Everything posted by AnobiumPunctatum
My holidays are over so the progress is much slower than before. I did the keelson before building the frames. So it is in my opinion much easier to adjust it with the fore and after deadwood. Before glueing the keelson on the backbone It take a long time. All frames have to be installed first. Today I worked on my first frame. It took quite long to find my way to build the frame. The result is not perfect, but I think doing the next frames will be much easier and faster. If it's interesting for someone I will do a step by step description from building one of the next frames.
Evan Thanks very much. I've stopped the project for the moment. I had to admit, that the project is to big and difficult for the moment. IPOF is the kind of ship modelling I like to do but I need to much trys for every part. So I decided to do a much smaller ship (Naval cutter Alert) first and learn the necessary steps. Then I will go back to my HMS Fly project.. I have the Constitution also in my kit stack and if I decide to give her a try, your log is very very good reference for me.
- 446 replies
- Revell
- Constitution
Really wonderful. I have to see, which kind of stove has my HMS Fly.
- 1,207 replies
- sloop
- kingfisher
After the drawing works it was time to make sawdust. First part is the keel, which is a little bit tricky. The keel has a light curvature and the joints are perpendicular to the base line. I cut some small stripes with my cirular saw, make the joints and glue the parts together. Next I added the parts for the stem. The picture shows the step on the building board. I use Tamiya Tape to avoid that the keel glues on the paper during the build. The next pictures show the complete assembled backbone for the small vessel, the stem with with the changed layout of the parts, the keel and the rising wood, and the stern post with the after deadwood. The next steps are cutting the rabbet, the keelson and the building board. Then I can start with the frames.
Have a look at the model I found on two German modelling forums modellboard.net and Wettringer-Modellbauforum .
Well done. It's a really wonderful little model.
- 100 replies
- model shipways
- 18th century longboat
Nice start, Ben. I will follow your log with great interest
- 889 replies
I was really suprised that I did not find a build log about the Naval Cutter Alert on MSW 2.0. I know that there exist some pictures of a model on the old MSW The first source for building a model of this small vessel are Peter Goodwins book "The Naval Cutter Alert, 1777", published by PhoenixPublications Inc. 1991 and the two original drawing of her sister Rattlesnake (1776) which you will find on the homepage of the NMM. There also exist two paintings of Joseph Marshall of the ship, which are exhibited in the Science Museum, London. I found also an Sheer and Profile drawing of Alert which was published by the NRG. The sheer and profile of the NRG and Goodwin differ from the original drawing. They show the maximum width of the ship not at frame 0. Perhaps my Engish is to bad, but I could not find any reason for this. So I decide to draw my own lines. which were based on Goodwin and the original drawing. The drawing is not finished, because I decided only to draw what I need for my build. Next step was the keel. Goodwin shows for the pass between keel and lower apron a solution which I could not find on any original cutter drawings. For the after deadwood he does not offer any possible solution I decide to follow the original drawing of Cheerful 1806 for the pass between keel and lower apron. The flat joint at the foremost keel part is shown on original drawings of this period (for example on HMS Triton). For the after deadwood I decided to use a bearing line. I am not sure if this is common for ships of this period. The next picture shows my completed keel drawing: Goodwin uses for his design the common frameing pattern of double and single frames. I am not sure that this design was used for the original ship. For the Swan class sloops only single frames were used. This you will also find on the drawing of Cheerful and other cutters. Also the wide of the frame parts are not clear. In his drawing he uses much smaller futtocks than he descibed in the text part of the book. In his "Construction and Fitting of Sailing Man of War" he gives a third solution. What now? Alert is a practice model for me to get the experience to continue my HMS Fly build. Marshall shows on his paintings an simplified frameing design, so I decided to use this. Every frame is 8'' width followed by 8'' space. For the port side I like to show the clinker planking. On my drawing the final design for the last frame and the hawse pieces is missing in the moment. The drawings for every 31frames and 21cant frames are finished. I am not sure in the moment if I will use the original practice with chocks or the simplified method of Harold Hahn for my build. It will be very nice if you have further information about the cutters of this time. I found the Marmaduke Stalkartt on Google-books, but they didn't scan the plates. Perhaps one of the MSW user can help me to confirm my decisions.
I found your log this morning. A really wonderful build.
- 446 replies
- Revell
- Constitution
Randall, these differences are quite normal. If you print out the parts on your deskjet, you will see that it makes a difference if you use landscape or portrait format. They are very small (0.1) and are up to the manufacturing process of the paper. Another source of the porblem is the thikness of the line. If I remember right they are about 0.25mm. If you saw out a part and sand to the correct size, you see normally more than the half of the line. 0.25mm in sum are very small but if you glue more than one part together your get very quick a difference of 1 mm and more. I didn't count how many deadwoods I have casted off until I understand how to work with these problems: Try to use allways the same paper and paper direction and sand your parts until the whole line is nearly invisble. And the rest is handcraft - so small differences are totally normal.
Really interesting start of your project.
- 346 replies
- terror
- polar exploration
