smooth, which accounts for a lot of the white areas and lines that you see. Once the sanding was finished I hand painted over the tape with green paint decanted from the rattle can. This not only evened out the surface, I could fill in the small angles to make a smooth curving edge. The final result was, I think, more than satisfactory, even under photo magnification. WHEW ! Now that I had the boot topping done I did a final light sanding of the lower hull which had picked up some scratches and blotches while I was working elsewhere. After sanding and wiping it down, I masked off the boot topping with the Tamiya tape made for curves. I have to say that I am a fan of the product. It laid down easily, could be repositioned as needed, and went around the curve under the counter without a problem. I burnished down the edge, then built up the rest of the masking in layers of widening strips of painter’s tape until the entire upper hull was protected. I sprayed a clear coat along the edge of the masking, as several of you suggested, then laid the model on its side to spray the red from over and behind the masking so the paint would not be driven against the edge. I used light coats and only did one side at a time, giving each a full day to dry. When I removed the tape I had no bleeding under the masking. But I did have THIS - - - The Japanese masking tape had pulled up the American paint from all along the Chinese striping tape. I wonder if this says anything about global geopolitics? In any event, all of my hard-won boot topping would have to be removed and discarded. There was only one thing I could say – When I got back to it after a few days to clear my head the repairs went fairly quickly. I managed to save the boot topping under the counter with minor touchups of paint, and the rest of the tape came off easily and without leaving a residue. I was now proficient in making up the tapes and applying them, so only two days later I had restored the boot topping satisfactorily. So I guess I learned some valuable lessons in perseverance and dealing with frustration. But I would much rather skip that class next time. LOL ! Be well. Dan
- 287 replies
- michelangelo
 - ocean liner
	Hi Nils - I am really enjoying following your build. Those barrels look quite lifelike. Excellent work. I do have some reservations about the gun carriages. To me they look very small and light compared with the size of the guns. Also, the trunnions are usually bedded down into the cheeks of the carriage so the recoil force is directed down into the wood. Before you do a lot more work on guns, you should check some sources. Dan
- 692 replies
- eagle of algier
 - chebec
	Hi Cedric - A very nice start. You are setting yourself a very hard task, kit-bashing to such a great amount. I am watching with real interest. I do have a bit of confusion about your calculation of the the distance between gunports. You have divided the hull into 17 equal segments, including the one from the forward port to the stem and from the aft port to the stern. I am not sure that these two distances were the same as the separation between gunports. I am no expert and I would not be surprised if I was wrong and they are the same as the gunport separation. But to me it just doesn't feel right. Would it make sense to locate your forward and aft ports where they fit, depending on the sizes and locations of the quarter gallery, headrails, etc., then divide the space between the two by 15? That would give you the distance from center to center, rather than the planking distance between ports, but that is just a technicality. Dan
	Hi Clare - Fascinating. It reminds me a bit of the mortice and tenon construction of early Mediterranean boats, as well as the laced planks of Egyptian boats. Am I right in interpreting the photos to show that the butterflies go all the way through? Won't that cause weak points, especially where the butterflies are close together? Dan
	Hi Nils - Really nice work on those spindles. The framework is coming together well. I can almost see her scudding across the waves. The gratings are nice and clean. The deck planking is coming along too, but I have a small issue with the three butt joints in the short planks between the gratings. Although they fit in with your planking pattern for the deck, I don't think a ship builder would add in an extra joint unless he was really short of wood. It's a really small point, and this deck will rarely be seen, but it's something to keep in mind for the upper decks. Dan
- 692 replies
- eagle of algier
 - chebec
	Bob - I have some thin white striping tape coming, which I was going to paint green and try to apply. After your suggestions, i will add some coats of clear on top for strength. Marc - I have some Tamiya masking tape for curves coming, and will try to do the masking that you suggest. Or I will gladly ply you with Maker's Mark after you have done the masking for me. Druxey - Failing everything else, I will cut a nice horizontal line across my forehead and slip in a layer of green jello as a boot topping. By then my brains will have turned to goo anyway. Later Dan
- 287 replies
- michelangelo
 - ocean liner
	Hi Bob - I have some decal film, but did not think that it was strong enough to make a striping tape out of. Another thing to try. Thanks. Marc - I am bad . . . make that HORRIBLE . . . at masking and painting. No matter what I do I always get some bleeding under the mask. Then I have to clean that up, then I have to clean up the cleanup, etc. etc. I am also not confident that I can mask both edges of the green so it is a consistent width. If I had done some prior planning I could have done a reverse mask of the green lines, but now that the hull is painted, that option is gone. Maybe next time. Dan
- 287 replies
- michelangelo
 - ocean liner
	Hi Druxey - Good suggestion. I will add it to my experiments. How do you get the paper to achieve a smooth horizontal line across surfaces that curve in three dimensions? Do you cut the curve beforehand? Thanks Dan
- 287 replies
- michelangelo
 - ocean liner
