Posts posted by Papa
I never heard of “craft paste”. Is it like spackling paste?
5 hours ago, ccoyle said:
Aleen's Clear Gel Tacky Glue
I will look into this
- Canute, lmagna, Old Collingwood and 1 other
- 4
If i may add another hint learned through trial and error. Don’t try to glue too many tabs at once. They just will not stay in place and everything gets out of whack. For example, on the frames i would add a bit of glue and firmly attach one of the 3 tabs to the “false keel”. Once that set, i’d glue the second. Etc. Likewise, in gluing the long waterline piece i glued one frame at at time, and one side at a time. It was slow work but everything stayed aligned. After about 3 frames i decided to add the reinforcement stripwood. One tab, one strip, one side. Then the next. It took a while😀 but i am pleased with the result.
- ccoyle, mtaylor, Old Collingwood and 2 others
- 5
- Old Collingwood, GrandpaPhil, hof00 and 2 others
- 5
- Old Collingwood, GrandpaPhil, hof00 and 4 others
- 7
14 hours ago, John Ruy said:
Very nice work! 👍Thanks. 😃
Today i received my new copy of the United States liner card model from Poland.
1. Photo shows how to properly join the beam sections, using tabs #6. I missed this the first time.
2. Note the triangular section in the middle if the frame, 13. In my first build, I didn’t realize there were 3 tabs in there needed to attach the frame to the center beam until i had cut the center out of about half the frames. I had to jury rig new tabs. 😳. I learned my lesson and am doing it correctly this time.3. i also learned that i need to write the part number on each part when cut out. Doesn’t take my 78 year old brain long to forget what part is which.
I am genuinely curious 🧐
- Keith Black, AiDi and mtaylor
- 3
16 hours ago, AiDi said:
have masters in theoretical physics and my interests focus around the geometrical foundations of quantum and classical field theories
This comment makes we wonder how many of our fellow ship modelers are in the sciences or engineering. I have a PhD degree in mathematics.
- 3
Love the well-worn look of the try pots etc
Not sure why i even said “slow”. Perhaps subconsciously because I probably don’t have enough years left to finish all my projects😃
- Tigersteve, John Ruy and marktiedens
- 3
On 9/20/2021 at 1:00 PM, domcath said:
What size scribed sheets did you use and where did you but them?
If you are referring to the deck houses, i got the scribed sheets at model expo i think. 1/32 scribing
Error creep has reach the point where i am stopping the build. I have ordered a new copy of the kit from JSC. Once I receive the new copy I will restart the build log from the beginning.
- mtaylor, Old Collingwood and Canute
- 3
I don’t understand the question. The boats are made from laser part parts that are stacked together. One then has to carve them to shape. I made a template for the bow and stern shape based in the plans.
There are many things wrong with the build and the errors accumulate. I am learning as i go along. I did use some CA to stiffen some very thin pieces a trick i learned from reading Dan Vadas build logs. Something is certainly needed to stiffen the decks. It seems to me that trying to spread CA over that large an area would be a messy job and could cause more problems than it solves. Gluing folded tabs on corners and edges leads to problems also. I think one needs to score and fold inside the line by the thickness of the card otherwise the dimension increases by 2 times the card thickness. I may try this on the next few cabins. Overall this kit is a learning experience.
Swampscott Dory by Melissa T - FINISHED - BlueJacket Shipcrafters - 1:12
I would hazard a guess that you are the only person on this site with a Herztsprung-Russell poster on the wall! I figured you had to be an astronomer, but i see from the profile you are an historian and amateur astronomer. Good luck on the Swampscott dory build. I grew up in Saugus, MA, right next door to Swampscott!
Ron Gove,
(Papa to my grand daughter)
