pwog
Posts posted by pwog
  1. Okay, I am finished. If you've been following you'll know that this was my first plank on build. This kit was overall a fun build. I believe I learned a lot, as I seem to do with each build. I guess time will tell. I'm not completely happy with the final shape of the hull. I was afraid to sand too vigorously when attempting to fair the hull, as the planks were very thin and I was afraid that I'd sand through them. Ih hind sight, I probably wouldn't have. Anyway, the following images show my result.
    Thanks to those who followed.
  2. So, I have cut my sails and waiting for a coat of varnish to dry before sowing the hems and panel lines.
    I am a bit disappointed that there wasn’t enough sail cloth provided in the kit to make the main sail given the required hem. Fortunately, I found some similar cloth, albeit a bit thicker in my wife’s sowing stuff.
  3. I’ve been pretty diligently working on my Dory. I finished my planking and trimmed the shear line. I built and installed the center board trunk assembly. I added the rails, added the seat risers and the rudder and tiller. I also built the mast step.
     I glued the seats in, but left the forward seat unattached waiting to attach the mast step and step the mast before glueing the seat in place.
    I also painted the inside and hull of the Dory. I found a picture on the Internet that I liked and tried to replicate the colors. My hull color came out a bit more blue than I was aiming for, but I like it.
    Don’t look too close, as there are a lot of errors 🤔
    Now I’m getting ready to work on the mast, boom, sails and rigging.
  4. I am currently shaping the last of the planks pairs. I’m a bit nervous how the planking is shaping up. There are a few bulges and the last planks are going to be attached a bit higher than the plans show. I overlapped each plank by 1/16th of an inch, per instructions. As this is my first attempt at planking, I’m not sure what to expect. However, I’m enjoying this build and will keep moving forward and see how it goes.
  5. Hello All, I am starting my third build and my first "plank on". I'm looking forward to this build, but have to admit I'm a bit nervous about the planking part.
    I have been spending some time reading over the instructions and looking over the plans. I really want to get a strong start, so that when the planking step comes the planks will fit with minimum issues.
    I have cut out and primed the frames. I primed as I have decided to paint the interior instead of staining/varnishing the wood.
    I then painted the frames and glued them together. I then started to layout the hull bottom using the plans, a divider and ruler to mark where the frames will go.
