AnobiumPunctatum
Posts posted by AnobiumPunctatum
  1. @Ed
    Thank you. I use also the waterlines of the half breath plan. I am sure that's a lot more work to draw this manually because it was more than enough work with my CAD.
    These sheer plane views are mainly for aesthetics
    You're right. But it made a lot of fun to do this exercise.
    Also I had some points I want to check with the drawing. On the Half Breath Plan were only the positions and angles of every second cant frame given. I wanted to check the reconstrction of the other cants. What's with the position of the gun ports? WHich cant frames do I have to shift? Is every timberhead given in the Sheer and Profile drawing on top of a frame?
    If I compared the position of the timberheads given in the Sheer and Profile of Fly and in the DOF plan of Cygnet, I found some alterations, for example at the fore cants. I wanted to check the consequences for the frame design.
    @druxey
    I've checked the position of all timberheads of the Sheer and Profile drawing and my reconstruction again. At the after cant frames I found two timberheads whose position do not really match with my cants. The position of the other four timberheads is ok.
    So I think to change my design will not solve the problem.
    What do you think is the better solution? To move the timberhead or to add a timber between the frames and not to change the position.
    @all
    Thanks for your interest and hints, which I really appreciate.
  2. Today it rained all day, so I had enough time to finish the design of the cant frames
    The Bollard Timbers and Hawse Pieces are missing to complete the planning of  framework.
    The individual components and the frames I'll draw later during the build.
    Next, the construction of the two-stage slipway is on the ToDo list, then I can lay down the keel for the model.
  3. In the moment I am working on a corrected disposition of frames drawing for my sloop
    The basis are
    • DOF of Cygnet (ZAZ4691)
    • Dimensions given in "The Ship Builders Repository", 1788 (1)
    • Dimensions given in Steel "The Element and Practice of Naval Architecture", 1805 (1)
    • Antscherl TFFM, Volume 1
    (1) The dimensions I took from Allan Yedlinsky "Scantlings of Royal Navy Ships 1719-1805". The original books are unfortunately to expansive for my hobby budget.
    The different timbers for the keel and the knee of the head, I took from David's book. I only adapt these to the other proportions.
    After a lot of measurements in the DOF of Cygnet and comparing with the given dimensions, I decided to follow Steel. I am really surprised how well the frames fit to the original drawing. If you compare the numbers of the sweep ports with the original drawing, yo see that there is one port missing, because it was not shown on the As built drawing.
    In the moment I am drawing the cant frames, which is much easier as by my second project. :D
  4. Dan, it looks like that you've nearly finished your build and also your log. These are very sad news. :(
    What should I read in the future? Your log was and is a big inspiration for me. Thanks for the really lot of work you've done by photograhing the steps of your build writing your explanations and so on.
    Your log is in my opinion beside the book of Greg the best source of building this type of model
    Thanks very much.
