TOM G
Posts posted by TOM G
I think you will have it completed before his birthday. 👍
- thibaultron and mtaylor
- 2
If your still into building stick & tissue. check this out........ home of the very first balsa wood model airplane kit. https://clevelandairline.com/default.aspx
THank You, 2200 lumens, very bright and LED......... That should work for me just fine........ with my old age i need bright lite.
15 hours ago, popeye the sailor said:
the stuff I used came from a rattle can.......I've never tried a varnish before. does it give a hard finish?
You will have to read about it, to see if it has the degree of hardness that you are looking for.
Don't use a lacquer based flat coat, on enamel base paint...... act's like paint stripper. I use dead flat varnish it's water base........ and it is dead flat...... you can reduce it and use it in the airbrush.
- Old Collingwood, Canute, Egilman and 2 others
- 5
5 hours ago, LyleK1 said:
That would be tough to do since it’s already planked! But I like the idea!
Sorry....... for some reason i was thinking you was getting ready to plank........... so goe's my brain at age 68.
Your stains look good. Here's an idea..... stain some planks with the first stain, some with the second stain, some with the third stain. Then cut your plank's from those, and take the cut plank's throw them into a paper bag and shake them up........ dump them out on your bench..... pick up a plank and set it...... grab another and set it etc...etc...etc. What you end up with is color variation on all your plank's, and the deck does'nt look like one color from stem to stern.😉
Rabbit joint look's good.
The day will come, and you will be with your husband again............... It's just a matter of time.............. And we are all here for a very short time.
That's a grand peice of work..... Top shelf. I tip my hat to you Gary.😉
- FriedClams, Keith Black and druxey
- 3
Beautiful Work, Doris .
- EJ_L, DORIS, VonHoldinghausen and 2 others
- 5
Gary, i think what you have on your hand's is artist block...... i read about this. i have the same problems weathering freight car's. their's something missing but you can't put your finger on it. remendy : cover up the project and don't look at it for a few day's. then when you view it you will see what's needed.
- mtaylor, FriedClams, Roger Pellett and 1 other
- 4
On 3/22/2020 at 2:52 PM, usedtosail said:
Seats are next to do. I am going to practice with some extra balsa to see if I can carve a realistic looking seat cushion.
Try out rigid foam insulation board.
Jaws Orca by neilm - WIP
Class "A" build 👍
