cog
Everything posted by cog
  1. Lovely detailed work on your kitchen ... I'm afraid you'll turn in hungry after finishing such a large pot ...
  2. "I have done a bit of pondering over the last several weeks" looks more like months. It has been reather silent, Dick. With regards to your masting problem: If you feel the evidence is thus, limit yourself to a single mast, or if you have multiple installed, pretend it's from a later aera ...
  3. Scott, you'd better start lookin' on ebay like: 20mm flak PE 1/200 or bismarck 2mm flak PE 1/200, etc, etc e.g. this one unfortunately 1/48 but you'll get my drift
  4. Nice build, I especially like the wooly underneath
  5. Very impressive. Certainly a ship which lends itself for this kind of illumination. Can't wait to see more of your updates ...
  6. I know you can't, but when you know the colour code from lifeColor, you can get the corresponding colour from the chart. I've got a another chart somewhere which gives the mixtures for certain colours, but haven't found it yet
  7. You might find this link to german colours interesting For the USS MIssouri here and these you can translate with this Vallejo Conversion Chart.pdf
  8. A little touch up and she ready to rock 'n roll mate. You'll have her ship shape in no time
  9. For Tamiya I use 1:1 paint:thinner On Vallejo Air I use it straight from the flask, the others 2:1 1:1 paint:thinner ratio, it depends how it works out I have used 1:2 ratio for it's primer. It just depends on the weather/humidity temp, etc. It isn't an exact science you might say. I had to store my airbrush and paints, as night frosts are cooling the attic, and spraying gets rather difficult whit frozen paint
  10. "Took way longer than I thought to paint this." That's what they all say... You have a very nice finish on those items, and I have to say your railings look very sharp!! The mast doesn't look bad at all, that is to say the rungs stand out quite well
  11. Quite some welding to do on your deck, a bit sloppy work from the supplier. What's "metho"?
  12. Thanks, when I get my wood I'll let you know. She starts to look awefully good Mike
  13. That's a tricky one ... it's IJN, so I would go for Hinoki, but cypress is soft so that would make it teak, else I would have a choice at oak or teak (depending on the year of construction)
  14. "I do those also" that's the spirit!!
  15. Found me a drawing, can you tell me if it is close enough ... What I've seen for Sopwith Camle planes, this would be a fitting prop ... well, actually half a prop sizes based on your given length total lengt 17cm max width 1.4cm (I can bring it down to your 1cm) max thickness 0.94cm seven layers : each layer 0.13xxcm I'll have to order some wood, as the stock I've got left doesn't meet the requirements
  16. No elevation ...??? I was so looking forward to that ... a real pitty ... Taking the planks off ...?
  17. Nah ... a gift would be more appropriate. Maybe just postage. It's a hobby, what's a bit of distraction time and wood between modeller mates
  18. I'll have a go at it, and shall let you know if I get as frustrated as you
  19. How's your treenail sharpener holding up Nice contrast with the deck.
  20. Looking good, Dan. I would have expected the "hanging" support to have it's two outer supports higher than the inner two ... Astonishing to realise how much time some simple looking supports need to cut and put together! Sometimes I use a round cutter/drill in straight edged corners too to give me some leeway with the knife/saw. Never would have thought of that Slog.
  21. Mike, Can you give me the measurements of the prop. The smallest ones I can find are 9" or 10" which is a wee bit to large to have it twirl around ... but I wouldn't mind giving it a try meself ... (a good excuse to do something else then twisting, folding, and glueing PE) Love the look of your model ...
  22. That was not my thought, I gathered you had to correct the angle on the rod before you could attach the sleeve ... A resistance soldering unit ... well now that is new to me Looked it up, what I make of it, is it looks a lot like welding with solder ... interesting device
