Posts posted by iMustBeCrazy
1 hour ago, EvanKeel said:
I can take a hint, however subtle
From the short grain where those three broke you were always going to have trouble. I suspect they were cut too close to a knot. Bending them at 90° to the way you did may have helped but probably not. If the wood had been milled with straight grain it would be a lot easier.
I would suggest boil longer, take a rib direct from the boiling water and clamp it to to the mould near the keel, then walk your fingers along the rib bending it to the mould as you go. If at any time it doesn't feel like it's going to bend throw it back in the boiling water.
I broke several when I did it but I salvaged a couple by putting a clamp over the split to keep the bend then superglueing them when they dried.
Debating what to do about the colour scheme.
The exterior I will probably paint white or white below the waterline, the interior I'm going to leave 'natural' but the wood seemed a bit too light (see first pic in the post above) so I took some shellac and added a touch of spirit based stain and brushed it on. Seems to have done the trick nicely. The stain bled through the plank joins in some places, but only enough to darken the seams a little. I could leave the hull with the current shellac finish without anyone noticing.
- bruce d, AnobiumPunctatum, mtaylor and 1 other
4
On 5/19/2023 at 4:22 AM, Matrim said:
assistance from the plans masters out there
Well I'm certainly not one of them, I believe I'm further down the learning curve than you.
But since I have to do this myself sometime I had a play and this is what I came up with (not much):
This superimposes the frame plan (green) and the outboard profile (blue) over the inboard profile (red) and shows that the transoms are horizontal across the stern and that they are horizontal in profile except number 3 which tilts down following the lower deck.
Since number 3 tucks up under the lower deck, we can use the lower deck plan to get the shape of number 3.
That's about all I can come up with, hope it helps.
3 hours ago, Lieste said:
Unsure who copied the diagram by hand
It comes from a sketchbook by David Stauffer https://www.gilderlehrman.org/news/civil-war–era-sketches-david-stauffer
There is a second part to the sketch:
- mtaylor, thibaultron, Archi and 1 other
4
Ok, ok. I couldn't wait. She popped of pretty easy, just snagged a little on the plywood tabs holding the frames (see post #33), the cling film (saran wrap) worked great.
A small amount of excess glue and I over bevelled the planks a little but otherwise she's good.
- ccoyle, goatfarmer11, Montaigne and 5 others
8
Kitty's hull is currently getting re-painted white, I had it wrong. She will look a lot better for it.
I have also drawn up the mast, below is what I had to work with alongside one cross section drawn by my Father.
That's the mast on the right and the boom at the bottom. And, no I can't read any of the measurements either.
- Roger Pellett, wefalck, GrandpaPhil and 1 other
4
- oakheart, thibaultron, mtaylor and 2 others
5
STL files if anybody wants them.
6 Pounder Carronade Barrel.stl 6 Pounder Carronade Mount.stl 6 Pounder Trunnion Carronade Barrel.stl 6 Pounder Carronade Axle.stl
I was looking at drawing this trunnion carronade ( https://www.rmg.co.uk/collections/objects/rmgc-object-86768 ) as a possibility For Lapwing when I get back to her. But it turned out that it was a poorly dimensioned sketch and the carronade is too wide for trunnion supports to fit on the slide and bed. I could have made those wider but decided to put the mount under the barrel as per more normal carronades. I also decided to do a 3D version which is something that has been outside my comfort zone.
The results so far:
The barrel was built in sections indicated by the different colours.
And the mount was merged into the section of barrel.
Drawings and perhaps an STL file later, decisions about what to include and angles still to be made.
Looking good.
But have you faired 1,2 and 3 already? That gets done after you fit the ribs to the other moulds (but not 1,2 & 3). Not a big deal if you have but you will have to glue on some false ribs.
5 hours ago, EvanKeel said:When adding the stiffeners, i was a little worried they were slightly too long and there was a bit warping of the end molds (1-2mm max) but I decided this was acceptable. Thoughts? It's not too late to fix this.
So, your spacers are about 0.1mm long giving a cumulative error of about 1.5mm or are the about 0.2mm long giving a cumulative error of about 1.5mm each end? I think the magic number was 26.1mm so I would suggest replacing every fourth one with one 0.2mm short (ie: 25.9mm).
5 hours ago, EvanKeel said:Next up would be the dreaded bending of the cherry frames.
