Everything posted by cog
You could ask Jan (Amateur), he's quite knowledgable on Dutch ships
- 756 replies
- galleon
- golden hind
... ready to load hay bales on a wagon
- 1,090 replies
- showcase models
- vendetta
Less beer, less games, less Murphy, I would suggest, but the first is impossible, the second necessary, and the third inherent to the previous two, so you'll be stuck with the way you work my friend ... you keep on muddling through (try and try again), and still have a way to create some lovely looking parts, which I would dream of making ... instead I just rip open a plastic bag and pull out a sprue with all detailed plastic thingies ... give yerself a break laddy, yer doin' fine
That's what I use. The only problem is the "halfeye" fills up quite quickly so you need to burn it out with a lighter, but it works rather well That explains your calm demeanor If only you could only reach them from downunder ...
- 1,090 replies
- showcase models
- vendetta
If you are right about their age, you are so very wrong
- 1,090 replies
- showcase models
- vendetta
Nice try, Lou, though I don't buy it. You are obviously an animal lover, and you won't lay the blame on them 😛 Although, you are still to blame in the end, since you didn't raise them responsibly
- 1,090 replies
- showcase models
- vendetta
As Mark wrote, what's left to be seen ... you might as well paint them. Besides, why did you paint the former PE parts ... as you airbrush them, the detail won't be lost, but spray them first darkish than add lighter layers from above to get more depth For Musashi 1/350 I've got the guns in black, after that I'll go to washes of lighter grey, and airbrush from above so the lower/underside of the parts seem to be in the shade
- 467 replies
- mikasa
- wave models
That's why we see so little advancement ,,, SIghhhhhhhhhhhhhhhhhhhhhhhh ........... and there flutters another piece of PE Dennis, those large scale builders have no idea what challenge(s) you are up to
- 1,090 replies
- showcase models
- vendetta
- 1,306 replies
- syren
- model shipways
You might want to get EZ line, which is an elastic thread used on models, if you put it on streched, you won't get those sagging lines
74-gun ship by Gaetan Bordeleau - 1:24
cog replied to Gaetan Bordeleau's topic in - Build logs for subjects built 1751 - 1800
Thanks Gaetan. Not much difference with the Dutch version -
You've got quite some parts to build it up, mine were not so finely detailed ... though they were a lot smaller too
- 467 replies
- mikasa
- wave models
Dennis, the PE primer I use with a brush too comes from Tamiya. Works rather well, like the rattle cans I use for larger surfaces or a lot of parts to be primed at once
- 1,090 replies
- showcase models
- vendetta
