Posts posted by Edwardkenway
I also had problems getting on the forum 4 or 5 weeks back, that was in the early hours of the day, so it seems it's not confined to the US, but as EG said after a couple of hours everything is fine.
1 hour ago, Chuck said:Reset your modem and try again. This usually solves that issue. It is sometime as easy as turning of your modem and turning it back on again.
Works for me every time.
Chuck
This I did as I was always told if it don't work, switch it off and then switch it back on.
Very nice, Denis, very nice!!😃
Looks good Phil, the "planking " works very well 👍
- popeye the sailor, lmagna, mtaylor and 2 others
5
I got to agree with @fnickand @Jack12477 it does look like metal! Good work! can't wait to see the completed plane👍👍
- lmagna, mtaylor, popeye the sailor and 2 others
5
1 hour ago, lmagna said:
Is there a shore facility close where I can sit in the window and watch while tipping a few?
Is yew one o' them seafaring gennelmen cos if yew is, there's a welcome at the Saucy Shrimp!
Good ale and hot pies.
- mtaylor, popeye the sailor, Canute and 3 others
6
I'm away for 5 minutes and you go and finish, turned out rather nice as well if a bit odd looking. Great job Denis.
Edit: reminds me slightly of the tri-engine junkers with the prominent ribbing
- Old Collingwood, lmagna, Canute and 3 others
6
You've done yourself proud with those quarter badges, they look much, much better than the supplied castings.
Just a thought, but would it be possible to etch the roof tile pattern onto the wood rather than make them as a separate piece or maybe use a modelling putty for them and also the other details?
Keep the faith EG she looks alright!
She will look like lightning when "plated"😁
- Canute, popeye the sailor, mtaylor and 3 others
6
I had the exact same issues here and tweaked the frames to fit the plan then remade the top fillers, I just need to sand the pieces to fit.
Very nice Tiger Mark, I really like the minimalist look it's got going on😄
2 hours ago, Canute said:
Read them twice. Read Dudley Pope about Ramage, too. Authors Stockwin, Lambdin and Bond. Engrossing books.
But this log is about a vignette "somewhere in England" and a night-flying Mossie squadron. 👍
Yes yes yes, good authors all.
And yes meanwhile on a sweltering summer afternoon in leafy SE England nothing is stirring??🍿🍿
Yes yes sorry bout the log hijack but we is all eyes again OC
11 minutes ago, Jack12477 said:
just missing OC and "Spinach man" I guess.
They are probably stuck in traffic or the sat nav is playing up.😏
- Egilman, lmagna, popeye the sailor and 2 others
5
5 minutes ago, cog said:
You shouldn't forget David Donachie
Or Alexander Kent.
- Canute, popeye the sailor, Egilman and 2 others
5
Don't be too hard on yourself OC, I think looks fantastic, very royal navy, wouldn't look out of place on HMS Illustrious.
Edit: further research suggests that mk3 were on Hms Victorious and mk2 were on Illustrious
- Canute, lmagna, popeye the sailor and 3 others
6
2 minutes ago, Jack12477 said:
Or I could build a backyard pond, waterproof the hull, and float her out there. But then winter ice would be a problem.
A room of her own with a pond! Won't freeze over in winter🤪
Finished dimensions are
Length 40 3/4 inches or 1035 mm
Width 6 1/32 inches or 153 mm
Height 27 15/16 or 710 mm
The odd values are because the original measurements are given in metric
7 inches shy of 4ft, I think you need to find her a room of her own!😏 I thought Winchelsea was big at 38 inches and she's not going to be rigged.
17 minutes ago, Canute said:
I've been reading some novels of the Peninsular War of the early 1800s. Wellington versus Napoleon's marshals.
One of my favourite periods, if you haven't already read them I can recommend Bernard Cornwell's Sharpe series and C.S Forester's Death to the French and The Gun
EG even subconsciously through novels I still struggle, I'm great with pointless info but for anything else I have to have in front of me
Hannah by GrandpaPhil - FINISHED - 1/72 - CARD - from Hahn Plans
What did you do to make look better? whatever it was worked, it is great!!