These have to twist to follow the faired moulds, I'm not too sure about a bending iron. I think I finished up boiling them for two minutes and fitting them as one piece (port and starboard as one) by poking it through the keel to the middle then bending but I don't think the keel actually needs to be fitted which would make it easier. Don't just grab the ends and bend, work your way out from the false keel applying pressure and clamping as you go. Make two sets of ribs so you have the intermediate ones pre-bent. When the second set has dried you could put a small dab of glue on each and then fit the keel.
5 hours ago, EvanKeel said:How do you like my picture insertions, by the way? Told ya I'd figure it out!
10 hours ago, oakheart said:
You may not have noticed, but there’s not been much in the way of progress here.
I certainly did Tim.
Fortunately my run has had better outcomes.
Late last year my younger brother was diagnosed with leukemia, treatment seems to have worked but full recovery will take time. Two weeks ago my mother had a small heart attack during a pacemaker replacement, she is nearing recovery. Three days after that my elder brother was diagnosed with prostate cancer, it was removed and despite it being a very aggressive cancer it doesn't appear to have spread. Me, my migraines are almost gone (they were only mild anyway).
But, that's life in a big city.
As for cutters, Lapwing will probably get some re-drawing after reading this document posted by Kris.
Ok, the deadline has arrived. I would have liked a couple more coats of paint but that's life. I didn't really expect to get any further in the timeframe.
- GrandpaPhil, ccoyle and wefalck
3
50 minutes ago, EvanKeel said:
Thanks for the detailed reply
No problem. One thing that would help with the planks is to take a bit more off the moulds when fairing, half a millimetre might do.
And you may be able to fit the transom with the TRANS on the inside and cover it with a backrest for the stern seat. Check it first, I might be wrong.
First coat of paint.
- ccoyle, wefalck, GrandpaPhil and 3 others
6
Hopefully I've done all the woodwork needed for now. A little more prep and masking and get some colour on her tomorrow.
That splash guard was a right pain, way too many angles all at once.
- goatfarmer11, Montaigne, Jim Lad and 4 others
7
6 hours ago, Dan DSilva said:
Did I miss something in the file descriptions?
No, sorry perhaps I did. However I do think that the Sailmaker painting is based on the Knijff painting and therefore the same vessel. I think here are just too many similarities. But hey, I could be wrong.
- mtaylor and Dan DSilva
2
More progress, remember to mask everything when spraying.
- thibaultron, goatfarmer11, wefalck and 3 others
6
7 hours ago, Dan DSilva said:
Royal Museums Greenwich says that they were normally ketch-rigged,
And here the RMG show otherwise. The wiki entry for HMY Fubbs says James II had 9 yachts. The two paintings in your first post are showing the same vessel at the same event and I suspect it is the same as the closest one in the painting I linked to. I doubt either artist was at that event but both must have had access to the vessel or a painting of it Or perhaps one painter based his off the others painting??
- thibaultron, mtaylor and Dan DSilva
3
Greetings fellow Bounty Launch builder, I'm on my second which is a scratch build, the first was a Model Shipways.
There are a few traps with the Model Shipways kit so I suggest you read all the build logs, this link should help you find them.
The most common are the word 'TRANS' etched on the transom and the length of the planks (only just enough if you do them perfectly), they should have been a little longer.
55 minutes ago, EvanKeel said:The Bounty Launch was a gift and, reading about it's history, I'm pretty interested! Amazing journey that I'll be reading more about.
In this thread we try to sort fact from fiction, you might find it interesting. It starts as a discussion about oars but morphs into a more general discussion on the Bountys boats.
58 minutes ago, EvanKeel said:they suggest staining the interior. Really?
Truthfully, nobody knows. It is likely it was white or perhaps grey but again nobody knows so do what you like.
1 hour ago, EvanKeel said:My keel does not perfectly match the false keel.
If that's about station/frame 3 it doesn't matter, that rib is added after removing the boat from the false keel. Same for 1 and 2.
1 hour ago, EvanKeel said:Some of the molds don't seem to be tall enough near the stern.
The ribs sit in the notches in the keel, the moulds should sit at a height that supports them there EXCEPT 1 2 and 3 where the moulds include false ribs as the real ones are added later. The instructions should warn against gluing planks to moulds 1 2 and 3.
I believe I've got that all correct but it was a while ago.
Bounty Launch by iMustBeCrazy - 1:16 - SMALL
Mocking up the interior:
