cog
Everything posted by cog
  1. Maybe get a help topic on the subject. You might ask an admin for it
  2. Take care Denis, you shouldn't neglect things like these at our age. Get well soon, and do some shipmodelling to pass the time
  3. As Greg wrote Death Star, that Mark IV will certainly make it easier! Such a pitty, all those planks ruined, whole forests ripped asunder for naught. You need a hand demolishing? Enough pulling at legs ... you did make the right decision, I know you don't make these lightly. It will certainly work out to your advantage, a real French deck. Cheers
  4. I wouldn't worry to much about those straight lines, a steady hand comes with time. You need to keep on practising though. Once I could draw a straight line a meter long, when I was at the Academy of Arts, but nowadays, I'm glad if I can manage 20 cm
  5. Nice paint job, Kees. You didn't even loose detail n those hinges!
  6. Thanks for all the likes and comments gents Hello Nigel, The eyes are holding out. I got a visor which helps against cross sightedness, and headaches so far ... I'll be using airbrush primer and paint. Since you put on multiple thin layers, the detail should be preserved. You should take a look at the last work Greg Lester did on his Yamato here on the formum. Exquisite paint work. Thanks for stopping by Cheers
  7. So, looking at your avatar ... it's well passed
  8. Still up Greg, not passed modeller's bedtime
  9. Your painting makes it look very realistic. I like the way your railings turned out with the easy line. Might be even easier than the brass ones, considering the hardships those gave and give me. At least the look a lot better! As far I can see your kit has a lot more detail to the plastic to start with, which is a nice plus, a terrific job
  10. You might win a few games at that scale I'll be in for some stupid moves! I'm glad I tie my jaw shut before I have a look at your build logs. You are really pulling all the plugs, Igor. Increadible. It is magnificent to see the result of your labour. I especially like the "underwater" shot. A great result.
  11. Getting ready for the next 15mm turret. Available parts to pimp it: Now getting it all together ...
  12. OC, I thought a juwellers would be better, more attention, at Harrods it would just be another plastic kit
  13. Thanks, Greg. Luckily I've got some nimble tweezers! Got some wachmakers tweezers whith different tips that were quite convenient
  14. The funnel has been "brassed over", some more work to do on the front tower/bridge, finished the rear tower, and the rear 15mm gun Rear 15mm turret Looks good, until I mounted the rear tower ... it seems I have to get rid of some railing, if I want that turret to be able to move around buggers Still a lot of brass to add to rear turret. Next the front 15mm turret, and all the tripple AA guns ... I found that giving the plasstic a preliminairy coat of CA, and another when gluing the brass had the best result for me Cheers
  15. Thanks for the likes and the comments. Greatly appreciated! Joel, Yes it is in a way a pitty, but it adds quite some additional fine detail to the build which wouldn't be possible with plastic or resin. When I look at the gratings ... I wouldn't know how on earth that could be accomplished in plastic (how I wish al the brass weight would be gold !!!) Thanks for visiting!
  16. Personally I don't like billowing sails and oars out for rowing on a static model, or it should be diorama like. On the other hand, it is what you like, Mike.
  17. Stop fussing, buy the thing So what are you fussing about now ... Deathstar II subversion 5 release 59 ...
  18. Thanks Ed. Learned something new again!
  19. I'll play you when you have the pieces ready
