Posts posted by iMustBeCrazy
On 1/15/2022 at 3:41 PM, Louie da fly said:
with two side-rudders
Steven,
I may be wrong but: (I might have to put that in my signature)
To me the depictions in the mosaics look more like sweeps through ports in the stern than any form of styrbord or rudder. I don't know how that would fit historically.
Nothing a coat of paint won't hide (after a little more filler).
- ccoyle, wefalck, thibaultron and 3 others
- 6
Well, I failed with the ply. It's just too stiff.
So I sanded a piece of paulownia (which I used/am using on my Bounty boats and for everything except the bulkheads on Kitty) down to 0.65mm to match the ply and fitting it was a piece of cake. Paulownia is very like double density balsa.
Once it's filled and painted no one will know.
- thibaultron and bruce d
- 2
Well, as I expected the bow sections are a bit more of a challenge. Both the long edges change from overlapping the keel or side to a butt joint to the stem or side
add to that getting the curve working and you can see it's going to be fun.
The shape wasn't too hard, templated in card.
And I think this will achieve the curves. It has been warmed with a heat gun but I do not know yet if it was warm enough.
And yes, that's another stringer gone.
- bruce d, thibaultron and goatfarmer11
- 3
43 minutes ago, MajorChaos said:
I’m trying to get the seat and thwart frames straight and level.
A rubber band and a piece of scrap wood will create a reference you can measure from. You can also square it up from one of the transoms to align things lengthwise.
- Knocklouder, WizardOfOs, druxey and 4 others
- 7
18 minutes ago, Ghost029 said:
I don't have a vice, so I am holding in one hand against the table
Make a 'V' block as shown, if the brass is too short put a bit of wood through it and clamp both ends.
Moving along, most of the bottom on but I suspect the rest will be more difficult.
Broke two more stringers but she is learning to fight back, she drew blood twice.
- Bryan Woods, ccoyle, bruce d and 1 other
- 4
40 minutes ago, Jim Lad said:
I would have thought her a little narrow for an 18 footer
A different class John but designed in Sydney.
- thibaultron and Jim Lad
- 2
Chines and shelves connect to the stem and stringers connected to the chines.
Sides fitted. Dang those stringers are fragile I've broken four or five so far, good thing I don't really need them.
- bruce d, thibaultron and wefalck
- 3
Enough for today, chines and shelves made and fitted, errors corrected. Next I have to work where and out how everything attaches to the stem.
- bruce d, ccoyle, Prowler901 and 1 other
- 4
Glitch number 2 and 3, Frame E is an inch too tall, frame B is 3/8 too tall. Can still be fixed in-situ but I'm kicking myself.
- 2
1st glitch, messed up frame D. Fortunately the fix will be hidden inside the hull, I just need to re-cut the notch for the chine and sand down the frame and stringers.
- 2
- thibaultron, ccoyle, Paul Le Wol and 4 others
- 7
Something a little different.
Hopefully this will be a quick build at least up to a painted hull, I only have until Easter to get that far. Some may be wondering why I'm not working on my Bounty launch.
Kitty was built in 1949 by my father and three mates and was going to be my next build after the launch but the son of one of the builders will be visiting at Easter so the launch is on the back burner.
I have been playing with drawings for a few months based on photocopies of photocopies of the 'plans' in a magazine, some incomplete drawings my father did in preparation for making a model, some photographs of the build and, fortunately, the materials list.
- thibaultron, mtaylor, Paul Le Wol and 4 others
- 7
Unfortunately I stuffed up either my measurements or my gluing of the landing strakes and the sheers don't overlap the landing strakes properly. There should be a 1" (scale 1/16") overlap the full length but I finished up with zero overlap at E, F, G and at the transom. The stem and midships are fine. I Ummed and Ahhed for some time and finally decided to add some packers to make the sheer sit at the same height it would be if it overlapped and then when I fit the fender it will hide everything.
Ok, I'm back. I got some insect repellent in my eyes and couldn't focus well enough for close work even with magnifying glasses. Better now.
Prior to that I fitted the landing strakes. These are clinker as mentioned above. This time I used a stepped rebate for the gains rather than the 45°s that I used on the small cutter. I glued depth stops to a pair of blades (you need a left and a right) and cut rebates going down to half the thickness of the planks. It worked well and was easier than the 45°.
4 hours ago, oakheart said:
does it look right?
I'm not that old!
The only real problem is you need to come up to the forward thwart.
Some examples:
https://www.rmg.co.uk/collections/objects/rmgc-object-66671
https://www.rmg.co.uk/collections/objects/rmgc-object-67761
Based mainly on the above and other contemporary models, the quarterdeck was likely solid (no gaps between planks), the foredeck either solid or a grating.
Based on experience, the rowers need somewhere to brace their feet. Either raised floorboards or footrests.
There will be exceptions.
On 2/3/2023 at 9:20 AM, oakheart said:
The Rattlesnake appeals
Tim, have you seen the nice big clear Danish Archive copy of the Rattlesnake drawing? https://ao.sa.dk/ao/data.ashx?bid=31921156
Kitty 1949 by iMustBeCrazy - 1:16 - SMALL - 18' Racing Sloop
The last pieces of decking being glued:
As you can see I was going to stain and 'varnish' the decks as the was how she was in the photos I had, but I found a later colour slide showing her in a pale aqua which is how I remember her (I couldn't remember if the deck was still varnished).
I see the boom has a splint (has been fished) but when the photo was taken there wasn't even a breath of wind, I wonder what the story was.