	Hi all – Thanks for the likes and compliments, and for following along. Now that the QAR 2 is done and delivered I can get back to this project, and to posting progress reports. Sorry for the long delay. Here is where I had reached last time, the hull shaped and painted, with the Promenade deck done except for some small details. The Boat deck has been shaped, both the deckhouse and its ‘roof’ which becomes the surface of the next deck up, the Superior deck. The Boat deckhouse, including several inset doorways, has been mostly sheathed. Decking sheet has been applied to the Superior deck surface where it will show around the deckhouse. From here the solid railing was applied around the perimeter of the deckhouse. It was important to make sure that it rose a consistent height of 3mm (42”) above the deck surface so it did not look uneven. In addition, this solid railing here and around the Superior deck is shown on the plans and the photographs as overhanging the deckhouse below. The overhang is only about a foot, but it creates a shadow line that had to be replicated. My solution to these two problems was to first shape and sheathe the lower deckhouse. The roof piece was cut slightly overlarge, then trimmed and sanded to sit exactly flush with the sheathed deckhouse. In the photo the deckhouse is upside down with the untrimmed edge of the roof to the left and the finished edge to the right. This is actually the Superior deckhouse and its roof, but the technique for the Boat deck was the same. After finishing the roof edge my paper planking sheets were cut oversize and glued down parallel to the centerline. When the glue was dry the paper was trimmed to the edge. This has to be done now, since it would be much more difficult to cut the decking to fit after the railings are on. On top of the roof several spacers of 3mm sheet wood were loosely taped to the planking Now the deckhouse was turned over again on a clean, level spot on the workbench. A plastic strip 5mm wide was cut, then set down on the bench and offered to the trimmed edge of the deckhouse roof. It covered the edge and, because of the spacers, always rose a consistent 3mm above the deck. Piece by piece it was permanently attached to the roof edge. Here is the railing of the Superior deck overhanging the Boat deck. The shadow line is just enough, I think, to indicate the overhang without being too stark. And here the Superior deckhouse has been capped by the overhanging Lido deck rail. This worked very well for the aft ends of these two decks. At the bow, however, there was a problem. As you can see in the photo, the forward faces of the Boat and Superior decks are flush with each other, as are the sides, aft to a common setback just ahead of the boats. Not only are the two decks flush, but the forward face is sloped aft quite a bit, as seen on the plans. To produce this smooth slope, I needed the two decks fixed together, but to work on the details of the deckhouses, especially the handrails that go above the solid railings, they had to be separate. I have to say that I have not yet solved this problem. I did clamp the decks together, drilled pilot holes and screwed them together without glue. This allowed me to do the rough shaping of the combined bow end, but I found that the positioning was not exactly repeatable, so I am still working on a better solution and leaving the forward area unfinished for now. As a bit of an incentive, I removed the masking from the lower hull and applied the upper, narrow green line with 1/16” vinyl pinstriping tape. I am not happy with the product. It is too thick and does not take the needed curves at the bow and stern very easily. The 3/16” boot topping was impossible to work around the counter at the stern without radical and obvious surgery, so it was removed. Unfortunately, I have not been able to find thin striping tape in green in the right widths. I am still experimenting with other solutions without a lot of success. But with the remaining deck pieces and funnel cages stacked up, I can see that there is a light at the end of the tunnel. And here she is posed in front of the model sized plan for the QAR. Quite a contrast, nu? More soon. Be well, everyone. Dan
- 287 replies
- michelangelo
 - ocean liner
	Nek0 - Well said, sir. Very well said. I am also on the artistic side of the artist/engineer spectrum of model ship builders. I do not think of myself as building a miniature ship, but creating a sculpture that resembles, to a close degree, the look of a particular ship. The historian in me insists that I get as close to the actual look as I can, but I recognize that this is forever to be out of reach due to the limitations of scale, technique, and my poor talents. It is nice to see that this philosophy is shared by others. Dan
- 2,678 replies
- heller
 - soleil royal
					(and 9 more)
	Marc - I take it all back. I took a look at what .033 actually looks like, and I am impressed that you got even one centered hole. Great work. Will you be applying them to the hull before or after you paint the planks? Dan
- 2,678 replies
- heller
 - soleil royal
					(and 9 more)
	Hi Marc - The bolts and washers look good. You are much better at slicing off tiny pieces of rod than I am. I don't know if it is too late for this suggestion, but there is a technique that works for me in situations like this - I drill the holes for the bolt heads before I part off the washers from the styrene strip. A simple jig will give you a line of holes .033" from each other and centered along the strip. Then you just have to cut between the holes. You can drill into the hull where you want the bolt to go, then pin through the washer and into the hull with your bolt. Glue, clip and clean up. Hope that can help you. Dan
- 2,678 replies
- heller
 - soleil royal
					(and 9 more)
				Roter Löwe 1597 by Ondras71
shipmodel replied to Ondras71's topic in - Build logs for subjects built 1501 - 1750
Hi Ondras - This looks like an interesting project, a build of another 16th Century ship, and quite difficult, with your having to compare and adjust two different sets of plans. I read through your prior build log, and you clearly have all the skills and talents that you will need for a fine rendering of the ship. I have pulled up a chair and look forward to enjoying your progress. Be well Dan -
	Hi Marc, Jan - If French practice at the end of the 17th Century is any guide, the hull planks were fastened with alternating wooden treenails and iron bolts. At butt ends I suspect that two bolts would have been used in the more problematic areas under strain. Not a definitive answer, but highly probable. Dan
- 2,678 replies
- heller
 - soleil royal
					(and 9 more)
Hi Marc - Thank you for posting photos of your outstanding work. You are clearly a very accomplished draughtsman and woodworker, and your model is well on its way to being a top notch work. I will be following along with great interest. It will also be very informative to compare and contrast your work with Hubac Historian's plastic model, and Michel Saulnier's as well. I may never build one of these massive projects, but I will learn a great deal from all of your efforts. Thanks again. Dan- 208 replies
- le soleil royal
 - 104 guns
