Everything posted by realworkingsailor
Hmm.... did the wabbits get to that last post Kevin? Did they sail off with your Victory without you? Andy
- 1,319 replies
- caldercraft
- Victory
Don't get discouraged, there are alot of people around here who are very interested in what you're doing. Don't even worry about the "numbers" Andy
Well... a modicum of progress.. this time by hand alone... Fore Topmast #3 (#1 The original made with kist supplied bits, #2 See Above) now squared down at the top and sanded down and rounded so the cap now slides all the way down to where it is supposed to sit. Next step, I'm going to take a file and turn down the mast to the diameter required below the hounds and taper to that point from both directions... sounds like not fun and a lot of dust... if I haven't made enough already... and I have to do this how many more times?!
- 1,148 replies
Hey Augie... Seen any groundhogs your way lately? Last trip down the seaway, passing through one of the locks near Montreal.. Saw a whole field full... Darned near a dozen or more! Wanted to go all "North Korea" on their @@@es (euphemistically speaking)... Andy
- 1,668 replies
- syren
- model shipways
Well I've never used a lathe...period... So this is all good info for me... I think I'm going to at least try to do one by hand... Although Mark's suggestion of going slower might help.. I was using a regular plug-in drill.... maybe the battery has charged up on my cordless.... Agh...I dunno... Tomorrow's another day.... Andy
- 1,148 replies
Well I've got this down to two options: 1) Do all shaping and tapering by hand (most likely) 2) Buckle and purchase a hobby lathe (and really make a mess).... BTW, there's still a shed load of work to do on the masts and tops.. Including paintwork... No laser char shall be seen by mortal eyes when I'm done.... And Augie...I don't think in my case it matters.... As I tried to allude to before... Even before I touched my file to the dowel.... Yikes... Andy
- 1,148 replies
So.. as promised.. and attempt at progress... sort of... I got right down to working those nice square cherry strips... and learned a few lessons... The first bit went ok.. got the section I cut for the fore topmast planed down to 6mm, easy. Got the doubled section filed down to 5mm... great... things where looking up at that stage... and then... I tried to turn down the rest of the mast... There is a lathe in the shed... but it's very old... I think it may date back to the 30s.. it's belt driven.... it's missing more parts than I can count.. and I don't think it runs.. So, I thought to myself... everyone else seems to be doing it, so why can't I use an electric drill instead. So, game as a pebble, propped the dril up in the bench vice, chucked my nice piece of masting in and gave it a spin... and watched as that nice piece of cherry wobbled all over the place (I think the radius of the wobble at the end was something like 4 inches). Stopped the drill... (obviously..duh ) Thinking I may have inadvertently inserted the mast incorrectly, readjusted everything and tried again. Much better.. got the wobble down to 1/2". I thought.. "I can work with this"... Then I applied sand paper.... (Keep in mind that up to this point there was no damage done...) I think a rodeo cowbow has it easier trying to get on a bull..... Well... I think the last two photos illustrate exactly where that little experiment went... As for lessons learned... Always buy more strip than you think you need (I figure I needed about 18", I did buy over 6 feet of 6.5mm cherry) When you plane down a piece... plane the whole piece.. or at least enough to do a couple sections... Buy a dang lathe and do it right... or find out from someone who's done it with a drill,how they did it... So back to square one... oh well... better luck next time... Andy
- 1,148 replies
So after a marathon sleep, a small surprise at the door..... The FedEx man had a parcel for me from Model Expo... The square stock wood that I had ordered a little over a week ago showed up... Sweet timing right?! They didn't have any 6mm walnut, so I hesitatingly ordered the 6.5mm cherry instead.....big sigh of relief... Good decision.. The colour is not too far off the lighter walnut shades... So you really can't tell at a distance. Yay! I'm waiting on one more package... (I'll share what that is if it arrives ) Andy
- 1,148 replies
And here, all this time we've been worried about Sjors and his battle fleet... Sneeky sneeky wabbits! Andy
- 1,319 replies
- caldercraft
- Victory
Not to worry.... I made it home safely Everything was just as I left it.... No signs of wabbits or popcorn....whew A laundry list of things to do....building shall resume soon Andy
- 1,148 replies
