Everything posted by capnharv2
Flo After you drill (or punch or whatever you do) the holes for putty, consider putting some type of sealant (like a flat, clear lacquer) in the holes before putting the putty in. That should help keep the stain in the putty from migrating into the end grain of the holly. One nice thing about putting a clear finish in the holes is that you should be able to scrape the deck to get any excess off. Just a thought. Hope that helps. Thanks, Harvey
If you're looking at rigging complexity, the Rattlesnake has 3 masts, the Niagara has 2. I suspect the Niagara would be easier to rig. Also, running rigging is simplified if you don't have sails. An interesting trade in complexity would be Niagara with sails vs. Rattlesnake without. Hope that helps, Thanks, Harvey
Don't forget to neutralize it when your done bleaching. I believe baking soda is the preferred neutralizer. Rebecca Whitman's book "Brightwork" recommends a thick paste of oxalic acid crystals in hot water. But I've given up on bleaching wood. My new toerails are iroko. I'll post pics when I get them installed. Harvey
Cutty Sark by NenadM
capnharv2 replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
My wife had cataract surgery a couple years ago. Her comment after surgery-"Wow, the trees have leaves again!". Recovery is pretty fast too. She had to take antibiotic eye drops for a month or so, and that was pretty much it. Yes, it can be pricey. But, if you can afford it, the surgery can correct other vision problems at the same time. Good luck Nenad. I hope things work out well for you. Harvey- 4,152 replies
- cutty sark
- tehnodidakta
Now you tell me about the chopsitcks!! Question-did you tie your ratlines fore to aft on both sides or fore to aft on the port side and aft to fore on the starboard side? For whatever reason, I've always tried to do fore to aft on both sides, and had a devil of a time on the starboard side (I'm right handed). Thanks! It's been fun and educational following your build. Harvey
Okay, I cheated a little bit. I knew that it was either a Bluejacket kit or a Laughing Whale kit. So, I went to the Bluejacket catalog and found W122 (now KLW122) is a New Bedford whale boat. I hope I didn't spoil the fun. Harvey
Geoff, A question about rigging sizes (I have your size chart from way back). I know there are places in the plans that call out for .012" .014" .015" .017" .019" diameters.When using only 30 and 50 wt thread, how do you determine which sizes are close enough to use the same size line and which are different enough? Also, when making 3 strand line on the ropewalk, how consistent are your diameters? On larger sizes, it's not been problem. But when making, say .015" dia line, sometimes, from the same spool, I get .013", sometimes .016" (this is after hardening it a couple days). I guess a lot of it boils down to "how good is good enough"?, and I was looking for your (and others') thoughts. Thanks, Harvey BTW, I like the highlighter on the plans for finding sizes. I also use them to show completed lines (it's easy to miss or forget a line that's impossible to put on as an afterthought sometimes)
How do you like AYC for shipmodeling Chuck? I've heard that it's an oily wood and can be hard to glue. But it's a wonderful wood for carving-I've made numberboards for our boat using Alaskan Yellow Cedar, and it was great to work with-reminded me of a softer boxwood. I plan to carve trailboards for Amie using AYC. Thanks, Harvey
- 269 replies
- Queen Anne Barge
- Syren Ship Model Company
Ken, Jay (Modeler12) and I had this discussion when he was building his MS Connie. I think we agreed that, since studding sails were mainly downwind sails, that putting them on the mainsail would blanket the fore course and its studding sails too much. The discussion is buried in Modeler12's build log for the Constitution. Note that he's scratchbuilding a fwd section of the Connie now, and his build log is there. Hope that helps. Thanks, Harvey
Jerry, I'm impressed with the forethought and incorporation of other folks' lessons learned in the building of your launching cart. Harvey
- 553 replies
- sloop of war
- constellation
(and 3 more)
Jerry, I'm no expert on trailers (boat or otherwise), but I would feel better with 2 supports per side. I worry that hitting a bump or hole while pulling it in a crosswind could cause it to jump and twist off the trailer. Just a thought . . . Thanks, Harvey
- 553 replies
- sloop of war
- constellation
(and 3 more)
Thanks Ed. I learn something every time. Harvey
- 3,618 replies
- young america
- clipper
They may not have been turned in the past, but they can turn them in Grays Harbor WA http://www.thesparshop.org/
- 3,618 replies
- young america
- clipper
Rob, I missed that. Was it here on MSW? Edited to add-Never mind. I found it. Great picture. I too would like to see your models of her. I worked on Puffin last summer. The usual volunteer stuff-paint, varnish, sanding. Her boiler was getting worked on. She's a neat little boat.
- 1,208 replies
- great republic
- clipper
Rob, Mark, It is a bit of work. That is our boat, the Friendship Sloop Amie (might explain why I like Friendship Sloops), and I do normally keep her at the Center fro Wooden Boats on Lake Union. I've been working on her since January and have, probably 2 months to go. So far, I replaced/repaired 10 frames and 6 planks. I still need to finish caulking and below waterline seam compound before we can prep for paint. Also, I have new toerails to make and rot in the cabintop to repair. I've had help occasionally, but it's pretty much a one man show. Your models and Bremerton remind me-do you have the book "Maritime Memories of Puget Sound" by James Gibbs? It has some beautiful pictures pictures of square riggers on Puget Sound. My favorite is a shot of Port Blakely when they used to ship logs out of there (I think the photo is from the 1880's. It's wall to wall square riggers-quite a contrast to how it looks now, with expensive, isolated mansions dotting the bay. I apologize for the thread drift. Rob, you've got a fantastic model, and I've been enjoying this build log. Hope to meet up with you one day soon. Thanks, Harvey
- 1,208 replies
- great republic
- clipper
Rob, PSSM has about 30 members, about 6-8 who are active, and about 3-4 that come to meetings. Our president is Floyd Kershiner, and meetings are usually at his house. Most of us live on the east side of the Sound. I haven't been to the meetings much lately because I have a little bigger project I'm working on. When I'm done with this I hope to get back to ship models. Thanks, Harvey
- 1,208 replies
- great republic
- clipper
Gotta be careful with the cave pics Rob. Puget Sound Ship Modelers might want to have a meeting there . . . Harvey
- 1,208 replies
- great republic
- clipper
Gee Ed, now I'm thinking about re-doing the capstan on my Constitution Harvey
- 3,618 replies
- young america
- clipper
