Mirabell61
Everything posted by Mirabell61
  1. Bob, the hammock netting Looks great, the whole ship seems to have reached a Status where you are preparing for the Standing rigging if I gues right... Nils
  2. Thank you Bob, I was much inspired by your beautiful boat for the "Essex", and after postponing a boats build for the "Pegasus" several times, that gave the Initial go for myself to do so at last. I know B.E. also built a beautiful longboat in POF mode, that I also had in mind, but I thought a 18 th century captain`s gig in clinker build was also not bad, and not presented at NMSW yet, and I just want to see if I can do it..... About half the planking is on now so that the other half will be repeatable work..... Nils
  3. Update...... the clinker planking is with 0,5 x 4,3 strips of nutwood 7 Planks per side between keel and sheer. I`ll fit one more plank later, each side above the sheerline due to leaving the rather sharp edged clinker contours, there is hardly no sanding afterwards possible, roughnesses can be trimmed with a flat key-file if necessary Nils
  4. Bill. its a pleausure to visit this build log, a wonderful representative of modeling art indeed. Thans very much for sharing this.... I like all those carvings, they look fantastic Nils
  5. Thanks Piet, do you have some pics of your version 2 Dinghi in progress ? Nils
  6. Very nice looking build Bruce, nows the turn for Fitting out...... Are you going to rig the sails later ? Nils
  7. update on captain`s gig for HMS Pegasus (scale 1:64) The first clinker-Planks on port side are on..... Nils
  8. Thank you Martin, for your appreciation, the choise fell on this boat because it Looks a bit more elegant than the more or less working boats (bringing out the anchor, etc...) . For a longboat the space in the Swan Class waist was not Long enough, and a cutter would have had too much beam. The captains gig now has widest beam at appr. 36% of its length. The 18 th century square-riggers, mother ships, mostly were resembling what was called the "cod`s head and makerel tail" lines and I wanted the ships boat to present These lines as well, as the boats were in general near copies of their mother ships, regarding to hull-lines. Nils
  9. Bob, I hope you`re right, the Planks will be very thin, and at the bow and Stern Ends the overlapping plank portions have to be thined down, so that the Planks come flush to the bow- and sternpost bedding. Trying to find some suitable Planks in my scrap wood-bin David, you are allways welcome, so we both can watch the open ending of what works out...... Piet, yes Piet I noticed your lovely Dinghi build activities in November this year already, knowing it is / was an ambitious Task, but it turned out very good looking, and the scale is even smaller. Does it fit into the appropriate Subs boat- hold ? Alistair, the Framework is very fragile, and having no proven kit to build from, all neccesary reinforcements have to be made and fitted as the Need requires. When planking is completed I shall remove it from the build block and and remove the centerportions of the framework Nils
  10. Outstanding work Matija ! sails and rigging looking superb Nils
  11. Captains gig the keellaying took place today the obligatory base board with supports for leaning and glueing the frames to.... there wont be any stringers except for one, bothsides, like shown here frame precuts (for breaking out) can be seen here Nils
  12. Build log part 69 Starting yesterday with a ship captains gig (POF build in 1:64) to suite the available space at the ships waist and on top of the gallows...., lashed to the spare spars afterwards Looking up my literature for a plan I could use, I fould a nice looking boat ( line- and frame plans), amoungst several orthers, in Chapmans Architectura Navalis Mercatoria. The plan had to be converted to a max length of 136 mm for the boats overall dimension without hooked in rudder. The frames will have (sawn) precut lines for breaking out the inner frame portions afterwards, and all frames brought to a horizontal level for fixing on a flat building base I would like to do the hull planking in Clinker mode and hope I can do it. Its a long time ago when the two lifeboats of my "Bohuslän" (appr. the same size) were built POF with clinker planking. This now shall be a little intermediate trip to 18 th century boatbuilding For fellow builders that are interested, I have made some pics comprising the to date status on this little project.... this is what I have in mind, (the upper two, and bottom right), pic borrowed from the web Chapmans book, chose model # 5 lines and frameplan transfer frames and keel to 1mm ply Deck- and waterline view frames cut out with the jig-saw Nils to be continued....
  13. Mark, a beautiful build, nice hull lines and fine framing work Nils
  14. Gil, a wonderful Build log, I love it, very good explanations, and lovely Pictures. Congrats,This surely is going to be an inspiring and welcome guide for fellow builders of 18 th century square riggers. The rigging is first class, very neat and Looks authentic to me Nils
  15. Nice work Rao, lovely scratch build Nils
  16. lovely winch Matija, are you using old clockwork toothwheels ? Nils
  17. beautiful work George, very nice rigging,and also first class Pictures taken, thanks for sharing.... Nils
  18. Keith, thanks for your words, for the sheet, tacks, brails, reeflines, etc,.... I refer to Lennarth Peterssons and James Lees publications Nils Martin, thank you for your appreciation, I trust that it will be easier to get the mounted squaresails prefixed to the Yards and then rigged to the masts, than fiddeling the stay sails in between the squaresails, but ist just a thought, I have to try it out, and see how it goes... Nils B.E. Many times I thought of rigging a full suit of sails, or if that would possibly overload the appearance of the model, or take much of the sight on it, but on the other Hand I know only of one "Swan Class" model I`ve seen, and that was in scale 1:48 bearing most of the rigged sails, and I found that very inspiring, so there was the challenge if I can do it in scale 1:64..... Nils
  19. beautiful Fitting of catharpins Danny, that is a real tricky assembly to get the correct Tension on These in relation to the shrouds.... Nils
  20. Lucky you Matija, good Equipment is what a "master" Needs.... Nils
  21. Popeye, Thank you, yeah, it Looks a bit strange without the square sails put on but I have to do additional work on some of the uncompleted Yards, and still I`m having some headaches with the two lower Yards (when sharp braced, Yard moving much away from mast). I should rather have rigged the the first two shrouds in stand alone single lines on each side and mast with a quick loostenable additional tackle, also not incorporating the catharpins attachments to These. Would recommend this to other modelers who may intend to rig Yards in a braced mode Nils Thank you Juergen, I`m quite happy to be so far with the build in the Moment. As my Amati plan Shows neighter sail rigging, nor stay sails, i hope and presume that the sails I did are not too wrong. I am using much more individual blocks for all those sail rigging lines than originaly intended, but I think it is worth it not to save material here..... Nils
  22. Beautiful art work Matija, performed like a jewelery maker (very smart idea with the brass wire !), Are you silver-soldering with a mini Gastourch ? Nils
  23. Good work on that Stern decor Nenad, it Looks great Nils
  24. Build log part 68 starting with the stay sails..... Slowly but constantly the sails are being rigged. The spanker and the bottom row of stay sails are on Nils Build log part 69 to follow
