Everything posted by BANYAN
Lookin' good Greg; those two tones work well together. cheers Pat
- 233 replies
Great to see the update Keith, take as long as you like mate. Merry Christmas to you and your family Pat
Looking great Steven, that stand really suits. Happy Christmas Pat
- 508 replies
Ditto, happy Christmas to you and your family Glen cheers Pat
- 174 replies
- Waa Kaulua
- bottle
Your model is looking great Ian; and if I may use a superlative in the most sincere way 'outstanding'. Have a great Christmas and looking forward to her progress in the new year. cheers Pat
- 536 replies
- Quadrireme
- radio
This will make another fine display Greg; looking forward to seeing it. Happy Christmas Pat
- 233 replies
Hi HOF, great to find another member of the Endeavour club - and many thanks for the accolades, I hope my build lives up to your expectations. It looks like you have a very nicely faired hull, and the deck planking looks great. Looking forward to seeing her come along. Just holler across the ditch if you have any questions mate, I still have many of the photos I posted so just let me know if you need any, or need any clarifications on why I did anything, especially the rigging. cheers Pat
Good luck Greg, that will be a difficult pattern to mimic. Certainly looks effective. Merry Christmas Pat
- 233 replies
Easy for you to say Glen, me thinks this is more experience and good skills coming to the fore. You will really have to look outside-the-box to find a real challenge for your next hull build ... and BTW, the craft looks great in its setting - very nice work indeed. cheers Pat
- 174 replies
- Waa Kaulua
- bottle
Stepping the mast with a plum bob...two questions.
BANYAN replied to HardeeHarHar's topic in Masting, rigging and sails
Hi all, the method I use is based on the 'square' idea but utilises a jig. I make the jig as a triangle with a flat base that sits on the deck. I then cut the leading edge to the correct angle have set that up with a protractor; the angle (or straightness of the trailing edge does not matter. I glue/tack a small slat on either side of the leading edge forming a channel within which the mast sits - but I also do not glue the mast in. This cradle of sorts holds the mast in the correct alignment while I place the major standing rigging that stabilises the mast. The jig is as thick, or slightly thicker, as the mast itself. I usually make this from scrap wood (preferable something stable such as MDF) but it does not have to be very large; typically, a base of 2-3", and about 4-6" high I find is more than enough, and it remains small enough to extract it though the gaps in the rigging - note that I have usually fitted the upper masts off the model before this. I tack-glue a bit of scrap material (usually plastic) to the base that has been shaped to conform with the side of the inside of the bulwarks, or other fittings keep the whole assembly centred on the centre-line and aligned correctly. This done of thin material and tacked only so that it can easily be removed/separated from the jig for its removal. I hope this all makes sense? I then level the model in my building base (if not done earlier) by placing small bubble levels on the deck and adjust as required. Once level, I secure the hull in the building base. This method allows me to have the mast at the correct rake and also minimizing the chances of it being moved too far to port or stbd. Just an idea for an alternate solution. -
Wow Glen, those sails came up a treat mate; very nice. cheers Pat
- 174 replies
- Waa Kaulua
- bottle
Looks great despite its best efforts to thwart you Glen. Hopefully still enough room in the neck to get your masterpiece inserted? cheers Pat
- 174 replies
- Waa Kaulua
- bottle
Ha, would I do that? You had me worried when I opened your latest update. Before reading the associated text, it was a case of - Woa, what's Glen doing with snake skins Thankfully only leaves/bark. Great idea for preserving them. Looking forward to seeing them in situ; they will really set it all off. cheers Pat
- 174 replies
- Waa Kaulua
- bottle
Very tidy work John, she's looking great. Great to hear the proposed new project will probably go ahead. cheers Pat
Nice job on those braces Steven, they came up a treat - they look very symmetrical. cheers Pat
- 508 replies
Glen, are you sure you haven't confused this with another site? Just askin..... Pat
- 174 replies
- Waa Kaulua
- bottle
That's always the way isn't it Glen? Probably natures way of ensuring we don't get to complacent I suppose Anyways perhaps worth another tot? Now where is that keg? cheers Pat
- 174 replies
- Waa Kaulua
- bottle
Wow Glen, that is very nice work at any scale let alone at the eye-watering scale you are working with. I think that deserves a double 'tot'. cheers Pat
- 174 replies
- Waa Kaulua
- bottle
I haven't commented on this build earlier Greg, but i have been lurking and watching this build come together. You have become a real whiz with PE; some really nice detail you're adding in this (re)build. cheers Pat
- 233 replies
