BANYAN
SPECIAL CONTRIBUTOR
Everything posted by BANYAN
  1. If you have a lot of room for improvement Keith, I am going to need an eternity to catch up That is some very nice detailing. cheers Pat
  2. I can't help you with the wire composition Masa, but it has piqued my interest as I have some wire rigging to do very soon. I became a little concerned when you mentioned its heat/fire issue though. Although you would not put a model that close to a heat source, what about inadvertent temperature rises caused by light beaming through windows etc. Like you, I would be very interested in the properties as I was wondering how to source suitably sized wire. May I also ask why you are seeking a black finish to the wire? My understanding is that wirerope was treated with boiled linseed oil which, after some time would build up and make the wire darker, probably a silvery brown (darker in the grooves. Sections of the wire were parceled and served (not wormed) so will have been darker again in those sections? cheers Pat
  3. Rob, I know that you previously mentioned a deep hull, but did not realise how so until seeing the last batch of photos. WRT the compound, I am assuming you have done trials yto enure the outer planking will glue to it OK? cheers Pat
  4. Thanks for that Keith, had not thought on beading wire - will need to check that out also. cheers Pat
  5. OK we'll be generous, have a make-n-mend also, and as we're in a good mood, you can also have an extra tot cheers Pat
  6. Haven't lost me Rob, there is more than one way to achieve the same outcome. AS you are looking for hull form, what type of planking technique you use is entirely up to you. cheers Pat
  7. Coming along very nicely Ilhan. I am enjoying seeing the progress you are making. Pat
  8. Another masterful example of your skills Eberhard; they look great! A very nice addition of detail. cheers Pat
  9. Thanks Alan, I 'll keep a copy for future projects. Much appreciated. cheers Pat
  10. This will make into a great cross-section Doc. The keel is progressing very nicely with nice tight joints. cheers Pat
  11. Hi again Alan, I am also commencing this journey and have been doing a little experimentation. I purchased some plastic coated wire, which I think may be fishing trace to try; mine is clear but you can also get black coated. it did not matter for me as I intended, and did, melt the coating off. I also wish to experiment with control wire used with the tethered RC planes. I tried the former type first, as once the plastic is off the lay of the wire is more like the real thing with a 'flatter' longer lay. My initial worries are that it kinks a little too easily and if you tension it enough to remove these, there is too much strain on the fittings; but I am at scale 1:72. I found that by stretching it, it did remove many of the kinks but still not good enough that it would look right. I have not tried the control wire yet. I am also considering using a silver or grey thread made up into a loose/greater angle lay rope instead. The problem is that I am not sure it would stay together so well if laid at say 70 degrees. I will be interested in your thoughts on all this also. WRT to setting up the wires, for my build at least, the wires were not spliced but rather turned on a thimble and seized back on themselves (according to Underhill). I am assuming that yours may even be 'swaged' or ferrule crimped? Also, mine were set up with rigging screws and for the shrouds - rigmaiden lanyards ( metal tensioning device that had the same purpose like rigging screws). This will make things a little easier but finding or making (I am doing the latter) rigging screws is difficult/frustrating at 1:72 I also have to see how wire will respond in my serving machine as Underhill writes that the foremost leg of the shroud gangs, the eyes, and the tail ends of the wire ropes were parcelled (not wormed), and served. I have read somewhere, but not yet found it again, that the parceling was painted with white lead before being served, then the whole wire treated with boiled linseed oil. Not sure what the modern practices are, or whether you will need to do any serving. Hope this helps a little? cheers Pat
  12. Geeez, life is tough in the west, spare a thought for us 'pariahs' in Victoria still in lockdown Great idea for the bread boat though. Seriously though Dick, that hull is very well constructed, looks great! cheers Pat
  13. I'm still waiting for the lower tier of rowers (Ducks for cover to avoid the dynamite) That has turned into a very interesting and well executed model Steven, so I am guessing that that if you are going with the same sort of theme - your new build will have crew to carve, be quite colourful and very rarely modelled? Now what fits into that theme........ cheers Pat
  14. What are you on about Allan, that skylight looks really good. Are you talking about the porthole shaped skylight? The only thing I can see is that the 'glass' may need some polishing/cleaning. Excellent work on the wood finish, it will look great when sealed and polished. Nice work overall. cheers Pat
  15. Wishing you the best for a quick and full recovery Clipperfan. cheers Pat
  16. That looks stunning Steven, and I think you may be selling your building skills a little short noting the scale of this model. You have taken us on a wonderful voyage of discovery with this build, and I am looking forward to your next project - any hints? cheers Pat
  17. Ah, sorry Patrick I thought you were referring to the jeweler for the coating job. cheers Pat
  18. Nice work and research Steven. I note that in the second image above (Sermons ....) that the steering oar has another small cross piece where the swivel point would be. Have you considered and/or eliminated that? cheers Pat
  19. Ditto - that is some nice metal work Patrick cheers Pat
  20. If it helps, the Contract for HMCSS Victoria (1855)called for brass belaying pins. cheers Pat
  21. Thanks for posting this again Bob, I have also linked to it in my build log or associated posts as I think it is a great reference. Bruce, interesting to hear he is responding to contacts; how did you approach him. I tried sending an email to the university of South Australia but no response. I wish to pick his brain on whether he has much material/information on reinforcement plates (usually gunmetal) around the screw aperture in steam ships. cheers Pat
  22. Another stunning update; your workmanship is first class Keith and I always enjoy seeing your updates. cheers Pat
