Everything posted by WalrusGuy
Those are some great shots, Eric! I really enjoyed looking at them, thanks for sharing them and also for writing up the excellent build log on this cool vessel 🙂.
The sides of the gun ports have now been framed and faired. It was very satisfying vacuuming the area revealing the smooth lines! There were some areas where the bulkheads were not truly perpendicular to the keel, so I had to glue some extra pieces so that the framed sides are symmetrical between both sides. Anyways, here are the photos!
Moving along at a slow but steady state. The lintels and sills are now all glued permanently. For the lintel of the quarter deck, I used binder clips to hold the slight curve in position while the glue dried. Here are a few pics before I start the vertical parts of the framing! Also, please do not hesitate to comment if I made any mistakes 🙂.
Thank you Steven! I made the small jig of the canon, and it seemed to clear the batten at all locations by the same distance: I then started gluing in the sills. First, to cut them I lined them up at the bulkhead, used a sharp #11 blade to mark the location of the cut, then used the hand saw to cut them out. This resulted in most of the pieces fitting nicely in the first go. I then glued pairs from both sides together to make sure they are completely horizontal. This was done by resting a ruler on them to make sure they were flat. Here are a few pics showing where I am at: Next up are the lintels. These should be a bit easier than the sills as I will use a strip of wood to act as a spacer, so no need to adjust each piece very carefully.
I hope you continue working on the model. I'm loving the progress you've made. The photos are like eye candy!
- 317 replies
- enterprise
- caf
Never mind! I think I fixed it. I used the second option of removing bits and pieces from about 2 cm in to the edge of the bulkhead using a #11 blade. It was very tricky, so I had to be a bit slow and deliberate when removing the excess material. I used these clips to hold the the false deck so I could see if it is level or not. Seems to be good now (or at least much better!). Before permanently assembling the sills, I will make sure the guns can fit nicely using a cutout of the plans. So that will be the next step..
I hit a bit of a snag when using the testing batten to see the sills of the gun ports. I noticed I did not completely sand my bulkheads flat before gluing down the false deck. So now there are two spots where the deck is not level at the ends of the bulkhead. Here is a picture that shows this issue: All these issues arose because the two problem bulkheads did not fully enter the slots for them. Only if I had quadruple checked!! To resolve this, I think I have to carefully remove the false deck and sand the tops again to be level with each other. Another (tricky) way would be to remove bits and pieces of the bulkhead below the false deck until it remains flat. I will probably spend a day or two deciding what to do... If anyone has any idea I am all ears! I was also considering asking for replacement parts from ModelExpo and start the thing again, but I will try fixing this before I go that route.
The display case looks amazing! Very professional. Awesome work!!!
- 87 replies
I hope I remember this for my Confed build. The decking is looking great!!! 😀
- 99 replies
- winchelsea
- Syren Ship Model Company
The aft side of the bulkhead is now planked. I installed the door jambs first which was not too great of an idea. I should have planked it first so I could file the edges more easily. I managed to cut the planks to shape, so it was not too bad, just took a bit longer. Here are some pics: Next up is the gun port framing. This ship has lots of guns, so this will take a while 😄
All the best during your surgery, Michael. Get well soon!
- 2,215 replies
I finished planking and treenailing the vertical section (the bamboo skewers were thinned down to the third last position on the drawplate). After some sanding I applied tung oil: I'll next plank the otherside of the same bulkhead, put in the door jambs, and fix a slight warping issue on the false deck..
Hey Chuck, sorry if you have mentioned earlier, but what wood finishing did you use on the deck and hull? Or was it left in the natural state?
- 1,784 replies
- winchelsea
Thank you David!! I tried using the matt acrylic as suggested. It is very similar to the first coat of the sealer. I also made another deck testing station, and tried a polyurethane satin varnish. Here are a few pics of the results (with just natural light): Another pic with the overhead lights switched on: I am now very confused on what to do. Before I was thinking of having the decking appear lighter than the hull planking, but I just like the look of basswood with tung oil too much. The treenails also look darker with tung oil, and I like that look then the muted ones from other finishes. I may just use tung oil for everything. Would love to hear other opinions though! Another option I was thinking about was putting tung oil on the sanding sealer. I applied the oil on the section I did before and the nails appeared darker like what I was hoping for: I am now also considering this option. I also finished decking a small section at the bow. So I will think about the finishings before I start planking the vertical part of the bulkhead.
Thank you all for the likes! Just a quick update, I made a sample deck to try out some finishes. On the left I used Tung oil and on the right is a sanding sealer. I wanted some contrast between the deck and the hull planking (a lighter deck and darker hull). I will be trying out some more varnishes/finishes before making my decision. Any suggestions are more than welcome!