**big sigh of relief** Hope to restore full diplomatic relations at the earliest opportunity. Andy
- 1,319 replies
- caldercraft
- Victory
**Andy is desperately trying to avoid an international incident brought on by the misunderstanding of his intentions by a group of wabbits**
- 1,319 replies
- caldercraft
- Victory
For the record (and hopefully some clarity) I never refered to wabbits as anything other than noble wabbits. I was merely contrasting their helpfulness and guidance with the misleading information provided by the other rodent.. Andy
- 1,319 replies
- caldercraft
- Victory
Wabbits: kindly creatures that assist certain builders sorting out issues with problem areas of their ships. Usually associate in groups. Known for a love of fresh veggies. Groundhogs: miserable rodents who prognosticate on the possibility of the early arrival of warm spring weather...and leave you to freeze your backside off for six weeks longer than you're supposed to. Solo animal known for digging large holes in fields to trap large livestock. Eats like a lawnmower Andy
- 1,319 replies
- caldercraft
- Victory
**Andy still wonders how the wabbits got upset as be never called them groundhogs** **Andy hopes Kevin can explain to the wabbits that there are drastic differences between groundhogs and wabbits and they simply cannot be mistaken for each other** **Andy is confused as all he##**
- 1,319 replies
- caldercraft
- Victory
Oh.... That colour... That is just yellow ochre from Model Expo (thinned down about 2:1)... Hope that's more what you're after Andy
- 1,148 replies
I'm going to assume the blue colour? Trueline Trains BC Rail Blue I know that probably doesn't mean anything to you, but it's a special colour mix done by Testors/Polyscale for a Canadian model train maker. I don't think you can get it overseas, but tou may be able to order direct from them http://www.truelinetrains.ca/paint-accessories/paints As for the copper... I first marked the waterline,masked and painted the grey to it. There's no paint underneath, I just glued directly to the wood and right up to the waterline. It probably sounds scary, but very careful marking and cutting and I managed to get the plates to run cleanly along the very edge of the paint. I found the best way for cutting plates was to first mark the start and end point of the cut with a couple of small ticks with a sharp #11 blade. Then put the plate flat on the cutting matt. With a stainless steel ruler, and a craft knife (you need a heavier blade than an exacto here), scribe a line between the 2 tick marks, run the knife only 2 or 3 times. The take some smooth jawed long nose pliers, line the plate up along the score line, holding the side you want to keep, and bend the plate along the score mark, it should just pop cleanly along the score line. The only thing I found, with longer sharper plates it helped to score right through at the point for about 5mm. That's probably more than you needed to know... but you got me on the subject.. BTW.. for those interested.. I've not left yet.. but will be in a couple of hours.. home soon... Andy
- 1,148 replies
Nice work Jim, and congratulations! She looks a little precarious, balanced over the pool like that... Looking forward to your next project. Andy
- 88 replies
- amati
- robert e lee
Well.. ask them to cool their tails.. no one's calling anyone a ground hog... Except maybe this critter:
- 1,319 replies
- caldercraft
- Victory
I never called them groundhogs Maybe some of their distant hole-digging cousins.... Augie! Back me up here! Nice job on the stern too... Andy
- 1,319 replies
- caldercraft
- Victory
So what you are saying is... when I get home.... beware of any left over "Easter Eggs" Andy
- 1,319 replies
- caldercraft
- Victory
No.. sorry... not home yet. I wouldn't worry too much about them, really they are almost too thin. They will follow the tangent to the curve of the pilot house at the points they join at. The windows themselves wouldn't be exactly curved either, they would be segments of the curve only. And it is only styrene, if you're not happy with your first attempt, just re-heat, flatten between a couple good heavy books and try again. Andy
- 326 replies
- vinal haven
- steam ship
Yeah... nice quick way to clean up blocks by the dozen... Although you started with some pretty rough looking customers there..... Andy
From what I hear, Anja, you don't have anything to fear from the Rocky Mountain fleet., or the Northern Lakes Guard, even the Mississippi Peacemaker or the Seaboard Fisheries Patrol. In honour your stabilizing effect on the European Block, your peaceful merchant vessels are granted free and safe passage. Andy
- 1,668 replies
- syren
- model shipways
